Welcome to the North American Subaru Impreza Owners Club Tuesday October 23, 2018
Old 11-01-2009, 02:56 PM   #1
PhDinOMG
Member#: 221264
2002 WRX Sedan
Default 2.5L DOHC '99 Legacy Engine into 02 wrx
I found this engine on craigslist and ive been wanting to rebuild an engine and put it in my car. ive done some research and from what ive read this engine is not intercooled but i dont know if its turboed. would it be beneficial to put this into my car (cause it is a 2.5)? i havent found any threads that talk about putting an older engine in a newer car
thanks
PhDinOMG is offline   Reply With Quote
Old 11-01-2009, 03:14 PM   #2
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
a 2.5 legacy motor will be slower than your turboed 2.0. idn how the swap would go, if you want the legacy motor in there till your 2.0 is built..?? but if that whats your doing sounds like a hassle.. get another 2.0 or a 2.5 sti short block and start building that and swap for ur oem engine when its built
dirtbikeridr12 is offline   Reply With Quote
Old 11-01-2009, 04:38 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's not really worth buying. There is not much from a 99 2.5 that you could use in your wrx. The heads and intake manifold are not compatible with your ECU. This is the noob section so I won't go into why, but trust me, it won't work. You could use the shortblock but the compression would be on the high side of what you'd want with a turbo. So again, really not worth buying for what you want to do with it.
Old 11-01-2009, 09:44 PM   #4
2Slow4You
Member#: 213743
2003 Svt Cobra
from what i understand you would be better off just buying a sti short block, reusing your wrx heads...and if you decide to upgrade later you'll get more power/torque from the same mods than you would compared to your stock 2.0l.
Correct me if I'm wrong, just my .02.
2Slow4You is offline   Reply With Quote
04 engine into 02 wrx help please 2002subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-16-2009 11:34 PM
95 2.2L Legacy to 98 2.5L DOHC EastsideLegacy Subaru Conversions 32 01-29-2009 06:57 PM
usdm sti engine into 02 wrx wrxracer55 Subaru Conversions 7 10-25-2004 01:22 PM
2.5L DOHC engine darioc Private 'For Sale' Classifieds 13 06-20-2004 10:55 AM
WTB: Phase I 2.5L DOHC engine. solomrus Private 'Wanted' Classifieds 2 01-10-2004 12:28 PM
