Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 11-17-2001, 01:44 PM   #1
Tex-WReX2
Guest
Member#:
Default Royal Purple Motor Oil
Well, I hit 10k miles in the wrx and decided to go to synthetic. After viewing the pumps in our plant that use another form of Royal Purple oil, I decided to give it a shot. I am also able to get it through work at a great price. I will pass on any fuel savings. The first thing I did notice was valvetrain noise was reduced. I am running the 10w40 at this time because as you know, Houston really has two seasons. Real hot ans kind of cool.
I am always looking for a little edge. And we all know, friction eats horsepower. Once I have an obd2 logger working perhaps I can compare temps and other variables. Fell free for any questions.
Old 11-17-2001, 07:15 PM   #2
NotoriousWRX
Member#: 9026
Good choice!
NotoriousWRX is offline   Reply With Quote
Old 11-17-2001, 07:36 PM   #3
Altered BeasT
Member#: 10062
2002 Ford Explorer
Eddie Bauer-White
Amsoil vs Royal Purple:
This is just an FYI... it's not to start a debate, just throwing some number specs of each.
Viscometrics 40 degrees C cSt
- The lower the number, the better because it means better flow at low temperatures. This is important for the many in colder climates:
Amsoil Series 2000 0W-30.....57.9
Royal Purple 5W-30...........62.5
Amsoil XL-7500 5W-30.........58.4
Amsoil 5W-30.................59.5
Royal Purple 10W-30..........61.8
Royal Purple 10W-30..........67.3
Amsoil XL7500 10W-30.........64.0
Amsoil 10W-30................64.3
Royal Purple 10W-40..........94.0
Amsoil 10W-40................79.2
Viscosity Index
- The higher the number, the less change due to temperature.
Amsoil Series 2000 0W-30......188
Royal Purple 5W-30............160
Amsoil XL-7500 5W-30..........160
Amsoil 5W-30..................197
Royal Purple 10W-30...........144
Royal Purple 10W-30...........149
Amsoil XL7500 10W-30..........148
Amsoil 10W-30.................177
Royal Purple 10W-40...........149
Amsoil 10W-40.................183
Pour Point
- Again for those of you in colder climates. This is the temp that the oil will still pour at.
Amsoil Series 2000 0W-30.....<-76
Royal Purple 5W-30............-44
Amsoil XL-7500 5W-30..........-60
Amsoil 5W-30..................-60
Royal Purple 10W-30...........-40
Royal Purple 10W-30...........-49
Amsoil XL7500 10W-30..........-54
Amsoil 10W-30.................-60
Royal Purple 10W-40...........-49
Amsoil 10W-40.................-54
Flash Point
- The higher, the better able to withstand high temperature. This and the next one are important, especially with the heat our turbos put out, or if
going to the track and running hot.
Amsoil Series 2000 0W-30......460
Royal Purple 5W-30............395
Amsoil XL-7500 5W-30..........464
Amsoil 5W-30..................442
Royal Purple 10W-30...........400
Amsoil XL7500 10W-30..........471
Amsoil 10W-30.................446
Royal Purple 10W-40...........400
Amsoil 10W-40.................450
Fire Point
Amsoil Series 2000 0W-30......489
Royal Purple 5W-30............435
Amsoil XL-7500 5W-30..........478
Royal Purple 10W-30...........435
Royal Purple 10W-30...........445
Amsoil XL7500 10W-30..........478
Amsoil 10W-30................. ?
Royal Purple 10W-40...........435
Total Base Number (TBN)
- This is basically the additive package that keeps the oil alive. The higher the number the better. Most of these numbers for Amsoil are the
minimum they allow, usually the numbers I've seen are between 12 and 13!
Amsoil Series 2000 0W-30.....11.4
Royal Purple 5W-30...........10.5
Amsoil XL-7500 5W-30..........9.0
Amsoil 5W-30................>11.0
Royal Purple 10W-30..........10.5
Amsoil XL7500 10W-30..........9.0
Amsoil 10W-30...............>11.0
Royal Purple 10W-40..........13.0
Amsoil 10W-40...............>12.0
In most cases the Amsoil beats the RP numbers, even their lowest line, the
XL-7500, which I've been told is pretty comparable to Mobil 1. I understand that Mobil 1's TBN numbers are around 9 as well.
A friend of mine who sells oil passed this info on to me... and I'll pass it on to you. I looked up a few of the specs and they are correct.
Altered BeasT is offline   Reply With Quote
Old 11-17-2001, 08:16 PM   #4
aZiator
Member#: 10040
2002 WRX Wagon
Sedona Red Pearl
This table looks oh so familiar!!! I switched from mobil 1 to the royal purple Racing41 in my Z and was very impressed with the difference in valvetrain noise at the first start-up. I am planning on using amsoil in the WRX, but I sure do love the RP and the way it looks after oil changes.
aZiator is offline   Reply With Quote
Old 11-17-2001, 08:46 PM   #5
Tex-WReX2
Guest
Member#:
Default `
Thanks Altered beast. I am always looking for good tech info.
What is the cost per quart for Amsoil?
Old 11-17-2001, 08:49 PM   #6
Altered BeasT
Member#: 10062
2002 Ford Explorer
Eddie Bauer-White
If I remember right, I usually see it for $7, but I was at a place here in Ma (Redline Performance) and it was $5 something. I think $5.99. It's a lot harder to find.
Old 11-17-2001, 09:05 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Although I use Mobil 1 in my road car, The only thing I will use in my race cars is Royal Purple, and that is here in Phoenix. It is the best
Eric
Eric SS is offline   Reply With Quote
Old 11-18-2001, 04:36 AM   #8
invisibleman
Member#: 8188
i haven't used royal purple but i've heard alot of good things. me i'm kinda stuck on motul because on my bikes nothing else came close to it.
invisibleman is offline   Reply With Quote
Old 11-18-2001, 02:16 PM   #9
Tex-WReX2
Guest
Member#:
Same here invisibleman
I use it in my current bikes (98 gsx-r 750, 2000 gsx-1300r)
I have used it for years and as you say, nothing comes close
Old 11-18-2001, 04:13 PM   #10
MrSwede
Member#: 9487
2002 Impreza WRX
Silver Surfer
Where can I find RP or Amsoil. I live in Northern KY, about 15 minutes from Cincinnati. I have looked around and can't find either brand. Any suggestions?
MrSwede is offline   Reply With Quote
Old 11-18-2001, 07:59 PM   #11
Tex-WReX2
Guest
Member#:
Default napa
........has it here in Texas
Old 11-19-2001, 12:58 AM   #12
invisibleman
Member#: 8188
hey Tex-WReX2 are you on the www.gixxer.com forum also? if not drop by. sorry for all those who didn't care but had to suffer through this little sidetopic. oh and i got an 01 750
Royal Purple Motor Oil SUCKS!!!! tayres North West Impreza Club Forum -- NWIC 58 04-28-2007 11:08 PM
Where to buy Royal Purple Motor Oil? InvertedB Mid Atlantic Impreza Club -- MAIC 4 09-23-2005 10:04 AM
Chi: Anyone interested in/know where to find Royal Purple gear oil? 8Complex Mid West Subaru Owners Club Forum -- MWSOC 23 09-04-2003 02:17 AM
Royal Purple Engine Oils???? JoeBloggz23 New England Impreza Club Forum -- NESIC 6 04-24-2001 07:41 AM
Royal Purple Racing Oil STi-Nismo Dood Normally Aspirated Powertrain 15 02-15-2001 05:38 AM
