06-19-2017, 01:47 PM | #51 |
Vendor Sales Rating: (7)
Member#: 228856
South East
New ML700+ spec closed deck block!! Thanks, Alex
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] |
06-20-2017, 11:28 AM | #52 |
Member#: 228856
South East
Manley Performance products used exclusively for our engine program! Thanks, Alex
__________________
06-21-2017, 10:59 AM | #53 |
Member#: 228856
South East
The BEEFY Manley H-Tuff rod featured in our popular ML500+ never disappoints for the 425-550WHP builds. Thanks, Alex [email protected]
__________________
06-22-2017, 03:25 PM | #54 |
Member#: 228856
South East
Contact us with any questions you might have about our built engine assemblies! Thanks, Alex [email protected]
__________________
06-23-2017, 11:07 AM | #55 |
Member#: 228856
South East
Motion Lab Stage II spec shortblock for one lucky customer ready to go. Featuring a closed deck case, Manley Performance Products, Inc. pistons and rods, King Racing XPG main and connecting rod bearings, and a new OEM crankshaft. Not to mention it looks super cool. Thanks, Alex [email protected]
__________________
06-26-2017, 12:08 PM | #56 |
Member#: 228856
South East
The beautiful Manley Performance "TurboTuff" I-Beam connecting rods are used on our ML700, ML700+ Closed deck, and ML1200 spec engines. This 1000+HP rated rod will give you the reliability you are looking for from either a factory semi-closed deck case, closed deck converted case, or LA Sleeve ProCross ProCool sleeve upgraded case! Thanks, Alex [email protected]
__________________
06-29-2017, 10:13 AM | #57 |
Member#: 228856
South East
Sleeved ML700 spec engine about to get some Stage 2 heads bolted to it! Thanks, Alex [email protected]
__________________
07-11-2017, 10:02 AM | #58 |
Member#: 228856
South East
ML700 Plus Closed Deck shortblock: The ML700+ offers superior strength over our standard ML700 spec engine by upgrading the factory cylinder block with a closed deck conversion. For the ML700+ we utilize the same high quality Manley Performance “TurboTuff” components that we do in the standard ML700 engine. It offers their 1000HP rated “TurboTuff” rod set forged from aircraft quality 4340 degassed material. Each rod is shot peened and magnafluxed after final machining. In combination with the “TurboTuff” rods we are using the latest “TurboTuff” piston design as well superior to the traditional “Platinum Series” pistons found on our ML500 and ML500+ spec blocks. By incorporating proven design enhancements from their “Formula-Won” strutted piston forging they have created the ultimate piston for your Subaru. Like their “Platinum Series” pistons these feature a off-set wrist pin, TotalSeal ring pack, chromoly 2.500x.180 premium wrist pins, and anti-friction skirt coating right out of the box. Fully blueprinted and assembled to our strict specifications using King XPG Race bearings in a clean climate controlled facility.
Recommended Power: Up to 800whp - Manley Performance “TurboTuff” 4340 Forged I-Beam Rods - Standard ARP2000 Rod Bolts - ML-Spec King XPG Race rod bearing clearances - Manley Performance “TurboTuff” 2618 Forged Pistons - Choose 8.5:1 (or) 9.8:1 Compression Ratio - Anti-friction skirt coating - Off-set wrist pin - “Formula-Won” strutted piston design - Thicker skirt wall versus traditional “Platinum Series” piston design - Standard Chromoly Wrist Pin (2.500”x.180” wall) - New Subaru OEM Factory Block - Closed deck conversion - Bored and honed to 99.75MM - Seal kit can be purchased separately (Seal kit includes: 3x wrist pin plugs, 3x wrist pin plug washers, 1x separator cover, 6x separator cover bolts, 1x wrist pin service cover, 1x wrist pin service cover O-ring, and 2x wrist pin service cover screws) - New Subaru OEM Induction Hardened Crankshaft - ML-Spec King XPG Race main bearing clearances Customer to pay extra for shipping. Please call or email to arrange installation or local pickup. Thanks, Alex [email protected]
__________________
07-13-2017, 11:58 AM | #59 |
Member#: 228856
South East
ML1200 spec block with copper o-ring and 1/2" head studs getting assembled to make some power! Thanks, Alex [email protected]
__________________
07-14-2017, 10:04 AM | #60 |
Member#: 228856
South East
ML700+ Spec closed deck block going together with ARP 2000 head studs and Cosworth 1.1mm head gaskets. Ready for our Stage 2 heads with Kelford 220-C cams! Thanks, Alex [email protected]
__________________
07-17-2017, 05:40 PM | #61 |
Member#: 228856
South East
ML700 Plus Closed Deck shortblock: The ML700+ offers superior strength over our standard ML700 spec engine by upgrading the factory cylinder block with a closed deck conversion. For the ML700+ we utilize the same high quality Manley Performance "TurboTuff" components that we do in the standard ML700 engine. It offers their 1000HP rated "TurboTuff" rod set forged from aircraft quality 4340 degassed material. Each rod is shot peened and magnafluxed after final machining. In combination with the "TurboTuff" rods we are using the latest "TurboTuff" piston design as well superior to the traditional "Platinum Series" pistons found on our ML500 and ML500+ spec blocks. By incorporating proven design enhancements from their "Formula-Won" strutted piston forging they have created the ultimate piston for your Subaru. Like their "Platinum Series" pistons these feature a off-set wrist pin, TotalSeal ring pack, chromoly 2.500x.180 premium wrist pins, and anti-friction skirt coating right out of the box. Fully blueprinted and assembled to our strict specifications using King XPG Race bearings in a clean climate controlled facility.
