Welcome to the North American Subaru Impreza Owners Club Thursday February 22, 2018
Old 05-09-2002, 12:50 AM   #1
WR-REX
Member#: 5250
2007 Tundra RCSB 5.7
Default PDE vs Turboxs downpipe
One has a 4 inch mouth that doesnt cover any of the turbo outlet. Bu the PDE does cover part of the turbo outlet. WHat does this do for performance?
WR-REX is offline   Reply With Quote
Old 05-09-2002, 12:58 AM   #2
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default downpipe
i have the pde downpipe and i love it. all of my lag issues are gone. i had all stock exhaust piping and downpipe with a front mount and an upipe and i had lag. i got the downpipe and now i have so much less lag compared to before. i think they are equally good.
STEALTH-WRX is offline   Reply With Quote
Old 05-09-2002, 10:55 AM   #3
WR-REX
Member#: 5250
hello
Old 05-09-2002, 10:58 AM   #4
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Default Re: PDE vs Turboxs downpipe
*edit* nevermind.
Covering the wg outlet (which is what I'm assuming does) like the stromug one, causes turbulence when you reach full boost (and the wg opens). The stock one is the same way. There aren't any dyno's of before and after that I've seen, but I just decided to get the best (IMO). $330 isn't that bad at all.
Another option is the Godspeed one because it includes the midpipe, so it'd save you that cost, you'd get no cell, and get to keep your catback.
my $.02
-C
TypeC is offline   Reply With Quote
Old 05-09-2002, 11:10 AM   #5
WR-REX
Member#: 5250
it seems that PDE and godspeed are nearly identical. ANd both replace downpipe and front midpipe. and both block the wg.
Old 05-09-2002, 11:17 AM   #6
WR-REX
Member#: 5250
here is a picture of both godspeed and pde
Old 05-09-2002, 11:37 AM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
It looks like hte GS one allows for the wg flow. You know the wg flapper doesn't open 90 DEG, so it will still go in there mostly. The stock DP is a big POS.
Old 05-09-2002, 05:58 PM   #8
WR-REX
Member#: 5250
what does that do for performance? blocking the wg I mean.
Old 05-09-2002, 06:02 PM   #9
Subi-fied
Member#: 13483
Can someone say cross talk?
Subi-fied is offline   Reply With Quote
Old 05-09-2002, 06:10 PM   #10
wrxtcy
Member#: 14672
2002 impreza wrx
midnight pearl black
Default turboxs vs. P.D.E.
It seems logical to me that less restriction in the downpipe would allow for better spoolup.I have the tbxs turbo back exhaust before (stock exhaust),boost reached 14 psi about 3500 rpm,now I reach 14 psi at about 3000 rpm.I am running stock ECU now.I am note sure if this answers your question,just wanted to give some feedback on the topic.
wrxtcy is offline   Reply With Quote
Old 05-10-2002, 01:29 PM   #11
WR-REX
Member#: 5250
Does blocking the wastegate hurt performance?
Old 05-10-2002, 01:58 PM   #12
Division By Zero
Member#: 7555
It makes the exhaust gas flow turbulant. That doesn't help performance.
Do you have the latest SCC mag? It has their WRX that they put on a Vishno Stg 0 and put on a few different exhausts. One of the exhasut utilizes a downpipe like the PDE one that has a flat plate in the path of the WG.
Read that article and they talk about it causing boost spikes, etc.
Division By Zero is offline   Reply With Quote
Old 05-10-2002, 03:15 PM   #13
Tuning Factory Inc.
Vendor
Member#: 3600
Just an addition. I machine out the flange at the portion over the wastegate arm. The wastegate opening is completely unblocked. I have had no spiking or creep issues with this setup at all despite my huge amounts of airflow.
Tuning Factory Inc. is offline   Reply With Quote
PDE downpipe w/cat vs Cobb downpipe?? hoovillemd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 10-17-2004 09:47 PM
PDE vs Helix catted downpipe? 11SECWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-11-2004 01:31 AM
Scoobysport Downpipe vs. TurboXs Downpipe? rallytuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-04-2002 12:25 AM
PDE vs. Godspeed Downpipe OCBeachMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-14-2002 05:02 PM
Modular USDM downpipes, shiv vs. turboxs vs. godspeed Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-19-2001 11:28 PM
