Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 01-31-2001, 02:14 PM   #1
H1
Member#: 3083
1997 Miata M-Edition
Green
Post
I haven't tried it myself, but I saw this in the instructions:
NOTE: sometimes they are still taped over with some small amount of plastic tape, so look hard, they will be there!
H1 is offline
Old 01-31-2001, 02:16 PM   #2
Fred Fredburger
Member#: 2539
Post
Yeah, I read that too so I spent about half an hour last night under my dash digging for it and I couldn't find anything resembling it. The instructions are from Australia (RHD models), but I'd imagine if I found 3 of the plugs the 4th one is around somewhere.
Fred Fredburger is offline
Old 01-31-2001, 02:42 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Post
If you find it too, let me know! I looked and looked and looked -- couldn't find it! Green yes, black no.
LaterZ!
Darren!!
Penphoe is offline
Old 01-31-2001, 02:44 PM   #4
Fred Fredburger
Member#: 2539
Post
Penphoe> Did you have the guts to try the procedures with only the green connectors connected? What year is your RS?
Old 02-01-2001, 12:43 AM   #5
Fred Fredburger
Member#: 2539
Question Can't find one ECU Check Connector...
According to the ECU Reset instructions at MRT they say to locate the 2 male/female sets of ECU Check Connectors under the dash (one small green set and one larger black set), hook them together, depress gas pedal to floor for a few seconds, start car and drive for > 1 minute at > 11Km/h and your check engine light will flash "all clear" (1/2 second interval flashes). I like this ECU reset better than the "unplug the battery for a while" because it gives more feedback. I found all connectors under the dash except the black female connector. The other 3 connects are all in the same branch of the wire bundle under the dash but I can't find the last one. Anyone ever use this ECU reset technique? Oh, BTW, I've got an '01 RS Sedan.
Old 02-01-2001, 10:31 AM   #6
Fred Fredburger
Member#: 2539
Post
B U M P
Old 02-01-2001, 10:56 AM   #7
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
The other way is to get a OBDII scantool.
ANZAC_1915 is offline
Old 02-01-2001, 10:58 AM   #8
Fred Fredburger
Member#: 2539
Post
Where would I get one of those and how much would one set me back?
Old 04-04-2001, 09:26 AM   #9
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Post
Anyone know how to do the MRT ecu reset for an 01?
MagicMT is offline
Old 04-04-2001, 09:34 AM   #10
Fred Fredburger
Member#: 2539
Post
MagicMT> Aside from pulling a battery cable (which I hate using as an ECU reset because it provides no feedback if it worked or not), I still haven't found the 4th ECU Check Connector under the dash. Someone mentioned using an OBDII unit, but I've checked some OBD websites and they don't mention having an ECU reset function (www.obdii.com, www.obd2.com, etc).
Good luck!
HTML code is On
Can't find my reflash connector plug KAX Electrical & Lighting 0 04-19-2007 01:39 PM
HELP! Can't find the ECU pinout in my service manual NicFunkadelic Electrical & Lighting 2 04-05-2006 10:18 PM
Looking for a hand pump to fill the rear diff. Can't find one anywhere! Wagon Joe Transmission (AT/MT) & Driveline 6 07-15-2005 08:06 AM
Reset ECU -can't find it :( ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-24-2002 07:36 PM
