Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 01-17-2008, 06:27 PM   #1
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
Default steering will not return to center
i installed megan coilovers in my car the other day. With the way this setup is, the spindle bolt area threads up on the coilover. this causes pulling on the sway bar before it is even on the ground. i have cusco 21mm front sway bar with cobb end links. do i need the white line adjustable endlink to loosen up on the sway bar in the front.
please help. thanks
gmanwrx is offline   Reply With Quote
Old 01-17-2008, 06:28 PM   #2
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
I am very confused. Spindle bolt area threads up on the coilover???
And what does the sway bar have to do with the steering not centering?
twizzstyle is offline   Reply With Quote
Old 01-17-2008, 06:32 PM   #3
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
the two factory camber bolts that connect from the strut to spindle. well on the megan coilovers, that bottom perch where the two camber bolts r, spin up o the coilover. so there is al ready tension on the sway bar..
most cars when u jack up the front, the wheels drop and the springs move around, there is no load on the suspension, with this setup, there is a load on the suspension in the air.
Old 01-17-2008, 06:55 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You mean they don't have enough droop travel? I doubt it's causing your problem unless you have one side severely preloaded that the other isn't. If that's the case then something is wrong with the install.
Most likely it's the top hat and a seized bearing up there. There's been a few other cases reported.
Old 01-17-2008, 09:22 PM   #5
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
Most likely it's the top hat and a seized bearing up there. There's been a few other cases reported.[/quote]
thanks,
Stiff steering, won't return to center.. Pines Brakes, Steering & Suspension 3 08-16-2009 07:43 PM
Steering sticking, not returning to center. bpimm Legacy Forum 18 02-08-2007 04:05 PM
Bought wheels off elpapi336 - one is cracked. He will not return my calls RR New England Impreza Club Forum -- NESIC 52 07-15-2006 01:14 PM
Help. Car will not return to idle... LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-10-2005 12:49 AM
Shift stick doesn't return to center danci1973 Legacy Forum 4 01-09-2003 12:34 AM
