09-06-2014, 11:07 AM | #1 |
Vendor Sales Rating: (0)
Member#: 400888
New product announcement - BtSsm
BtSsm is a combination Android app and OBD2 adapter for 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT
Prerequisites: Android phone or tablet, running at least V4.0, with Bluetooth or USB/OTG support
App running on an Android phone - realtime data display Learned Values - see what fuel/timing corrections the ECU is applying Capture knock events while app is running. See exactly what was going on at the time of the knock. Great help when you are tuning your timing tables (or send to your tuner). View your log file in raw format, or render it as a graph Please visit us at www.btssm.com for more info! Last edited by BtSsm; 11-25-2015 at 06:13 PM. Reason: updated to include up to 2014 WRX/STi |
09-08-2014, 08:00 PM | #4 |
Member#: 400888
This is the field chooser, where you pick what to monitor in real-time, log, or display as a gauge.
__________________
[SIGPIC][/SIGPIC][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT |
09-09-2014, 08:08 AM | #6 |
Member#: 400888
__________________
09-14-2014, 10:16 PM | #7 |
Member#: 400888
Graphing of logs was just added to the app itself! An update was just pushed to Google Play.
Tap anywhere on the graph, and it will display the values for each field.
__________________
09-17-2014, 03:05 PM | #8 |
Member#: 400888
FYI - a couple of other sites discussing BtSsm:
Similar BtSsm announcement on legacygt.com Thread on liberty.asn.au discussion
__________________
[SIGPIC][/SIGPIC][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT Last edited by BtSsm; 03-29-2015 at 05:17 PM. Reason: added liberty.asn.au |
09-22-2014, 12:49 PM | #9 |
Member#: 310796
Vehicle:05 obxt |
Bump for a good vendor. He is serious and has done a great job. It is awesome to use this app without having to carry around a laptop! Pull LVs whenever you want, get warning whenever there is a knock event, get real fast refresh rate, log data as you would with RR by hitting the rear defrost button. And all that on your phone! I think this is priceless.
09-28-2014, 07:23 PM | #10 |
Member#: 400888
Error code retrieval feature has just been added to BtSsm
On the main menu click "Codes". The update has just been published to Google Play.
__________________
10-03-2014, 03:50 PM | #11 |
Member#: 400888
Attached is a sample log file from BtSsm with 19 fields that shows the sampling rate is high compared to generic obd2 logging. No drop-outs. Great when you're tuning, or send them to your tuner.
__________________
10-04-2014, 08:24 PM | #13 |
Member#: 400888
__________________
[SIGPIC][/SIGPIC][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT Last edited by BtSsm; 10-06-2014 at 11:41 AM. Reason: added quote for clarity |
10-06-2014, 11:40 AM | #14 |
Member#: 400888
FYI - just published an update to Google Play that includes a new "ECU reset" feature. It is located inside the Trouble Codes dialog.
__________________
10-09-2014, 12:57 PM | #15 |
Member#: 400888
Here's a screenshot of the new "Dyno Chart Estimate" feature. It is a bit experimental at this point, but with some refinement it could be a helpful piece of BtSsm.
An update with this new feature has just been published on Google Play.
__________________
10-12-2014, 11:30 AM | #16 |
Member#: 400888
New update V1.0.9 just published to Google Play includes:
__________________
10-20-2014, 12:51 PM | #17 |
Member#: 400888
A new update of BtSsm has just been published to google play
__________________
10-22-2014, 03:31 PM | #18 |
Member#: 400888
Hey all - BtSsm model coverage should now extend to the following model years:
05-08 LGT (was 05-06) 06-08 WRX (was 06-07) 04-08 STI (was 04-07) 04-08 FXT (was 04-06) 05-08 OBXT (was 05-06)
__________________
[SIGPIC][/SIGPIC][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT Last edited by BtSsm; 10-22-2014 at 04:36 PM. |
10-25-2014, 10:47 PM | #19 |
Member#: 400888
An update was just published to Google Play:
__________________
10-28-2014, 07:50 PM | #20 |
Member#: 400888
FYI - some have had success using the BtSsm adapter to do RomRaider logging from a laptop (provided that the laptop has bluetooth support, which can usually be added if it doesn't have it already). You need to create an outgoing BT connection from your laptop, pair it with your BtSsm device, assign a virtual com port, then you should be able to use that com port in RR.
__________________
11-03-2014, 10:03 AM | #21 |
Member#: 400888
Happy November!
Announcing a price reduction for the BtSsm adapter: as of today, it is now available for $99 (includes shipping to US). The Android app remains priced at $15 Also, an update to the app is being pushed out to Google Play today. It includes:
__________________
11-13-2014, 01:05 PM | #22 |
Member#: 400888
Just published an update to Google Play (should be available within a couple of hours):
__________________
11-21-2014, 08:46 AM | #23 |
Member#: 400888
An update to the BtSsm app was just published to Google Play.
__________________
11-21-2014, 10:49 AM | #25 |
Member#: 400888
__________________
