05-04-2009, 11:33 PM | #1 |
Member#: 145122
MAIC
Vehicle:1999 99 lgt, 86 brat black, lt blue |
getting a piston bored questions????
i have an 02 wrx 2.0t engine that had a burned up piston. i tore it down and it is at the mechine and they said that it will need to be bored out to the next size over. they asked me what the factory askes for skirt and ring gaps. i called the dealer and they said they dont know. also i asked around and i have been told that only one over on 1 piston is fine for balence. not ideal but fine.
Last edited by supernick77; 05-04-2009 at 11:49 PM. Reason: this needs moved to 2.0 turbo page. sorry |
05-04-2009, 11:50 PM | #2 |
Member#: 191514
NWIC
Vehicle:'05 FXT 6spd, 98 Fozzy lifted,'01 RS 6spd |
I'd never do it but sometimes you have to do what you need to do. No way to pull off all 4?
05-04-2009, 11:50 PM | #3 |
Member#: 145122
MAIC
please move to 2.0 turbo
please
05-04-2009, 11:52 PM | #4 |
Member#: 145122
MAIC
trying to save money. unless i found i killer deal on all 4 oversized
05-05-2009, 08:22 AM | #5 |
Member#: 84181
NESIC
Vehicle:NASA #530 GTS2 |
I would be concerned that you'd be doing all this work for nothing. I can not give you an engineering answer on whether it's safe or not, but from my experience I've always did all or nothing. Doing 1 may upset the balance just enough to cause premature failure of other parts (IE bearings) and then you'll be doing this all over again wishing you found the extra 100$ to just do all 4.
Anyone else have a more... technical answer? |
05-05-2009, 02:35 PM | #6 |
Member#: 145122
MAIC
i wish it was only another $100. from subaru pistons are $75 each and then the cost to have all 4 bored vs 1. where else can i get 4 pistons. all the ones i have seen are 450 500 for a set. also anyone know what the tolerences are on the gaps?
05-05-2009, 05:21 PM | #7 |
Member#: 104206
South East
Vehicle:2002 WRX PSM |
find a blown ej205 with good cylinders. you can find plenty of spun bearing motors on here for dirt cheap. put your crank, rods and new pistons in there. simplest and cheapest solution.
Its not the best way, but its better than throwing your motor way out of balance. |
05-05-2009, 06:15 PM | #8 |
Member#: 114359
I wouldnt try to bore out only one cylinder. I agree either get another block or get 4 new pistons.
05-07-2009, 11:07 AM | #9 |
Member#: 13364
MWSOC
Vehicle:1996 GM8 caged, 99 V8 RSTi, 11' FXT |
Buy all 4 pistons. Get an aftermarket oversized set (not JP). Then give them to your engine builder and they'll build it to spec of the pistons. No sense in boring out the damn block before you even have pistons!
Judging by your complaining of paying $75 for a piston and even contemplating replacing one vs all 4 you are wasting your time thinking about rebuilding. You'll end up spending more on gaskets, headstuds, seals, etc. than you have a clue about. Don't waste your time or money if you're short on cash. Go drop in a used motor that runs w/ low mileage. It'll be cheaper. Unless you have at least $1k set aside for a super cheap rebuild. Or do what quadtard said... |
05-07-2009, 11:58 AM | #10 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
listen to him^
05-07-2009, 02:57 PM | #11 |
Member#: 145122
MAIC
i am going for all 4 now. i was just trying to save money at each step so it dosnt get out of control. the reason i asked is an over sized piston is only .5 mm bigger. with the way subarus run i didn't think it would even notice. i guess im in the market for 4 oversized pistons if anyone knows of some. i have an add in the wanted section.
06-16-2009, 01:23 AM | #12 |
Member#: 43196
TXIC
Vehicle:1999 STi Type R 93GF 95GC 02GD 01SF-T |
also if your machinist cant figure up ring end gaps and what not, take it somewhere else.
06-21-2009, 01:13 AM | #13 |
Member#: 56345
Vehicle:1997 OBS Primer Grey |
Similar Threads | ||||
EJ25 Block Halves w/ 100mm piston bore | XanRules | Engine/Power/Exhaust | 66 | 01-08-2011 09:56 PM |
Piston bore | Prevent | Built Motor Discussion | 3 | 09-25-2009 03:01 PM |
Mahle pistons/ bore question | ovedrivex | Built Motor Discussion | 5 | 01-08-2007 01:23 AM |
('93-'01) Since it's getting a bit boring, how about coupe or sedan debate? | danc | Impreza Forum | 55 | 05-07-2002 06:48 PM |
Need to get new piston rings, where to get? | Andrew | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 02-06-2002 02:00 PM |
