Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 02-15-2018, 03:11 PM   #1301
shadowfax028
Member#: 470623
I used the Whiteline to hats with camber bolts. I can get as much as -3.2
shadowfax028 is offline   Reply With Quote
Old 02-16-2018, 10:13 AM   #1302
Robin2
Member#: 390
2018 WRX sedan
Dark Grey
when it comes to brake pads, what is everyone using? the OE pads are decent on my 18wrx but lacks a bit of the bite that i'm used to previous car 11wrx with hawk hp+.
as much i despised the hp+ noise especially on light braking, they were pretty good for autox and able to brake harder in later areas of the autox course.
i'd love to get some ferrodo 2500s pads for my 18.
what's the consensus for other regular autox?
plans for this year
- bridgestone re71's
- proper alignment
- brake pads
that's it..... getting to be old timer at autox..... nearing 20 years attending autox events.
Robin2 is offline   Reply With Quote
Old 02-16-2018, 12:01 PM   #1303
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
i was going to get ferodo ds2500s but they are fairly expensive and my stoptech sports are enough to lock up the tires anyway
_brian_ is offline   Reply With Quote
Old 02-16-2018, 12:58 PM   #1304
Robin2
Member#: 390
2018 WRX sedan
Dark Grey
good info on sports as sports are much cheaper. i'll talk to local dealer.
this could be a good option.
Old 02-17-2018, 12:33 PM   #1305
jprice130
Member#: 288225
2014 BRZ
Since the conversation has moved to brake pads, I figured I'd put in another plug for my Carbotech AX-6 pads. No reasonable offer refused; just looking to get them out of my garage and help out a fellow autocrosser.
EDIT: SOLD!!
jprice130 is offline   Reply With Quote
Old 02-19-2018, 06:44 PM   #1306
Sean Dickinson
Member#: 448675
2016 WRX
How would you guys go about creating a little more rotation mid corner and on exit on a fully built autocross WRX?
I just feel like I'm leaving so much on the table when it comes to steady state cornering, as well as exiting corners. I know the goal is to brake as late as possible, rotate and aim straight out, but if I go too hot into a corner, I push pretty hard on the RE-71's. If I'm 10% more gentle, it turns in quite well, but it looks like from my videos the only fast areas are when the turns are point and shoot. Also as soon as I get on the throttle, the thing just goes straight, even with all that traction. Do you guys think this could be solely due to rebound adjustments on my coilovers, or is there something else any would try?
Please ignore the first cone on the track. Accelerated too hard on what was supposed to be a 44.xxx run, but that run was still by far my fastest everywhere else.
Sean Dickinson is offline   Reply With Quote
Old 02-19-2018, 08:37 PM   #1307
hackney1
Member#: 391014
'18 Prem. Perf Pkg
ISM
https://www.youtube.com/watch?v=-zhkmwH6b94
One of the excellent wrx drivers I know recommends up to 50psi in the rear to help rotation.
A number of drivers have high speed accelerometer recording/replay. This looks like the way to go as they can easily compare different approaches to a given turn.
hackney1 is offline   Reply With Quote
Old 02-26-2018, 07:08 PM   #1308
killadawg
Member#: 424203
2016 WRX stage 3
STI Drivetrain swap GM
Qstarz LT-6000S GPS Lap Timer is a great one If you are serious and want to improve your game on the track.
killadawg is offline   Reply With Quote
Old 06-03-2018, 05:22 PM   #1309
Charles33579
Member#: 469862
How do we keep the rear tires on the ground? Biggest front bar I can find ?
Charles33579 is offline   Reply With Quote
Old 06-06-2018, 11:04 AM   #1310
mulkio
Member#: 463697
2017 WRX
CBS
I would think it would help some, but with a trade off of less rotation and some push in tight elements. I try to mitigate wheel lift with a quick stab of steering wheel input to set it back down. Mind you I run a rear bar full stiff, but have thought about setting it on the middle setting to reduce the tail happy handling on my car.
mulkio is offline   Reply With Quote
Old 06-07-2018, 10:24 AM   #1311
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
We campaigned a 2016 WRX with Performance Pack Nationally last season and ran the Eibach front bar on the low setting IIRC. Co driver and I won a couple of tires at a few National Events (Bristol, Pittsburgh, Toledo) in DS but got crushed in Lincoln (15th and 16th). The other fast guys were running rear bars which I think worked better in Lincoln but we had some other issues that cost us time too.
The front bar will make it slalom/transition like a champ but you'll notice some push in sweepers and tighter elements.
gti_speed is online now   Reply With Quote
Old 06-08-2018, 12:08 PM   #1312
mulkio
Member#: 463697
2017 WRX
CBS
I agree wholly, with the rear bar my car feels vague in slaloms. On a side note, can I ask what tire brand and the psi you used? My re71 are wearing down the center ribs more then the outside edge. I have been running 33f/31r and swapping front to rear between events. Any input appreciated!
Old 06-09-2018, 12:36 AM   #1313
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
We ran BFG Rival S 1.5 in a 245/40/18 on the 8.5" wheels that came on the Premium 2016's. Target hot pressure was 34F and 36R. We also put STI dampers on the car.
Old 06-11-2018, 09:26 AM   #1314
Wrx16prm
Member#: 431411
Do you get much rollover on the front or rear tires with those pressures? I've been running Direzza ZII's in the same size as your tires with 40F and 42R. I get roll over on the front tires to just past the tip of the triangles and no rollover on the rear at all. The car seems fairly well balanced at those pressures, but I wouldn't mind a little more traction all around. My car is a 2016 premium and it is completely stock.
Wrx16prm is offline   Reply With Quote
Old 06-13-2018, 02:18 PM   #1315
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
I don't have any experience with the Z2's but I never ran pressures that high with RE71R or BFG on either the 15+ STI or 15+ WRX.
I'm not an engineer but here are my thoughts. In stock trim you are extremely camber limited in the front at -1.5max. The tire is going to roll no matter how much pressure you are going to put in it. Why not try to maximize that patch with less pressure?
Also the rear is just along for the ride. I'd experiment more with lowering the front. Maybe try to shoot for 35 hot and see how it goes and keep the rear around 40 hot?
Also get better tires...
