Tire & Wheel Forum sponsored by The Tire Rack |
12-17-2016, 04:35 PM | #5476 |
Member#: 355848
Vehicle:2006 Subaru STI |
model: 2006 STi
wheel model: Niche Misano wheel size/offset: 17x8 +40 offset tire brand/model: Pirelli Sottozero 3 tire size: 225/45R17 suspension: Stock fender mods: None spacers: None Any issues like rubbing or wheel bearing wear? https://www.carid.com/niche-wheels/m...-57883110.html
12-19-2016, 08:28 AM | #5477 |
Member#: 236005
Vehicle:2017 Outback 3.6R WGM |
2017
Outback 3.6R Motegi Racing MR118 17x8 +45 Falken Wildpeak AT3W 245/65R17 Stock suspension Stock alignment No fender mods No spacers |
12-19-2016, 03:39 PM | #5478 |
Member#: 324849
NESIC
Vehicle:2005 STI PSM |
Wow that looks good. Where else do people post modded outbacks? The new ones are my favorite.
12-19-2016, 04:17 PM | #5479 |
Member#: 236005
Subaruoutback.org has some. It's a small forum though.
12-19-2016, 06:08 PM | #5480 |
Member#: 452561
year:2003
model: WRX Wagon wheel model: Subaru 2011 WRX stockies wheel size/offset: 17x8 w/ 53mm offset tire brand/model: somekind of winter tires tire size: don't know yet suspension: Feal 441 Coilovers fender mods: Previous owner rolled all four corners flat and stripped the liners out aswell spacers: Nope Looking to put together a winter set. Have a set of the 2011 WRX stockies, with the stock 235/45R17 tires on them. The inside of the tires rubbed like crazy on the lowering coilovers that the car came on. The 441's are new. I've seen plenty of people posting about using 17x7.5 53et and people with 17x8 <53et with no problems. Can't find anything about 8 wide and an offset of 53 though. Looking for suggestions of some decent snow tires and sizes to fit onto these without rubbing on the coilovers again. Have a set of OZ Ultraleggeras in 17x8 48et on 225/45ZR17 Michelin Pilot Sports that I use as a summer set with no rubbing. Thanks. |
12-22-2016, 11:48 PM | #5481 |
Member#: 457491
Vehicle:2013 WRX |
Just an FYI, 18x9.5 +48 will not clear the gtworx/bilstein strut on my 13 WRX. With a 3mm spacer, I can just barely get a piece of paper through the gap between the wheel and strut.
Hopefully this will help others before they waste thousands of dollars like I did. model: 2013 WRX Sedan wheel model:Wedssport SA-15R wheel size/offset:18x9.5 +48 tire brand/model: Continental EXTREMECONTACT DW XL tire size: 265/35/18 suspension: GtWORX/Bilstein with Regular Springs alignment: NA fender mods: Rolled Rears spacers: 3mm in front |
12-23-2016, 02:58 AM | #5482 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
12-23-2016, 06:19 PM | #5483 | |
Member#: 457491
Vehicle:2013 WRX |
I'm getting an alignment tomorrow and will try again. Thanks for the tip! |
12-27-2016, 07:15 PM | #5484 |
Member#: 430523
What size looks good on a stock 07 WRX sedan? I'm eyeing some 17x8.25 ET-32 CCW Classics. Will this look decent or will it look like hot garbage?
12-27-2016, 09:00 PM | #5485 |
Member#: 443317
245/40R18 with 18x8 Wheels - Fitment?
Desired setup (I think):
year: 2013 model: WRX Wagon wheel model: Sparco Assetto Gara wheel size/offset: 18x8, 48mm offset tire brand/model: Toyo Proxes 4+ tire size: 245/40R18 suspension: stock fender mods: none spacers: no Hey guys, I combed through this thread for awhile (an hour or so) and couldn't find what I was looking for so I just thought I'd just post my question. I basically want to replace the stock 17" wheels with 18" wheels (specs above) for the look, and I'd like to get the widest tire possible without having any rubbing issues. I don't have any fenders rolled and I'm gonna keep the car at its stock height, I won't lower it at all. I was thinking of getting 245/40/18 tires with 18x8 wheels (specs above). I checked a few places and it looks like the 18x8 wheels max out at 245, but will it look funny? If I use a 245 tire with an 18x8 wheel, will the tire "puff" out around the wheel and look weird? I'd like to keep the offset at +48 or greater, don't wanna go more than 5mm away from stock offset. From what I've seen, it's hard to find wheels that are wider than 8" with at least an offset of +48. |
01-02-2017, 07:01 PM | #5486 |
Member#: 417803
Vehicle:1997 Impreza WRX WRB |
Year: 2002
Model: WRX Wheel Model: XXR 527 Wheel Size/Offset: 17x9.75 +25 Tire Brand: Federal SS-595 Tire Size: 235/40/17 Suspension: Raceland Ultimos Fender Mods: Rolled Spacers: No Being that they are Racelands, of course one of the front coils is seized so I couldn't get the front lower. Will be taking care of this once it's warmer out, along with giving the car a nice puil. |
01-13-2017, 05:26 PM | #5487 |
Member#: 461249
Will it fit
These are the wheels and tires I want to put on my car I just want to know if they'll fit
year: 2002 model: WRX Wagon wheel model: focal x wheel size/offset: 17x7.5 42mm offset tire brand/model: Bridgestone potenza s-04 pole position tire size: 225/45R17 suspension: stock struts with tein progressive lowering springs 1.5" front 1" rear fender mods: none spacers: no |
01-18-2017, 07:17 AM | #5488 |
Member#: 461500
Hi! I have impreza wrx bugeye year 2002.
