05-03-2017, 03:52 PM | #2976 |
Top Scoob 009
Member#: 68273
Vehicle:2012 WRX GD Race Car |
Oh nice, you work for Peterson. We pretty much raided your catalog for this build...tank, primer, heater, inline filter, breather. You make some good stuff! And yes it came highly recommended by Bill Dailey.
05-03-2017, 04:26 PM | #2977 |
Member#: 260314
NESIC
Vehicle:2007 STI silver gray metallic |
05-03-2017, 06:12 PM | #2978 | |
Member#: 97732
RMIC
Vehicle:2004 STi 65 Nova 8.80@151 |
Haha, well that's good to hear! I deal with Bill all the time, hes a sharp guy that's for sure. You'll like his system, it's about as compact and efficient as they come. Last edited by haberkorn; 05-03-2017 at 06:19 PM. |
05-05-2017, 09:24 AM | #2979 | |
Member#: 137548
RMIC
05-05-2017, 11:27 AM | #2980 |
Top Scoob 009
Member#: 68273
Rollin' along this week, not much time left before we load up for Atlanta! Fred got the dry sump tank mounted, as well as the remote filter/primer and new -12AN oil cooler. All of the plumbing is done as well (everything using crimp fittings). The header is wrapped with some really nice stuff from Heatshield Products, which should contain heat better than traditional wrap and it won't absorb oil in the event of a leak. He also got the new turbo plumbing done, redid some fuel lines, and mounted the Radium Engineering surge tank.
I finished mounting the new mirrors, made some blockoff plates for the stock mirror mounting locations, and a few other odds and ends. The body shop took care of a bit of paint work to prep for new graphics going down on Monday. Today, we are on the dyno with Franz Diebold. The car has Ignite Red (114 oct.) in the tank and I'm anxious to see what it will do on this new GTX3582R Gen 2. He will tune the car today, then come back on Monday to finish some wiring and troubleshooting. Graphics will go on, then we have Tuesday to do some final prep before we load up and head off for Atlanta! Any guesses what kind of numbers we'll put down today? |
05-05-2017, 12:28 PM | #2981 |
Member#: 421271
Vehicle:2015 WRX Galaxy Blue Pearl |
That wheel is nuts!
You're at the point where most would put an Arduino in there so you can run it all over CAN. Once you do that you can go full maniac F1 style, put a screen on there and all manner of craziness all with 4 pins. |
05-05-2017, 02:51 PM | #2982 |
Member#: 118334
SWIC
Vehicle:2006 Red GDA-F 2005 Aspen White GDA-E |
I'm going to guess 700whp on the RED. Ignite is no joke!
05-05-2017, 03:05 PM | #2983 | |
Top Scoob 009
Member#: 68273
That's pretty much what I'm hoping for. Franz usually tunes pretty conservatively but I know others have cracked 700 on red on the old GTX3582 so hopefully the gen 2 will hit it without breaking a sweat. I have a feeling we're going to run into some flow restriction up top using the stock intake manifold and no significant head porting. |
05-05-2017, 05:14 PM | #2984 |
Member#: 97732
RMIC
Looks good... Only thing i'd recommend would be a little finer scavenge filter on the return side. The filter you have currently are just designed to mount onto oil pans and are pretty course (1500 micron). Typically we run 100 micron's on the return side of the system to keep the tank clean.
Those are -16 lines? |
05-05-2017, 05:43 PM | #2985 | |
Top Scoob 009
Member#: 68273
05-05-2017, 05:57 PM | #2986 |
Member#: 97732
RMIC
We only make one micron size for that style filter, it's a 1500 micron which is a hole just smaller than an 60 thousandths.
Typically our 400 series filters with a 100 micron and no bypass are used on the scav return lines. I'm talking about the red 90* filter in the first picture attached to the scav return fitting on the tank. Last edited by haberkorn; 05-05-2017 at 06:14 PM. |
05-05-2017, 07:42 PM | #2987 |
Member#: 458149
Are you actually going to run the car at 700whp??
05-06-2017, 12:07 AM | #2988 |
Member#: 71875
Do you have a place for airflow from the radiator to go? If you've noticed the WRC cars with the v-mount setup have ducts dumping air out the sides in front of the wheels.
05-07-2017, 10:42 AM | #2989 |
Top Scoob 009
Member#: 68273
Pretty much yeah.
