Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 12-11-2005, 06:21 PM   #1
WRXWagonFun
Member#: 101829
Default Switch to Syntheic, when and how??? 06 WRX
Hi everyone! super stoked about the 06 WRX i'll be picking up in the days coming up. I need advice from all of you.
I'm want to switch to an all synthetic motor oil with a good filter after my second oil change. I'll probably move to MObil 1 since i hear it's a good choice. My question is: Which oil filter is good? I read some stuff on Fram, is that the way to go or should i be going back to the Subie dealership for an OEM filter?
Also, if i get the a good filter and synthetic oil, after how many KM/Miles should i be changing the oil? I don't gear down to use the engine break.
Thanks in advance!
WRXWagonFun is offline   Reply With Quote
Old 12-11-2005, 06:27 PM   #2
nate49509
Member#: 22452
2018 STi
I switched at my first oil change. About 3k miles. I've no problems the car runs great and dosen't burn a drop of oil. Mobil 1 and Purolator Pure One filters all the way.
nate49509 is offline   Reply With Quote
Old 12-11-2005, 07:01 PM   #3
poison
Member#: 37678
If you use Mobil 1, use 10-30 for sure. I recommmend against Mobil 1, however, because many suby people experience oil burn-off with it, myself included. It is a good oil though.
Try Castrol 'made in Germany' 0-30, it is very good stuff.
And PureOnes restrict flow. The OEM filters are very high-flow, and tests have shown that high flow/lesser filtration trumps high filtration/restricted flow. If you car is going into bypass mode, then what good is the ass kicking filtration media? Anyway the OEM filters filter excellently.
Stay away from FRAM. Period.
poison is online now   Reply With Quote
Old 12-11-2005, 07:38 PM   #4
WoohooRX
Member#: 70296
04 WRX
rally blue
I switched over to synthetic after 10K. I started off using Mobil 1, but my car ate the oil the like water, I don't know why.
Since then, I've switched to Castrol high performance something or another. This stuff is awesome, I haven't lost a drop of it, and I'm coming up on my next oil change in a few hundred miles.
WoohooRX is offline   Reply With Quote
Old 12-11-2005, 09:09 PM   #5
02Toyowrx
Member#: 56520
I would not switch to full synthetic before 8k. Also do not use any other filters besides OEM factory Subaru. They are worth the extra money.
02Toyowrx is offline   Reply With Quote
Old 12-11-2005, 09:21 PM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
2017 Outback Limited
And what is your reasoning behind that(8k before switching)? Not trying to be rude, I just have never heard that figure before...
I did one oil change with Dino @ 1k miles and then switched to synthetic at 4k. Considering that many cars come stock with synthetics these days, there shouldnt be any issues with switching too soon. The only things that I have read is that in some cases a car may be too old to switch to synthetics as they can seep due to the fact that they are much thinner.
Always use OEM filters, just buy a case of them
Gfunk720 is offline   Reply With Quote
Old 12-11-2005, 09:23 PM   #7
poison
Member#: 37678
From what I've seen on bobistheoilguy, STi engines have been seen to still be breaking in at 10k
Old 12-11-2005, 10:57 PM   #8
WRXWagonFun
Member#: 101829
Good input about the oil filters and when to switch to Synthetic but after i switch to Mobil 1.. how often should i be changing? once every 5k or 7.5k or what?
Old 12-12-2005, 01:08 AM   #9
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
I just switched to synthetic w/ Mobil1 but I am using 5w30 like the manual says I should . . is that bad ? I am also using the Purolator regular oil filter. I wana know why these are looked down upon ?
ALaDDiN is offline   Reply With Quote
Old 12-12-2005, 01:28 AM   #10
Charge
Member#: 3313
Depends how they're measuring that. We've had people crack open blocks on the board that had over 100,000 miles and still had machine marks that hadn't worn away yet.
Charge is offline   Reply With Quote
Old 12-12-2005, 01:31 AM   #11
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
i switched over to mobil 1 syn. 10w-30 at 10k.
Bishop is offline   Reply With Quote
Old 12-12-2005, 02:14 AM   #12
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Used dino oil until 15k, then switched to synthetic. To make it easier to know when to change the oil, I do it every 5k miles. It's just easier for me to remember to change oil at 20k, 25k, 30k, so forth so forth.
Been using the Puralator filter since the first change, it's worked great so far.
eltrouble is offline   Reply With Quote
Old 12-12-2005, 11:12 AM   #13
timmah
Member#: 54203
you do know the new OEM filter is a pile of crap, and is made by purolater, right?
timmah is offline   Reply With Quote
Old 12-12-2005, 11:52 AM   #14
poison
Member#: 37678
WRXWagonFun, it depends on your driving habits. You should do an oil analysis at 4k to find out. www.blackstonelabs.com Most likely you're fine going at least 5k.
ALaDDiN, 5/30 shears down a lot more than 10/30 of the same oil. I'd use 10/30, unless you live in the Antarctic.
