Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 07-19-2005, 12:34 AM   #1
peterex
Member#: 27021
2015 WRX
Default Fuel filler neck question
A stupid question:
Does the little drain hole in the fuel filler neck go straight to the gas tank?
I'm adding a couple ounces of GTA Fuel Enhancer to my gas, and the spout doesn't quite fit in the fuel door. Is it OK if I pour into the fuel filler neck and it drains down that little bitty hole?
Thanks!
peterex is offline   Reply With Quote
Old 07-19-2005, 04:20 AM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
No, it drains out spillage.
Ken is offline   Reply With Quote
Old 07-20-2005, 03:49 AM   #3
peterex
Member#: 27021
2015 WRX
I'm talking about the small hole that's behind the gas cap - i.e. it's at the bottom of the filler tube, and you can only see it when the gas cap is off. That drains out spillage? Where? I don't see anything dripping under the car. I thought it goes back into the tank. Pardon my ignorance.
Thanks.
Old 07-20-2005, 01:11 PM   #4
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
The one INSIDE the neck goes into the tank. The one that drains on the ground is still visible when you close the cap.
JimBlake is offline   Reply With Quote
Old 07-20-2005, 01:37 PM   #5
peterex
Member#: 27021
2015 WRX
^^ bingo, that's what I thought. Thanks!
Checking/replacing a fuel filler neck on a 98 Leg GT Ender81 Normally Aspirated Powertrain 0 03-06-2009 03:13 PM
fuel filler neck leaking yUraBuS Normally Aspirated Powertrain 3 11-30-2006 12:28 PM
fuel filler neck '00RS sedan byroll01 Private 'Wanted' Classifieds 0 10-03-2006 10:25 PM
wtb-fuel filler neck dave_t Canada Region Private Classifieds 2 09-29-2006 06:05 PM
removing a fuel filler neck from a '95-ish legacy wagon alacrity024 Off-Topic 2 08-29-2006 10:18 PM
