04-28-2020, 04:13 PM | #1 |
Member#: 404487
NWIC
Vehicle:2008 Legacy Spec.B QSM |
OR: 2008 Spec.B -- Fully built, LOW miles
2008 Subaru Legacy GT Spec.B
$20k firm. Quartz Silver Metallic paint (QSM) 6 speed manual transmission and LSD rear diff from the factory-- shifts beautifully. Leather/Alcantara heated seats from factory. NAV + 6-disc CD stereo from factory (still works, but NAV is a little outdated) Fresh built longblock at 42,065 (have paperwork) Recent oil at 56,750 Recent tune at 56,750 (have dyno sheets) Currently sits at 57,0xx miles on chassis (it is not a daily driver, but I do put a couple miles on it here and there just so that it isn't sitting too much) Roughly 15k on engine, roughly 300 miles on the turbo/fuel system. Tuned in late April by Jarrad at PDXTuning/Superior Soobie & Import, using a Cobb AccessPort on speed density. The car makes 508whp/457wtq on E85 at 27psi and 423whp/380wtq on pump 92 at 23psi. There is also a low-boost map for E85 (23psi) loaded. Clean title in hand, no banks involved on my end. Tags/registration is good through July 2021. I will more than likely be keeping my plates. The main reason that I am selling it is because I am just looking to start a new project. I've put a crap ton of time, effort, and money into this thing, and I'm just over it. I change stuff up every couple of years, and I'm just at a point where I want to try my luck with something else. Absolutely no corners were cut with this build -- all high quality parts. Makes safe power and drives like a dream. Fast, handles amazingly, rides smooth, is comfortable to be in. Interior is stock aside from the Perrin gauges mounted on the steering console, the leather/suede seats are in absolutely perfect condition. The stereo and sound system works perfectly and sounds great-- stock speakers are awesome quality in this car! The windows are tinted to 25% in the rear and 35% in the front. There are a few minor door dings on the rear doors, but nothing insane. I have roughly $25k into aftermarket parts alone in the car. You cannot build a high horsepower Spec.B for anywhere near this price, unless you cheap out and use low quality parts, which I have not done. Everything is to the best standard. At my current asking price, you're getting this thing for less than 50 cents on my dollar. All custom bits were done professionally, and all welding projects were tig'd by a professional, top-notch welder. Absolutely NO test drives without cash/cashiers check in hand. No exceptions. Before you think "this car has been beaten and thrashed on"-- no, it really hasn't. I'm not going to say I've never redlined it or thrown it around a corner or two, but I don't really beat on my car. I want my stuff to last, I don't want to risk it blowing up, so compared to pretty much any other modified car out there, mine is pretty much just driven nicely. Mod list is as follows ENGINE -HMS Stage 3 shortblock (Manley forged 99.5 pistons + H-beam connecting rods, STI crankshaft, blueprinted & balanced) -Factory gasket kit used when built -B25 STI heads -ARP2000 head studs -BC Brian Crower 272 camshafts -GSC Power Division springs/retainers -KillerBee oil pan/baffle/pickup/windage tray -KillerBee 1/2" plug -Mishimoto magnetic drain plug -IAG street AOS -Cobb short-throw shifter -ACT HDSS clutch -Koyorad radiator + new Koyorad cap -PRE radiator hoses -Custom coolant expansion tank -Perrin oil cap -Cylinder 4 cooling mod using -10AN fittings fittings BOOST -Forced Performance Black 82HTZ XR ball bearing 3" inlet -Forced Performance in-line oil filter -Custom -4an stainless braided oil feed line -Turbosmart 40mm EWG INTAKE -N/A long-runner intake manifold shaved -Aluminati 19mm phenolic intake manifold spacers -Torque Solutions fuel rail adapter brackets -3" stainless steel intake + K&N air filter (#2820) -Forced Performance Turbo Inlet pipe -NWRS bypass valve plug -Factory modified intake snorkel to fit the larger intake filter EXHAUST -Tomei equal length headers (modified to 2-bolt to work with the uppipe) -GrimmSpeed ceramic coated uppipe+dump -Invidia 3" catless downpipe -3" stainless tig welded midpipe -Perrin dual axleback narrowed to fit the Legacy cutouts FMIC -3" ETS core -TiAL Q50 blow off valve -Custom tig welded aluminum pipe kit FUEL -Fuel Injector Clinic 1200cc injectors -Aeromotive fuel rails -Aeromotive A1000 Fuel Pressure Regulator -HotRodFuelHose -6AN PTFE fuel lines -Walbro 450 fuel pump -Fuel pump bracket SENSORS -AEM IAT sensor -AEM 3.5bar MAP sensor -Torque Solutions MAP sensor adapter SUSPENSION -BC BR coilovers -Whiteline front 24mm sway bar (set on soft) -Cusco rear 21mm sway bar -Kartboy endlinks front & rear + front spacers -AVO rear swaybar support brackets-Torque Solution pitch stop -Stainless/chromoly heim jointed front strut brace BRAKES -04 STI Brembo calipers (front, brand new when installed about 4k miles ago) -Stoptech stainless braided brake lines -Stoptech sport rotors, Stoptech street pads in front -Centric rotors, Centric PQPro pads in rear WHEELS -OZ Ultraleggera 18x8+48 with Dunlop Sport Maxx 245/40/18 tires, about 5/32 tread -Muteki SR48 lug nuts ELECTRONICS -AEM AFR & oil pressure gauges (both X-series) -Perrin dual gauge column gauge pod -Accessport V3 EXTERIOR -RallyArmor mudflaps -LED front and rear turn signals, reverse, high beam bulbs -Custom mesh grill (made by a local body shop) -Deleted rear bumper reflectors -Weathertech front floormats (have factory front floormats too) -Underglow (bluetooth/phone controlled) -JDM spats front & rear -NightRunner Int license plate bracket (would be happy to remove this if you don't like the front license plate angled) -BaysonR front lip Will come with: -Factory front and rear swaybars and endlinks -Factory shifter -6 quarts of Total Quartz 9000 Energy 5w-40 oil (enough for 1 oil change) -half a gallon of OE green coolant (pre-mixed with deionized water) -spanner wrenches for coilover suspension adjustment Recent maintenance: -Oil change at roughly 56,750 -- using Total Quarts 9000 Energy 5w-40 and a RX8 Tokyo Roki oil filter (arguably the best oil filter available to use) -Coolant flushed at roughly 56,750 using OE Subaru green coolant -Trans + rear diff fluid changed at roughly 53k miles (using Redline fluid) -Brake fluid changed when the calipers/rotors/pads were done, at roughly 52k miles-- DOT4 fluid used. CONS: -The trunk carpet does not fit perfectly. Previous owner ripped the entire trunk out, including the carpet, spare tire, and emergency tools. I found some carpet to put in, but it does not fit perfectly. This never bugged me, so I didn't mess with it. I personally use the spare tire well to store my emergency gear, a can of fix-a-flat, and an air compressor. -The front tow hook cover is not properly paint matched. It is currently painted grey. A can of professionally matched spray paint would be around $25, so it would not be hard to take care of this. I plan on getting to it, but I can't guarantee I will before sold. -The trunk was debadged, but the "Subaru" and "Legacy" lettering can still be seen very faintly from sun-fade. $20k firm.
06-15-2020, 11:26 AM | #22 |
Member#: 404487
NWIC
thank you! no dice so far, but im sure it will find a good home once the market opens back up a bit
If you're interested, i'd be happy to work out a deal with shipping. |