Charge, they're measuring it by oil analysis: wear metal are still high around 10k on some, IIRC, but calm down after that.
timmah, purolator makes, in general, excellent filters. They have proven to have an excellent design and material quality, 2nd best flow rate (behind K&N), and one of the best filtration rates (and the overall best combination of flow and filtration without compromising either). Oil analysis doesn't lie, and Purolators bring in consistantly stellar UOA's. Keep in mind the Pureones aren't as good necessarily.
Old 12-12-2005, 02:57 PM   #15
bluesubie
Member#: 767
04 FXT
The wear metals in my FXT were just starting to go down to normal at 22.5k. These wear metals will shear most 30 weight oils down to a 20 weight rather quickly. If you're running a synthetic 30 weight before 10k miles on the odo, I'm willing to bet that it's a 20 weight in less than 3k miles (depending on your location and driving habits).
-Dennis
Old 12-12-2005, 03:08 PM   #16
poison
Member#: 37678
Wow. Crazy.
Old 12-12-2005, 08:47 PM   #17
lDeez lNutz
Member#: 94339
2005 STi
switch to synthetic if you feel like prolonging your oil change intervals, otherwise it's just pointless. synthetic oil is over-hyped with car enthusiasts, regular oil technology has come a long way. at worst i'd switch the oil filter twice every oil change interval.
lDeez lNutz is offline   Reply With Quote
Old 12-12-2005, 09:41 PM   #18
poison
Member#: 37678
ALL oil technology has come a long way. Dinos are great, but synthetics are still better and protect far more, regardless of interval. If you get a new car every 5 years, use whatever you like. If you want to keep it as long as possible, use synthetic.
Switching oil filters is a waste of money, unless you are going more than 7000+ miles or operating in dusty rally conditions (in which case you need to do more than change only your filter.
With the advances in filter technology, a 3k interval doesn't come close to maxing a filters capacity. People on BITOG have cut filters apart after 10,000+ miles and shown that they could easily go farther, both with piccs and used oil analysis.
Old 12-13-2005, 12:28 AM   #19
akinasdevil
Member#: 61050
2004 STi
72 Corona
Stick to what your manual recommends in terms of how/when to change the oil. I hightly recommend reading Unabomber's sticky/faq on oil, there is a lot of good info there. In fact any sticky by Unabomber has a wealth of good information and is worth reading.
akinasdevil is offline   Reply With Quote
Old 12-13-2005, 12:47 AM   #20
subenerd
Member#: 72630
2004 STi
everyone varies...I switched to Redine 5w30 at 3750. 48K+ miles to date and motor feels good, no issues. No analysis yet, oil change intervals are 4K - 5500 with stock filter
subenerd is offline   Reply With Quote
Old 12-13-2005, 01:35 AM   #21
dr327
Member#: 80243
2005 2.5 RS
Grey
The Mobile 1 works great. I would also consider changing the tranny and rear fluid to Redline Synthetic, it will prolong the life of those components as well. Check out COBB for amounts. Also, stay away from FRAM, they dont flow as nice. The OEM filters are actually Purolator Pure 1 filters, with a different label, so those work great.
dr327 is offline   Reply With Quote
Old 12-14-2005, 11:49 AM   #22
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
So if i was to live in the MidAtlantic region, which one is better for my 02 wrx .. . 5w30 or 10w30 mobil 1 . .synthetic . .
Old 12-14-2005, 12:16 PM   #23
VpointVick
Member#: 93193
'03 325iT
Mysticblau
After the seepage problems, they have scrapped the 09a filter, that was manufactured by Purolator, and are back to the black Roki 15208AA100.
VpointVick is offline   Reply With Quote
Old 12-14-2005, 05:37 PM   #24
dr327
Member#: 80243
2005 2.5 RS
Grey
Good to know, sorry about the mis information.
Old 12-23-2005, 07:10 PM   #25
jmax
Member#: 103196
06 TRIBECA
SILVER
Default synthetic oil
Ive had two subaru outbacks. One had 7500mi other had about 14000. Did both with Mobil1. One with lessor milage took longer to break in .Other with more milage ran much smoother.These engines need time to break in.Although it woun't hurt any thing ,It seems it's better to wait ,engines built tight from factory.Great motors ,will serve you well, be patient it, worth it.2001 ltd sedan,2003 wagon,2006 tribeca ltd.All great cars!
jmax is offline   Reply With Quote
How to install 2wss-s on 06 WRX? weggy Electrical & Lighting 5 12-20-2006 12:55 PM
When will the 06 WRX come to CT? platnumn General Community 17 08-16-2005 05:30 PM
When and How did you learn to Masturbate? HoOn Off-Topic 11 01-18-2005 01:56 PM
Switching to snow tires early...how bad is that? dedfish Tire & Wheel 10 10-15-2004 02:21 PM
Bay Area dealers and 05 Legacy GT: when and how much? Ken S Bay Area Impreza Club Forum -- BAIC 5 05-15-2004 03:31 AM
