Welcome to the North American Subaru Impreza Owners Club Saturday November 18, 2017
Old 11-14-2017, 11:51 PM   #7151
amore93
Member#: 454298
17 WRX
Lapis Blue Pearl
Originally Posted by alvinli217 View Post
It will fit, I had this setup on stock suspension before
265 on 18x9.5 +38 will rub a little of the rear bumper corner close to the fender under hard corning, 255 should not rub at all since it's stretched a little bit on 9.5 inch rims
here are two photos of my car with 18x9.5 +38 on 265 cup2 tires with stock suspension
Would rolling the fenders completely solve this or would that not be enough?
amore93 is online now   Reply With Quote
Old 11-15-2017, 04:11 AM   #7152
Balishag
Member#: 94409
2015 STI
Originally Posted by CV888 View Post
what tire pressure are you running?
I think about 35 psi?
Balishag is offline   Reply With Quote
Old 11-15-2017, 11:33 AM   #7153
Lansonfloyd
Member#: 476167
I'm batting around the idea of the Fast FC04, given the pretty decent exchange rate from US to CAD these days, the style, concavity, and lightness of the wheel, etc. But I'm waffling between the tried-and-true 18x9 +40, vs the 18x10 +45. By www.willtheyfit.com research, the outer poke will be about a mm less than the ubiquitous 18x9.5 +38, however I'm mostly concerned about inner poke. I have zero plans to use coilovers, but I do think some mild lowering springs will be in my future. I want to use a 265/35-18 or push for a 275-35-18, if it will let me. Given that, is the 18x10 +45 worth the slight bit of extra weight? I wonder.
Its either those, the Wicked Awesome wheels, or the NT03+M in 18x9.5 +40 for me I think.
Lansonfloyd is online now   Reply With Quote
Old 11-15-2017, 09:51 PM   #7154
alvinli217
Member#: 133236
2016 WRB STi
04 WRB STi-GONE
It's actually not the fender rubbing even though I did roll it just in case i rub at the track.
it's the rear bumper portion close to the fender that's rubbing, i just used a grinding tool to trim a bit of the bumper off(like few mm) and fixed the rubbing issue
alvinli217 is offline   Reply With Quote
Old Today, 01:46 AM   #7155
amore93
Member#: 454298
17 WRX
Lapis Blue Pearl
Any chance you could show a picture?
