07-25-2009, 08:59 AM | #1 |
Member#: 145673
E. Canada
Vehicle:2002 Impreza WRX Aspen White |
Need a map for an 18g
ok so i spent alot of money lately and need a quick map to get me by for now until i can afford to properly tune it. heres the engine mod list....
02 wrx 2.0l with version 8 sti transmission, diff.... blouch TD05 18g 7cm (ceramic coated) deatchwerks 750cc injectors walbro 255lph fuel pump perrin turbo inlet perrin lightweight pully perrin catless up-pipe helix downpipe cobb cat-back exhaust aps tmic grimspeed ebcs crushed stock bpv k&n drop in air filter soon to have tgv deletes and 3mm phenolic spacers so may aswell include these i have a tactrix 2.0 and have 93-94 octane fuel available to me so does anyone have a map thats closer that i could use until i get a proper one?
07-25-2009, 09:00 AM | #2 |
Member#: 145673
E. Canada
thanks in advance for anyone who can help
09-24-2009, 02:38 PM | #3 |
Member#: 176235
Vehicle:09 Mazdaspeed3 |
Bump. I need the same thing as this guy...please.
09-25-2009, 01:32 AM | #4 |
Member#: 176321
NESIC
Vehicle:2011 wrx CGM |
you should contact clark turner here on nasioc he is great with maps for all types of setups
10-29-2009, 08:18 PM | #5 |
Member#: 187021
Vehicle:2004 WRX Sedan PSM |
This is a bit late but I have a safe base map that I came up with for a 2004/05 WRX.
FP TD05 18g Turbo XS FMIC Turbo XS UP,DP,High Flow cat,RFL Catback roughly 750cc injectors, enter your own scale/latency stock maf scaling I tested it on my setup at full throttle, safe to 17 psi, overboost fuel cut at 17.4 psi PM if needed Use at your own risk. |
02-22-2018, 11:14 AM | #6 |
Member#: 473633
I could use some help.im drivable but not optimal
O2 WRX ej20 avcs catless downpipe full exhaust 3 inch GrimmSpeed ebcs 850 injectors 18g Turbo Perrin turbo inlet aem wide band walbro 255 cold air intake
.can u help me? FP TD05 18g Turbo XS FMIC Turbo XS UP,DP,High Flow cat,RFL Catback roughly 750cc injectors, enter your own scale/latency stock maf scaling I tested it on my setup at full throttle, safe to 17 psi, overboost fuel cut at 17.4 psi PM if needed Use at your own risk.[/quote] |
02-28-2018, 10:00 AM | #7 | |
Member#: 257231
Vehicle:2011 STI ShinjiTuned DGM |
03-17-2018, 01:01 PM | #8 |
Member#: 460041
Did you guys end up finding anyone to make you a map?
vf39 for an 18g on STi what do i need to get it right? | taco_tom | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 09-01-2009 03:26 PM |
I need a fuel map for an fp green open source | blacknbluewrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 01-08-2009 02:38 AM |
Need info/help with an 18g turbo | gling | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 0 | 12-09-2007 02:41 PM |
Need SD Map for 560 pinks 18G | gaby | UTEC | 0 | 10-29-2006 11:21 AM |
Utec Map for a 18g??? | ImprezaWRX0386 | Engine Management & Tuning | 2 | 03-31-2004 08:39 PM |
