09-12-2018, 08:41 AM | #1 |
Member#: 310373
Vehicle:2018 wrx White |
Swapped Wheels TPMS Light ON
Hi All,
I have bought a set of 18" OEM Subaru wheels for my 2018 wrx. The new OEM wheels do have stock TPMS sensors in them but the light still ended up flashing with a warning for TPMS. My questions is do I take the car in and have my original TPMS cloned? If so, is Subaru dealer the only place that can do this? Also, if I end up selling my OEM wheels with TPMS sensors still in them, will it cause issues for the other person buying them? Thank your you help in advance.
09-12-2018, 09:05 AM | #2 |
Member#: 363268
Vehicle:2015 WRX STi WRB |
You're going to have to take the new wheels in and have dealership reset the tpms signal
09-12-2018, 09:06 AM | #3 |
Member#: 453598
NESIC
Vehicle:2021 Honda Type R Boost Blue |
Tpms
The ECU needs to be told the IDs of the new TPMS sensors.
Most tire shops can do it for free, in some cases, or for $10-20. The dealer is likely to charge some crazy price like $90-$100. If the new sensors can be cloned that's an option, but it will probably cost more than just updating the ECU. |
09-12-2018, 09:52 AM | #4 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
We do a couple newer Subies that swap rims twice a year for snows. Swap wheels, scan, program, done. |
09-12-2018, 11:11 AM | #5 |
Member#: 268310
SCIC
Vehicle:2011 SSM STI saloon Church! |
The shop that installed my aftermarket wheels swapped my OEM TPMS sensors to my new wheels as part of the install. No extra charge to swap them.
09-12-2018, 11:31 AM | #6 |
Member#: 30669
Fine if doing a one time swap. For those with 2 sets, quick program is fine, no dealer needed but the tire shop needs a scanner/programmer.
09-12-2018, 11:04 PM | #7 |
Member#: 370806
Vehicle:2019 WRX/STI DGM 23 Nissan Frontier Pro 4x |
Most Discount Tire loctaions can clone TPMS sensors now. No need to reprogram when you swap anymore.
09-13-2018, 02:06 AM | #8 |
Member#: 464019
Vehicle:2017 Wrx ISM |
I can vouch for discount tire, took them all of 5 minutes to reprogram my wheels
09-13-2018, 07:39 PM | #9 |
Member#: 370806
09-17-2018, 03:08 PM | #10 |
Member#: 361107
Vehicle:2017 WRX |
09-17-2018, 03:44 PM | #11 | |
Member#: 428511
Vehicle:2016 STI |
total pain having to get them programmed each season. |
09-17-2018, 03:57 PM | #12 | |
Member#: 228010
NESIC
Vehicle:2019 WRX Limited Crystal White Pearl |
I would still need to buy that $100 tool that wakes the sensors after they sit for several months? |
09-17-2018, 06:37 PM | #13 | ||||
Member#: 30669
Sorta easy for most, be nice to local tire shop so they program whatever sensors to your car when doing seasonable tire swaps. Cloning OEM sensors can be OK, but can create issues if you swap ID's around the car. You get a low pressure alarm, low tire may be in a different spot. So.....back to programming a TPMS ID to a corner. Sigh. |
09-17-2018, 06:46 PM | #14 |
Member#: 30669
My overall comment, make friends with a trusted local tire shop. You help them, they may help you.
Taken from a part timer at a shop that likes doing tires. They, and I, do TPMS swaps and programming. A lot of times, a regular customer comes in to do a tire/wheel swap due to seasons, reprogramming the sensors is "maybe" a couple bucks above labor to swap 4 wheels. A lot of times, the shop also stores your second set of wheels. Sorta depends on,if regular or not and other work (oil changes, etc.). You help a small shop, maybe they help you. |
09-17-2018, 07:18 PM | #15 | |
Member#: 370806
09-17-2018, 07:21 PM | #16 | |
Member#: 370806
Now like Charlie stated if a sensor has to be in a specific location in the car then this may not work for your situation. |
09-18-2018, 10:48 AM | #17 | |
Member#: 428511
Vehicle:2016 STI |
If you are a CUSTOMER a place will be more willing to do favors that they don't make a nickel on, you know, since you are a regular customer and they run a business and not a charity. If you never spend a dollar supporting their business and want to stroll in and ask for a favor they probably won't, and shouldn't be interested. Not sure what you do for work, but I'd go out on a limb and guess you don't work for free for random people wanting favors. |
09-18-2018, 12:14 PM | #18 | ||
Member#: 30669
Early systems just showed a "low pressure alert", you had to check all tires (sometimes even the spare). Newer systems show the pressure on each tire on a display from an overhead view. But, it I stated only accurate if the correct TPMS ID is in the correct spot. Still an easy fix. Quote:
Example.....busy day at the shop, Joe Blow comes in with a flat. Maybe we swap on the spare, then say, "come back in an hour" to get the repaired tire. Then we likely swap it on and place the spare back. Regular customer comes in, we may stop what we're doing and fix it then. Saves a trip. Same for tire rotation, unknown peep comes in, we ask (and likely charge for) telling the display where the tire ID's are now. Regular customer gets a tire swap, reprogramming is just done for no more cost. Shop time and customer time both have a value. A shop wants to be fair to everyone that comes in, but will help out regulars where they can. |
09-18-2018, 03:43 PM | #19 | |
Member#: 251046
Vehicle:2004 WRX Wagon Stage 5.1.2a.2 |
09-18-2018, 03:50 PM | #20 |
Member#: 428511
Vehicle:2016 STI |
^exactly
06-01-2021, 12:36 PM | #21 |
Member#: 524646
Vehicle:2019 WRX Metallic Blue |
Swapped one Wheel with one TPMS sensor.
I drive a 2019 WRX base.
Recently I have to change only one TPMS sensor on the Real Left wheel. It's an aftermarket one, and I did not made the job by myself. After driving a few miles the TPMS warning came up on the middle screen and the symbol blinked several times till it becomes solid lit. Checked pressure and was 3psi above recommended. So I assume this particular sensor must be readressed again. My Question: How to turn Learning Mode on my car to readress this TPMS? Already tried to turn ignition on "ON" position, look for a TPMS button behind glove box, and by the menu when using buttons beneath steering wheel.... Nothing... I need some help on this particular issue to do it by myself. Also I tried the VXDAS Relearn tool. I appreciate your feedback Thank You. |
06-01-2021, 12:59 PM | #22 | |
Member#: 477489
Vehicle:2018 WRX Limited CWP |
Your new TPMS needs to be programmed to the car, so it can identify it correctly. Take it back to wherever you got it installed and ask them to code it in correctly. Or take to to Discount Tires, they will do this for free and all it takes is a few minutes with the correct scanner/updater tool.
