Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 01-30-2013, 01:00 PM   #8876
09subi2.5i
Member#: 331636
09 impreza
paprika
Originally Posted by 3043imprez View Post
Thanks obd. Definitely open to anything that will cut down on bodyroll...
Rallisports UELs?
09subi2.5i is offline   Reply With Quote
Old 01-30-2013, 01:02 PM   #8877
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by 09subi2.5i View Post
Rallisports UELs?
IMO, not worth getting, as they have a change of throwing a CEL... Also, just doesn't make sense to get headers that won't give you gains, other than sound.
theoutbackdream is offline   Reply With Quote
Old 01-30-2013, 01:09 PM   #8878
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Rallisports UELs?
Heard these throw CEL's? Already have a modded '02ep3 that lights up like an xmas tree from time to time...just don't want any headaches with the sube...
3043imprez is offline   Reply With Quote
Old 01-30-2013, 01:10 PM   #8879
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by theoutbackdream View Post
I would say look at some springs too, but I am not knowledgable with springs, so maybe someone else will chime in.
IMO, don't bother w/ springs unless u r upgrading the shocks/struts as well.
+1 on RSB & better tires.
Fendyman is offline   Reply With Quote
Old 01-30-2013, 01:11 PM   #8880
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
++1 ^ I should of bought tires right after I got my swaybar but i was stubborn. Now I'm so happy i got off those ****ty all seasons.
Steve2.5i is offline   Reply With Quote
Old 01-30-2013, 01:25 PM   #8881
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
So before I cave in n have to take my car to the stealership I figured I'd ask you guys first to see if anyone else had this problem. I'm at about 46k mi on the odo and have done all necessary maint'd up to date. When I'm driving in gear in 3-4th, I let off the accelerator and hear from the front of the car a sound that sounds similar to a loose belt (squeaking/squealing). I can't get it to do it 100% of the time and the noise isn't loud. If someone could point me in the direction of where i should check first? or things to check I'd greatly appreciate it. The stealership wants to charge me 125$ just to look at the damn car which is ****ing bs. I asked the san diego nasioc group on FB but 0 reply's.
Thanks in advance, steve
Old 01-30-2013, 01:41 PM   #8882
DownhillSubie
Member#: 342985
Anyone know how to get the trunk unlock/gas door plastic piece removed from the driver carpet area? I unlocked it with my key and the plastic plate is off but won't pop out over the levers.
Any help would be appreciated, last step in removed my carpet!
Edit- NVM, got it without taking that piece out. Carpet is officially out of the car, new carpet installed today and picking up seats on Friday. Complete interior transformation.
DownhillSubie is offline   Reply With Quote
Old 01-30-2013, 01:57 PM   #8883
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Pull the plastic handles off.
fancyfootwork15 is offline   Reply With Quote
Old 01-30-2013, 01:58 PM   #8884
czeckson
Member#: 309412
2010 Impr. 2.0 Sedan
@sellars21:
The seats and the "plastic" around the shifter are standard.
The 2.0R acropolis is, apart from the engine, similar to the WRX.
czeckson is offline   Reply With Quote
Old 01-30-2013, 02:25 PM   #8885
DownhillSubie
Member#: 342985
Thanks dude, got the carpet out like 5 minutes after I made the post. I've done way more to this car then I originally planned.
Old 01-30-2013, 04:21 PM   #8886
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
A rear sway bar, like $200 or $150-ish shipped to your door
Grippier Tires than stock, like $500
+1 on that. The only mods that I have so far as far as suspension/ handling is a rear 19mm swaybar (front 22mm not installed yet), and 17x8 wheels with 225-45 tires. It has made a pretty big difference in the body roll even without the front sway bar installed yet, and the wider tires help with overall grip.
BWX is offline   Reply With Quote
Old 01-30-2013, 04:22 PM   #8887
subieguy87
Member#: 153412
1998 Impreza wrxRS
Originally Posted by BWX View Post
+1 on that. The only mods that I have so far as far as suspension/ handling is a rear 19" swaybar (front 22" not installed yet), and 17x8 wheels with 225-45 tires. It has made a pretty big difference in the body roll even without the front sway bar installed yet, and the wider tires help with overall grip.
19 inch!
subieguy87 is offline   Reply With Quote
Old 01-30-2013, 04:26 PM   #8888
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Originally Posted by subieguy87 View Post
19 inch!
LOL.. yeah that would look funny huh?
Old 01-30-2013, 04:30 PM   #8889
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Try 245's and you will have a racecar like me
KartRacer3 is offline   Reply With Quote
Old 01-30-2013, 04:42 PM   #8890
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Lol 225s seem to work for me
Out turned a wrx @outbackdream ;D
Navysesal is offline   Reply With Quote
Old 01-30-2013, 04:49 PM   #8891
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Lol heard that one before.
Old 01-30-2013, 05:20 PM   #8892
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I might try 235s next! My gas mileage doesn't like the wider tires, but my g-meter does.
Old 01-30-2013, 05:24 PM   #8893
theoutbackdream
Member#: 301179
2013 WRX Limited
I had this same sound in my OBS... My friend is telling me the bearing is bad, and the Mechanic told me it was the bearing too..
Old 01-30-2013, 05:56 PM   #8894
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Wheel bearing? Which bearing
Old 01-30-2013, 06:12 PM   #8895
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Suspension is high on my list...just not sure what elements i could get for $500...strut tower bars and lower ties?
You can get lowering springs.
Aredilla is offline   Reply With Quote
Old 01-30-2013, 06:15 PM   #8896
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Yea I just lowered my car last weekend, and I love it, it took a lot of the body roll away; and also if you want to take a lot out, you should also buy a strut bar or sway bars
Old 01-30-2013, 07:13 PM   #8897
krueger519
Member#: 336523
2010 Impreza 2.5i
Maroon
Alright, so I have put a lot of mods in my subie and was wondering what you guys think of suspension.
What will be installed later this year.
Whiteline 20mm front sway bar
STI 19mm rear sway bar
kartboy endlinks
Bilstein GTWorx sport kit with RCE regular springs
Opinions are greatly appreciative.
krueger519 is offline   Reply With Quote
Old 01-30-2013, 07:15 PM   #8898
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Springs are nice but will blow your oem suspension at some point . I would recommend replacing the entire strut assembly, either coils or inserts both will help. Strut bars don't help the new chassis as much as it did on the GC, GD's (basically pre 08).
235's are the recommended size I'm pretty sure and the stock size of the Wrx tires. However on a 8" wheel I would take the 245's any day lol.
Old 01-30-2013, 09:18 PM   #8899
Daniel208
Member#: 318639
2010 Impreza 2.5i
Spark Silver
Originally Posted by czeckson View Post
I´ve got some new mods:
DEPO LED rear lights:
Be sure to post some day/night pics when you get them on! Thinking about getting them myself.
Daniel208 is offline   Reply With Quote
Old 01-30-2013, 09:19 PM   #8900
theoutbackdream
Member#: 301179
2013 WRX Limited
Sorry, Wheel bearing.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 10 08-22-2017 12:30 AM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
