07-08-2011, 01:11 AM | #1 |
Member#: 280963
Vehicle:2005 92xaero desert silver |
Total noob on washing engine bay
Need some input on how to correctly clean your engine . Do I spray the engine down 1st? If so what can I not wet? I hear simple green and a tooth brush work the best. Thanks for the help!
07-08-2011, 01:44 AM | #2 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
cover your air filter if it's open.
Spray the rest of that **** down. Simple Green and a brush. Dress plastic if desired. Done. |
07-08-2011, 12:29 PM | #3 |
Member#: 191070
NESIC
Vehicle:05 WRX STi OBP |
07-08-2011, 08:36 AM | #4 |
Member#: 274345
MWSOC
Vehicle:2011 STI 5dr WRB |
^^ This. Just did it last night...you will be surprised how awesome it works.
Also, sometimes if the bay is super dirty, it's best to let the simple green soak in for a bit to really penetrate through the muck that's on there. |
07-08-2011, 10:41 AM | #5 |
Member#: 217405
MAIC
Vehicle:2006 WRX |
Add do not blast the alternator with H2O to Xan's list.
07-08-2011, 11:50 AM | #6 |
Member#: 274345
MWSOC
07-08-2011, 12:07 PM | #7 |
Member#: 217405
MAIC
Vehicle:2006 WRX |
Driving in the rain and shooting pressurized water into it are 2 different things. Besides it is covered so most rain water is deflected or rerouted anway.
07-08-2011, 12:26 PM | #8 |
Member#: 252910
I would put a plastic bag over it and an exposed aftermarket air filter just to be certain and hose the rest of that sucker down!
07-08-2011, 12:57 PM | #9 |
Member#: 119219
MAIC
Vehicle:2005 STi WR Blue |
If you run the engine while spraying water on it you will find out pretty quick what can't get water on it. If you do though, don't run the engine long enough to get hot, which isn't long. You should never spray any cleaner on anything hot especially your engine. Basic engine rule is stay away from all electrical components to include wiring/connectors. Be careful using any APC/cleaner undiluted on your engine especially rubber/plastic, and never on bare aluminum. Follow the manufacturer's recommended dilution mix for the job at hand. Only spray a direct stream of water where it really needs like oil/grease build up areas. A little APC and some mild scrubbing/agitation works better than straight blasting with water. If in doubt keep the water away; take the time to cover things using al foil, plastic bags, and tape. Avoid getting any undiluted APC on the paint and headlights, and any cleaner you get on the paint/hdlts make sure you rinse off immediately or wipe with a clean, wet microfiber clothe. To dry your engine without starting it and possibly getting steam build up into electrical connection or loose seals on things like headlights, use the blow side on a shop-vac and wipe things down with a towel to avoid water spotting especially on the rubber, plastic, bare al/metal, and non-clear coated paint under the hood. If you dress the engine use a true protectant for the surfaces your are dressing. 303 Aerospace Protectant is great because it's non silicone based so it won't attract dirt and build up like armor-all type sprays. Dressing the motor, or any other area for that matter isn't just for looks. It keeps the material from deteriorating from heat/dirt buildup. Recommend using a spray detailer/spray wax on the painted surfaces to brighten them up and give a little protection as well. Spray detailers/waxes/sealants can be sprayed on during the drying step to save you time and help reduce marring the paint/glossy surfaces and make drying easier/faster usually. To clean the fire retardant material attached to the underside of the hood, spray a mild cleaner onto a damp cotton terry clothe and dab the fire retardant material taking care not to rub hard. Whatever you do don't soak the stuff then scrub it and pull at it. There are cleaner designed for cleaning electrical components like connectors and electric motors; you can find them on autogeek.net that I know of.
Have fun and be safe. |
07-08-2011, 02:36 PM | #10 |
Member#: 41986
NWIC
Vehicle:'06 STI/'85 Brat |
07-08-2011, 02:28 PM | #11 |
Member#: 280963
Thank you all for the input. Sounds like I got a fun project this weekend.
07-08-2011, 02:38 PM | #12 |
Member#: 184977
South East
Vehicle:99 Impreza RS '13 BRZ |
I cover the filter and purple power the **** out of everything and hose it off. Make sure to have the car aiming toward the sun when you start. Once you are done leave the hood up for an hr or so and let the sun dry up the remaining water
07-08-2011, 03:21 PM | #13 |
Member#: 119219
MAIC
Great point. Just make sure that you take it out of the sun and let the eng bay cool before applying any dressings/protectants, as to prevent streaking.
07-11-2011, 05:41 PM | #14 |
Member#: 204304
MWSOC
Vehicle:2008 WRX 4D Stage 2 Silver |
07-11-2011, 09:40 PM | #15 |
Member#: 264877
Disclaimer - POTENTIALLY it MAY harm your engine. I am not responsible, etc.
Now, seriously, some say that washing a motor is bad and that it could cause damage to the electronics. I have washed my share of motors and never had a problem with electronics, wiring, failing parts, slipping belts, etc. If you're stupid about this I'm sure there's a way to kill the motor, but otherwise you're golden. You drive a car with a big whole in it anyways... Thing you need: Degreaser (Non-acidic cleaner preferrably. Won't harm metals) Brush (for Agitating) Towels (Cloth or paper) Process; Start: 1)With the engine cold/slightly warm at best (we don't want warping) lightly spray the motor. Some prefer to cover the alternator, battery, or other sensitive areas. If you want (I never do and I never have a problem) cover it with plastic wrap. 2) Apply cleaner, being agitating with brush. 3) Rinse off with hose. Use low pressure and avoid sensitive areas (if uncovered, don't drown the alternator for example. Getting it wet is fine, but don't spray it for 5 minutes on full blast). 4) Wipe excess. Use a towell or brush to wipe off the motor and any standing water. Good for removing water from plug holes, belts, etc. 5) Optional - Engine Dresssing. Some prefer to spray the engine with a dressing that will keep it shiney and protect it. I've used CD2 engine cleaner and I liek it (follow direction) but it was nice just to clean the motor honestly. I like the bare OEM look, and it's nice to not have to wipe my hands when touching my motor. If you choose, usually it's spray it on a cold engine and turn the motor on to bake it it (it's a resin). Then wipe excess away. 6) Clean-up. Spray/clean the dirt spot on the drive that you will have. |
07-13-2011, 03:47 AM | #16 |
Member#: 285333
simply use green or aluminium cleaner or polish.
07-13-2011, 09:00 AM | #17 |
Member#: 1026
MWSOC
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
Jus beware of high pressure water, use the low pressure setting at the CW or stand back a ways... the engine is pretty well sealed, besides the obvious... but it's not sealed for typhoon pressures.. lol..
Similar Threads | ||||
washed engine bay, now car won't start CEL on | pinoy_boy204 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 42 | 06-08-2010 09:12 AM |
changed oil, washed engine bay... EGT not working now?! | Rallye-fan | Electrical & Lighting | 0 | 12-31-2006 02:08 PM |
noisy pulley after washing engine bay | kiwee | Transmission (AT/MT) & Driveline | 4 | 08-07-2006 09:02 PM |
washing engine bay | 949 | Interior & Exterior Modification | 1 | 08-29-2005 12:35 PM |
Washing Engine Bay? | Inprogress | Texas Impreza Club Forum -- TXIC | 14 | 08-07-2005 11:17 PM |
