Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 11-18-2008, 01:59 PM   #1
WrXwaBBit
Member#: 33296
Default I haven't driven my car for 8 months
I been away from home and my wrx 04 has been sitting outside of my apartment for 8 months now. I know for a fact my battery is dead because i did not discount the cables and gas tank is 3/4 full. I be coming home next month but i would like to know what kind of problem would I expect for leaving my car out for that long? also could my alternator be dead? thanks in advance
WrXwaBBit is offline   Reply With Quote
Old 11-18-2008, 02:17 PM   #2
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
just get a new battery pull the starter fuse and let it crank to let some of the fluids circulate again
jcbluescooby is offline   Reply With Quote
Old 11-18-2008, 03:28 PM   #3
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
you need some fresh fuel too
Big_Hitter is offline   Reply With Quote
Old 11-18-2008, 03:53 PM   #4
WrXwaBBit
Member#: 33296
so i need to remove the old fuel and add new fuel?
Old 11-18-2008, 03:55 PM   #5
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
I would
Maybe you can disconnect the line from the fuel filter, turn on the ignition and drain it road warrior style
Old 11-18-2008, 04:06 PM   #6
jcbluescooby
Member#: 113012
'04 XT red LIFTED
if your gonna unplug the hose from the fuel filter make sure you wear eye protection unlike my dumass..lol..but i wouldnt drain it that way becuase youll be turning on the start repeteadly for a while and i dont think thats good..just cyphen it and use to make malitov cocktails
Old 11-18-2008, 04:24 PM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
other than flat spots on your tires, you'll be fine. Just top off with fresh fuel and get an oil change. don't drive it hard till the old fuel is used up.
fastnoypi is offline   Reply With Quote
Old 11-18-2008, 04:42 PM   #8
WrXwaBBit
Member#: 33296
I don't feel like draining 3/4 of fuel out my tank thats way too much fuel. I want to go ahead and use the old fuel, it wouldn't cause serious damage to my engine right? I mention that i left my car outside expose to the weather so won't there be a problem with my brake system?
Old 11-18-2008, 05:04 PM   #9
fastwrx25
Member#: 126441
03 bugeye
I parked my car for 8 months in my garage once. the battery was dead so I brought it to autozone for them to recharge (they do this for free). after I reinstalled the battery I changed oil and filter and just I let it warm up for a min and drove slowly to the gas station to fill up with new gas.
fastwrx25 is offline   Reply With Quote
Old 11-18-2008, 05:13 PM   #10
WrXwaBBit
Member#: 33296
You are lucky you have a garage to keep your car. Hopefully there won't be any problem with my car.
Old 11-18-2008, 05:22 PM   #11
alphagoose
Member#: 158302
2010 legacy gt
i havnt driven my wrx in about 2 weeks and its driving me nuts. idk how u did 8 months
alphagoose is offline   Reply With Quote
Old 11-19-2008, 01:41 AM   #12
fastlanerex
Member#: 133391
2004 boosted saleen
white
I didnt drive my wrx for 6 monthes and it was outside. Other than really rusted rotors that eventually wear off. I had a dead battery replaced that fired right up. Had half a tank of gas in here filled it up with gas asap and didnt get into boost for the rest of that gastank then i was fine.
fastlanerex is offline   Reply With Quote
Old 11-19-2008, 07:15 AM   #13
fastwrx25
Member#: 126441
03 bugeye
oh yah I forgot the mention, I added redline fuel system cleaner when I got gas too. I figured it would help with moisture in the tank and lines, and help with any gunk in the lines. I then changed oil again after a week or so before my next tank of gas( I usually change oil when I use fuel sys cleaner).
Old 11-19-2008, 11:16 AM   #14
dimswits
Member#: 160342
02 E46 Coupe
This. No need to drain the gas that's in the tank. You can smell bad gas in the exhaust. It doesn't stink really, but it has a sharp smell that is definitely different than what's normal.
I've resurrected several cars that sat for *YEARS*. One, my GF's current daily driver, sat in a field for 3 years and was basically a zoo inside. I generally just put in a new battery and fire it up. It should be safe to idle and limp around like that, just do an oil change ASAP and fill the tank with fresh fuel when you can.
Also not all tires will flat spot from sitting. You'll know soon enough if yours have.
dimswits is offline   Reply With Quote
Old 11-19-2008, 12:47 PM   #15
dewmudgeon
Member#: 156933
1998 2.5 RS
Acadia Green
Maybe use some octane boost? Can anyone support that, would it work?
dewmudgeon is offline   Reply With Quote
Old 11-19-2008, 01:19 PM   #16
SocketJockey
Member#: 143197
2005 I Drive a Truck
Still Swirly
I left my car sitting outside for 8 months...just changed the oil and topped off the gas tank. I would also check for small woodland creatures that might have decided to climb their way into your car, found two mouse nests (that reads funny) and a whole pile of mouse crap in the back of my car...thing still smells like piss.
SocketJockey is offline   Reply With Quote
Old 11-19-2008, 01:31 PM   #17
humplick
Member#: 170516
02 PSM WRX Sedan
Seafoam - That **** works wonders on gas. Works better when you add it before you leave, but it will make your gas a little better than whats in it currently.
humplick is offline   Reply With Quote
Old 11-19-2008, 01:56 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bad idea....all the water in the tank should be drained out
fuel injectors dont like water
this is REAL easy.....there are 2 nice drain plugs on the bottom of the tank....EASY to drain fuel
Leaving my car for a month missallie Newbies & FAQs 13 12-14-2008 03:45 PM
Dealer has been working on my car for a month. CapeRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 03-28-2006 09:22 PM
I haven't driven my car in 6 weeks... HalfBaked Off-Topic 4 07-26-2005 03:48 PM
Leaving my car for a month- what should I do? Mapplex New England Impreza Club Forum -- NESIC 7 12-02-2002 02:00 PM
