Welcome to the North American Subaru Impreza Owners Club Thursday February 22, 2018
Old 10-30-2012, 08:58 PM   #1
twistedmentality
Member#: 276600
2006 impreza 2.5i
Default Common Problem ? Valve Cover Gasket Leaking Causing Misfire
is it common for a valve cover gasket to leak around the spark plug causing oil to foul out the plug ?
my car was shuddering and spitting yesterday and i took it to the mechanic. read the codes and took the boot off of plug 3 and it was full of oil. he said it was a common problem with cars that had recessed plugs.
wondering what you guys thought.
thanks.
twistedmentality is offline   Reply With Quote
Old 10-30-2012, 11:44 PM   #2
KelConquer
Member#: 321498
1998 Legacy W. EJ25
It can happen, it was one of the troubleshooting things I went through to find out why my #4 was misfiring, bought new spark plugs and gasket all ready to do the job but under inspection there was no oil on my plugs so since i'd already gotten all of the supplies I replaced both valve cover gaskets anyways, including the gaskets that go around the spark plugs themselves. Chances are one of the gaskets around your plugs is letting oil onto the plug. The job can be done yourself with patience, some of the bolts are hard to get to depending on what side you'll be working on..
KelConquer is offline   Reply With Quote
Old 10-31-2012, 12:10 AM   #3
twistedmentality
Member#: 276600
2006 impreza 2.5i
i was quoted 300.00 for the job. thats from a local shop my brother in law is in partners with so i trust them but dont get no break on prices...
id take it to Ramono where i got it but i know they will be even more expensive ( i see your from Syracuse, i live in Auburn)
Old 11-02-2012, 03:36 PM   #4
evilWagon
Member#: 128739
Check out the DIY thread, I added information specific to the 06/07 after I did mine, because of the design of the AVLS systems in our cars you have to disconnect the engine mounts and raise the engine to have enough clearance to remove the driver side cover and do a proper job. The passenger side is easy enough to get off with the engine still in place but a paint to get back in place while keeping the gasket where it should be. I failed the first time, it shifted and got pinched and started leaking oil on startup.
You CAN do it yourself with some basic tools, time and patience though. The 3M gasket glue is awesome as well but it's $$.
evilWagon is offline   Reply With Quote
Old 11-02-2012, 05:47 PM   #5
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Happened on mine. Passenger side went first. Took 45 min to replace gasket and tube seals...$35 in total for parts.
treksofar is offline   Reply With Quote
Old 11-04-2012, 01:11 AM   #6
twistedmentality
Member#: 276600
2006 impreza 2.5i
hmmmm, i was told 3 hours.
Old 11-04-2012, 01:30 AM   #7
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
It takes a while to do the gaskets on both sides at home. You will need to raise the engine up quite a bit to ensure enough clearance to get the coves off and on without compromising the new gaskets positioning.
I bought the OEM Subaru kit over the FELPRO kit even though is cost more. $300 isnt that bad, I was quote $470 to do the gaskets and adjust the valves so rather than risk it ill probably go that route.
GEE-OTTO is offline   Reply With Quote
Old 11-05-2012, 12:52 AM   #8
twistedmentality
Member#: 276600
2006 impreza 2.5i
well it should be done monday. ill let ya know how it went.
Old 11-05-2012, 01:27 PM   #9
07RezaWagon
Member#: 291657
2007 2.5i Wagon
CGM
The passenger side gasket went on my 07 with 75k miles.. it was only like 35 bucks for the gasket kit at oreilly and an hour of wiggling the cover off and back on.
07RezaWagon is offline   Reply With Quote
Old 11-05-2012, 03:29 PM   #10
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Easy to do it yourself. Just need small hands and time. $300 is crazy to pay.
Old 11-06-2012, 03:45 PM   #11
twistedmentality
Member#: 276600
2006 impreza 2.5i
well its all finished. working well. with the weather crappy here and the fact they had to jack the engine im glad i had it done by a shop.
Old 11-13-2012, 02:15 PM   #12
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Adjust your valves while in there if you have an SOHC car.
I heard "They are noisy engines, no worry" millions of times. My exhaust valves were 2x+ what they should have been and intakes were way out of spec too.
Gained a bunch of power and lost a bunch of misfires from the newfound seal as well as the proper valve lift and timing.
gdoggmoney is offline   Reply With Quote
Old 04-16-2014, 05:11 PM   #13
teledan73
Member#: 387956
1999 Impreza Outback
I know this thread is old but I am having similar symptoms with my 99 Impreza Outback Sport. The car seems to run fine around town but I have noticed that if I drive on the freeway for a little while, the car starts running rough and eventually the check engine light will come on. The other day this happened to me so I pulled over and looked under the hood and one of the spark plug boots had come out! So I pushed it back in and it popped in nice and tight and the car ran fine. A little while down the road the same thing happened so I popped the hood and sure enough, the spark plug boot had popped back out! I pushed it back in and made sure it was in there tight, I would have to pull pretty hard to get it back off so I pushed it back in and kept going and the same thing happened maybe 6 or 7 times before I got home! I also noticed a small bit of oil on the spark plug boot. Here is my theory. I am thinking I have a leak in the spark plug seal and/or valve cover gasket and the blow by or pressure from the motor is popping the spark plug boot out when the car is revving high for an extended period of time. Does this sound crazy? or even possible? I think I am going to replace the valve cover gaskets and spark plug tube seals anyway because I have a small leak in the valve cover gasket, but has anybody ever heard of this sort of thing happening?
teledan73 is offline   Reply With Quote