Not exactly at this point. We experimented with one method last year but it was taking too much downforce off the front end. I have been looking into venting it out the sides of the bumper since there are already exit vents there. |
05-07-2017, 10:43 AM | #2990 |
Top Scoob 009
Member#: 68273
So this turbo is...quite strong. Franz tuned the car conservatively at 30psi since we are hauling about 11 hours and wanted to make sure everything holds together. At that boost level, it made 630whp and 582wtq. He will be at the track with us and he said he has headroom to add in another 5psi, which should be good for close to 750whp! Pretty incredible considering the car has basically stock heads (just cams, +1mm valves, and a valve job) and stock intake manifold. With some head porting and a process west manifold, we could be knocking on the door of 800. I'm going to run the car at 30psi during the Thursday test while I learn the track and the new tires. If I'm consistent and we need a little more lap time, I will consider cranking the boost a bit. I also got a little something to try to gain back some rear downforce since I added what will likely be quite a bit up front. You can see how much larger the Singular endplates are than the ones the wing came with, which should provide a significant downforce gain without adding drag. I will say they were not the easiest company to deal with...it took 2 1/2 months after I ordered and paid to get the endplates and they sent the wrong ones so I had to redrill them. They are going to have a new set made with the correct mounting holes but no idea how long that will take. For now though they look pretty badass! I also got the new steering wheel installed and it looks amazing. Tomorrow, the steering wheel gets wired in and all other wiring and electronics issues get sorted out. The new livery is also being installed tomorrow, then it's wrapping up the final details on Tuesday before we load up for Atlanta! |
05-07-2017, 02:15 PM | #2991 |
Member#: 374688
NWIC
Vehicle:2005 STI WRB |
Your car is inspiring even for us "budget" racers!
05-07-2017, 06:03 PM | #2992 |
Member#: 458149
I went up in endplate as well. The modeled -CL from going up in endplate and no additional drag makes it an easy choice. AJ Hartman was easy to deal with. Bummer on Singular being a pain to deal with.
Made a set of risers for that will allow the wing to go from standard height and up 1 or 2" in overall height. |
05-07-2017, 09:29 PM | #2993 |
Top Scoob 009
Member#: 68273
I thought about getting the endplates from AJ but I'm looking at switching to a top mount wing from him later this season. For now, the singular were a lot cheaper because they're aluminum. Just a shame their customer service isn't better because it's a really nice product.
05-08-2017, 10:44 AM | #2994 | |
Member#: 118334
SWIC
That powerband looks awesome. GTX3076 Gen2 correct? I too am completely stock heads and valvetrain. Also those endplates look solid! I know there are at least 2-3 different hole configurations that Kognition made for the endplates, so I can see the trial/error there. I love my Louver kit from Singular, got that pretty painlessly though. |
05-08-2017, 11:01 AM | #2995 | |
Top Scoob 009
Member#: 68273
There are 2 different hole patterns for Kognition wings but we had a whole conversation back and forth about which one I needed. I will give them credit though, apparently their waterjet shop messed up and cut the wrong ones but they went ahead and sent them to me and will replace them when the new ones are ready. |
05-08-2017, 03:29 PM | #2996 | |
Member#: 118334
SWIC
Nice! At least they are making it right, good on them. |
05-08-2017, 03:41 PM | #2997 |
Top Scoob 009
Member#: 68273
Yeah it's pretty insane, it makes peak torque at right around the same RPM as my 3076 Gen 1 did but it should be capable of 200+ more hp. This is with the 1.01 housing too! The Gen 2 stuff is no joke. If you're happy with your current powerband you should definitely consider giving yourself some more headroom with a 3582 or maybe a 3576.
05-10-2017, 04:53 AM | #2998 |
Member#: 158864
Vehicle:2003 SOHC destroker |
What made you go with the gtx over the new gtw's?
I've been dying to see some more results with the w's |
05-10-2017, 12:10 PM | #2999 |
Top Scoob 009
Member#: 68273
My understanding is that the GTW series is more of a "budget" turbo with a lot of compromises. They are bigger/heavier, less advanced compressor wheel aerodynamics, no fully machined compressor housing, etc. I think they will be good for the budget-minded drag racer or street driver but not ideally suited to road racing.
05-10-2017, 01:55 PM | #3000 | |
Member#: 47143
They are cheaper however they are very impressive in a number of applications. a 62mm 3884 has basically the same spool, slightly different in response to a gen1 gtx3582 but makes a lot more power. We have used them on a number of different cars/engines and they are a great option. Used in racing as well and they are great. Last edited by blurred; 05-10-2017 at 03:38 PM. |
Turn in Concepts 2010 Track Car Build | Turn in Concepts | Press Releases | 374 | 12-30-2016 02:06 PM |
My GC Race car build | rrsettgast | Member's Car Gallery | 3 | 04-27-2010 12:19 PM |
Came out to my car... belt on the ground and this (pic). | Padge | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-11-2009 10:36 PM |
Getting my car closer to the ground | BluScopion | Vancouver Impreza Club Forum -- VIC | 12 | 02-02-2007 02:30 AM |
got car back from the shop, now lights are messed up | X2.5RS01X | New England Impreza Club Forum -- NESIC | 1 | 02-21-2005 09:41 PM |