Recommended Power: Up to 800whp - Manley Performance "TurboTuff" 4340 Forged I-Beam Rods - Standard ARP2000 Rod Bolts - ML-Spec King XPG Race rod bearing clearances - Manley Performance "TurboTuff" 2618 Forged Pistons - Choose 8.5:1 (or) 9.8:1 Compression Ratio - Anti-friction skirt coating - Off-set wrist pin - "Formula-Won" strutted piston design - Thicker skirt wall versus traditional "Platinum Series" piston design - Standard Chromoly Wrist Pin (2.500"x.180" wall) - New Subaru OEM Factory Block - IAG Performance "Stage 4" Closed deck conversion - Bored and honed to 99.75MM - Seal kit can be purchased separately (Seal kit includes: 3x wrist pin plugs, 3x wrist pin plug washers, 1x separator cover, 6x separator cover bolts, 1x wrist pin service cover, 1x wrist pin service cover O-ring, and 2x wrist pin service cover screws) - New Subaru OEM Induction Hardened Crankshaft - ML-Spec King XPG Race main bearing clearances Customer to pay extra for shipping. Please call or email to arrange installation or local pickup. Thanks, Alex [email protected]
__________________
07-19-2017, 03:31 PM | #62 |
Member#: 228856
South East
__________________
07-25-2017, 10:05 AM | #63 |
Member#: 228856
South East
__________________
07-31-2017, 03:59 PM | #64 |
Member#: 228856
South East
Another PTE 6466 beast getting wrapped up with a ton of Radium Auto products and a ML700+ spec shortblock and Stage 2 heads! Thanks, Alex [email protected]
__________________
08-16-2017, 09:35 AM | #65 |
Member#: 228856
South East
The Manley H-Tuff connecting rod used on our ML500+ and ML700 closed deck block comes standard with ARP2000 rod bolts. Lightweight and strong, perfect for mid frame turbos like the Garrett GTX35r or smaller. Thanks, Alex [email protected]
__________________
08-18-2017, 11:35 AM | #66 |
Member#: 228856
South East
Nice 440WHP Cobb 20G with Flex Fuel setup running our ML500+ engine and Stage "0" cylinder heads. Thanks, Alex [email protected]
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 08-18-2017 at 12:01 PM. |
08-21-2017, 11:35 AM | #67 |
Member#: 228856
South East
Our Stage II FA20 block features a closed deck reinforced block for higher horsepower capability. Block reinforcement on the new FA20 open deck engines is even more important than the old EJs! Thanks, Alex [email protected]
__________________
08-23-2017, 10:50 AM | #68 |
Member#: 228856
South East
ML500+ uses a factory block with upgraded Manley performance 2618 forged pistons and 4340 forged "H-Tuff" connecting rods. Thanks, Alex [email protected]
__________________
08-29-2017, 11:37 AM | #69 |
Member#: 228856
South East
Nearly 550WHP on pump gas, not too bad! ML700 spec shortblock with stage 2 heads and a ETS 6466 rotated turbo kit makes it easy. Thanks, Alex [email protected]
__________________
09-01-2017, 11:57 AM | #70 |
Member#: 228856
South East
Sleeved block with Manley TurboTuff rods and pistons, GTX3582r, and some lumpy Kelford cams. Thanks, Alex [email protected]
__________________
09-05-2017, 12:35 PM | #71 |
Member#: 228856
South East
__________________
09-06-2017, 12:07 PM | #72 |
Member#: 228856
South East
__________________
09-07-2017, 09:39 AM | #73 |
Member#: 228856
South East
__________________
09-08-2017, 11:10 AM | #74 |
Member#: 228856
South East
__________________
09-12-2017, 10:45 AM | #75 |
Member#: 228856
South East
__________________
