02-20-2012, 06:02 PM | #1 |
Member#: 131945
Vehicle:2013 BRZ Gunmetal |
I want hear the stories, the good, the bad, and the ugly.
Trying to make a decision on what to use on a car running 35+ PSI / 700ish WHP I have the 625+ 11mm in stock, the P&L and AMR are on backorder for a month. Cost is a non-issue. Anyone put any real boost through the 625+ yet? Anyone have any problems using the bigger stuff? Keeping the extra material in the block with the 11mm sounds nice as long as they can take the pressure. If I have to, I will wait for the bigger stuff. Heres some data I found, I am not an engineer. ARP CA625+ Material - ARP Custom Age 625+ Yield Strength: 235-255,000 PSI 11mm body diameter Tensile Strength: 260,000 PSI Torque Spec - 100ft lbs P&L Material - ARP2000 215,000-220,000 clamp load rating 13 mm body diameter 110 ft/lb torque spec Larger 24.5 mm/o.d. washer for increased clamping area AMR Material - 8740 chromoly 220,000 psi clamp load rating 9/16 diameter (14.2mm) 120ft/lb torque spec
02-20-2012, 06:09 PM | #2 | |
Member#: 289606
Vehicle:06 WRX white |
02-20-2012, 06:14 PM | #3 | |
Member#: 131945
---------- I just heard that the boys at Georgie Performance have been using stock diamter (L19) studs with good success. That tells me the 625+ would only be better. |
02-20-2012, 06:59 PM | #4 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I have the custom age 625+ . I run the calculations and even with the larger cross sectional area and 10ft/lbs more at final torque the P&L 13mm have less clamping force than the 625+.
02-20-2012, 07:00 PM | #5 |
Member#: 131945
How much horsepower are you running and how many pounds of boost? I need results not math lol
02-20-2012, 08:40 PM | #6 |
Member#: 133146
02-20-2012, 09:27 PM | #7 |
Member#: 76974
Vehicle:2005 CGM STI 10.03 @ 135 |
Real world experience > math/theories
02-20-2012, 09:48 PM | #8 |
Member#: 133146
02-20-2012, 10:09 PM | #9 | |
Member#: 76974
02-20-2012, 11:19 PM | #10 | |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I had planned on guinea pigging the 625 11mm in my own car this year. 14mm have never given an issue but they're pricey. They're the only oversized stud that Darton East will install. |
02-20-2012, 11:46 PM | #11 |
Member#: 131945
Anyone know what studs the other fast cars are running? Obviously p&l are running their own
Easy street? Rigoli? Roger Clark? Precision tuning? I'm sure I am forgetting a bunch. Evo guys making 700ish tend to go for the L19 studs stock diameter with no issue. We have built a couple evos that make just over 800 with L19. Different application though. |
02-21-2012, 08:10 AM | #12 |
Member#: 81102
South East
I think these guys are doing Orings in racing.(the Evo guys surely are)
What are your guys retorquing strategies after initial install? Last edited by CatfaceType-R; 02-21-2012 at 08:15 AM. |
02-21-2012, 08:19 AM | #13 | |
Member#: 163108
International
Vehicle:07 EuroDM STi 2.5L Silver |
02-21-2012, 10:51 AM | #14 | |
Member#: 131945
This particular Subaru motor is getting O-ringed |
02-21-2012, 10:52 AM | #15 |
Member#: 131945
02-21-2012, 11:08 AM | #16 |
Member#: 163108
International
the Gobstopper don't have a headgasket, they use o-rings and something like o-rings to separate the oil and water from the block going to the heads. It works for closed deck Subaru engines only, I think version 3 and 4 STI engines. lots of machining but they have proven their technology
02-21-2012, 11:30 AM | #17 | |
Member#: 131945
I made some phone calls. I am going to give the CA625+ a go. Going to O-ring the block and run Cosworth headgaskets. If it lifts, I can always do bigger studs. I have faith it won't at the power levels this thing will see. Its also going to save about $400 in work that the machine shop wanted to do the job. Just waiting on my billet JE pistons to get here so I can sleeve this thing and get the ball rolling... Last edited by No Limit Motorsport; 02-21-2012 at 11:41 AM. |
02-21-2012, 11:38 AM | #18 |
Member#: 131945
02-21-2012, 12:20 PM | #19 | |
Member#: 163108
International
Any particular reason why use Cosworth head gasket instead of oem? I'm thinking about that for a long time now, RCM 14mm headstuds, sleeved block with o-ring, I just don't know if the oem head gasket can be "o-ringed"... Btw what sleeves will you use? Is it Darton or LA Sleeves? Thanks |
02-21-2012, 12:56 PM | #20 | |
Member#: 131945
No doubt the OEM headgaskets are good. We have never had a problem with the Cosworth gaskets either, only great experiences. Perhaps its a placebo effect, the feeling that the more you spend the better you get. Here is a test showing the clamping area of the different gaskets. http://www.motoiq.com/magazine_artic...ed-blocks.aspx |
02-21-2012, 02:48 PM | #21 |
Member#: 71875
what's the biggest stud that will fit through the stock dowels?
also, wrc cars use larger studs on the center two holes. It's something I've thought about doing. Although we were up to 38psi on cosworth 11mm L19 studs. I think keeping the headgasket together is more an issue of temperature management than it is headstud size. Last edited by jamal; 02-21-2012 at 09:13 PM. |
02-21-2012, 07:51 PM | #22 |
Member#: 25952
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
I am running the A1 Technologies Bolts. 620 whp at 28 psi on a GT4094R with E85 and a mustang dyno. I plan on pushing the boost to around 35 psi in two weeks.
02-21-2012, 09:19 PM | #23 |
Member#: 131945
Sounds promising. Keep us updated. I would expect the performance to be very similar to the ARP 625+. Are you running the chromoly or H11 version?
02-21-2012, 10:16 PM | #24 | |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
02-21-2012, 11:18 PM | #25 |
Member#: 163108
International
That sounds great. Please let me know if it is available in the market already
Similar Threads | ||||
FS : EJ257 block w/ Darton Sleeves, O-ringed, P&L 13mm head studs | bugeyesubby | Tri-State Area Private Classifieds | 9 | 11-12-2011 08:00 AM |
FS : (NJ): EJ257 block w/ Darton Sleeves, O-ringed, P&L 13mm head studs | bugeyesubby | Engine/Power/Exhaust | 8 | 04-10-2011 07:25 PM |
FS : NJ: sleeved,o-ringed 2.5 block w/ P&L 13mm head studs | EmaciatedCow | Engine/Power/Exhaust | 7 | 02-14-2011 02:56 PM |
2007 Prodrive Time Attack Challenge 9/15 & 9/16 | wrx grl | Southern California Impreza Club Forum -- SCIC | 87 | 09-12-2007 12:33 PM |
Perrin vs U-R vs P&L | FromEvoToRS37 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 08-22-2007 01:10 AM |