Im going to buy wheels 18"x9 et 40 or 18"x9.5 et38. suspension: tein superstreet I dont wanna pull or do anything to my fenders, so is 9.5 too wide? and what tires should i buy? Last edited by Jug0; 01-18-2017 at 08:02 AM. |
01-19-2017, 08:04 PM | #5489 |
Member#: 354732
RMIC
Vehicle:2004 WRX WRB |
Which wheels should I get? I'm torn. Leaning towards RPF1's, though.
(Made this with the WheelCo app btw, I'm no photoshop wizard). Option 1 Option 2 |
01-20-2017, 01:07 PM | #5490 |
Member#: 447721
SWIC
Vehicle:2017 WRX Limited WRB |
Id go option 2 all day every day....
01-22-2017, 05:44 PM | #5491 | |
Member#: 368756
NWIC
Vehicle:2005 STI OBP |
If you don't want to do anything to your fenders, 9.5in is too wide. |
01-23-2017, 02:19 PM | #5492 |
Member#: 401770
Vehicle:2014 STi SWP |
01-23-2017, 05:52 PM | #5493 |
Member#: 368756
NWIC
01-24-2017, 09:45 AM | #5494 |
Member#: 448320
South East
Vehicle:2015 WRX Limited Dark Grey Metallic |
Hey guys, need some advice. Looking to get some new wheels and tires, but I'm on a bit of a budget. I think I've narrowed it down to 2, lol, but still looking around. Specs below.
2015 WRX Stock suspension (will either get springs or coilovers within the year) Will be upgrading to 06 STI Brembo's up front and 04 STI Brembo's in the rear. The wheels I'm looking at are either the avid.1 AV20 18x9.5 +38 Or Tenzo R Type S 18x9.5 +35 I plan on running 255/35/18 wheels. Looking on the web I see a lot of people running AV20s with Brembo's, but I don't see anyone running the Tenzo's. I'm leaning towards the AV20 as I like the look, but I'm not sure I wanna run a common wheel (although I haven't seen anyone around here with them). Do you think I'll run into any clearance issues with the Tenzo's? They look as if they should clear the brakes. I'm also a bit concerned with how much poke I'll have. Is 3mm really noticeable? Thanks for any advice you've got. |
01-24-2017, 12:20 PM | #5495 |
Member#: 447443
BAIC
Vehicle:2011 WRX SILVER |
01-26-2017, 11:57 AM | #5496 |
Member#: 461387
Does anyone have 2008 Spec B wheels on their ride?
Hoping to see how they look on other model Subaru's, specifically 2008-2011 Imprezas! |
01-30-2017, 04:26 PM | #5497 |
Member#: 462173
Wheels and BBK
Hey guys, I have a 2014 WRX with a StopTech BBK. The fronts are 355x32. I went to put on my winter wheels today and there was not enough clearance. So, as things go, I figured since I am not the biggest fan of my current wheels, I would go for something I wanted a bit more.
I am looking at the Ray's 57DR 18x9.5 38 offset. Can anyone with any experience help me figure out of these should have the clearance needed for the BBK? There are no stores local to me that have them where I can take in the measurement printout and check them and the places I have called asking this question to were completely useless. Thanks in advance for any help! Chris |
01-31-2017, 10:09 AM | #5498 |
Member#: 461500
Thanks, i think i go to 9", because i think i dont want small tires and dont want to pull or roll my fenders. Would 255/35/18 go with the 9" et40 with no roll or pull or should i go 245/40?
02-01-2017, 11:45 PM | #5499 |
Member#: 421831
02-05-2017, 05:56 AM | #5500 |
Member#: 458462
2002 WRX sedan, want to run konig hypergrams 18x8.5 +38
What size tire is safe without having to modify the fenders? Car has BLITZ coil overs and is lowered but not slammed any suggestions? |
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
