Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 07-15-2004, 11:31 AM   #1
watcher in the sky
Member#: 3513
1997 Legacy Outback
Default KYB AGX struts and Prodrive P1 springs
plus an ALK. Would this setup yeild a great amount of handling over stock (already have strut tower and wrx rear sway bar)? I am either gonna do all that, or just get H&R coilovers. I do alot of back road driving, lots of turns with dips and mounds in the middle of them, so I don't want a setup that's gonna bounce me off the road.
When ever I get to it, my car is gonna be around 200-250 lbs lighter, maybe more, so I suppose I need to consider that. Anyways, just wondering if the afformentioned setup would be alot better than stock or just a little better.
watcher in the sky is offline   Reply With Quote
Old 07-15-2004, 03:19 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Works great. Washboard roads need to be taken at no more than 2 on the AGX or else.
At the low strut setting the ride is plush.
I would suggest that you get the STi top mounts with this combo as the stockers are pretty soft.
linsavy is offline   Reply With Quote
Old 07-15-2004, 04:42 PM   #3
watcher in the sky
Member#: 3513
1997 Legacy Outback
Alright I'll look into that, thanks.
Old 07-15-2004, 10:25 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
PM Andrew Bacon, we have this setup on his car. Very capable. Hugely better than stock. The adjustability gives the strut an edge over the V5/6 strut the spring is normally paired with. You can get a suppleness that the inverted strut can't get but still ramp up the damping to levels as stiff or stiffer than the P1.
Arnie is offline   Reply With Quote
Old 07-15-2004, 11:37 PM   #5
watcher in the sky
Member#: 3513
1997 Legacy Outback
sweet, I had a feeling that it would be a nice setup.
Old 07-15-2004, 11:41 PM   #6
saar
Member#: 43770
2013 Impreza WRX Lim
2001 Impreza WRX STi
haha...wierd...I am getting the Agx's tommrow...and guess what there being matched with.....you guessed it..P1's!
saar is offline   Reply With Quote
Old 07-16-2004, 12:03 AM   #7
watcher in the sky
Member#: 3513
1997 Legacy Outback
Old 07-16-2004, 03:45 AM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Yeah, and hell, for the high price that the V5/6's are running nowadays, I think I'd just go with the AGX's. Their both made by KYB so its not like you're losing out on quality. Just the additional torsional rigidity of the inverted. But, i hardly think you'd notice a difference of the piston deflecting!
its a good combo and it looks pretty damn dope!
Old 07-29-2004, 07:15 PM   #9
Diezel
Member#: 16182
I was thinking about the same combo, but was considering getting some ground control coilovers on the KYBs. Any thoughts on this?
I want to keep my suspension simple and streetable. I read about some guys running konis and gcs and they were talking about revalving and all sorts of other stuff, which i am not down for. Would i run into alignment issues with the gcs?
Diezel is offline   Reply With Quote
Old 07-29-2004, 09:06 PM   #10
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
so why bother with a coilover setup? You'll have to experiment with ride height and corner weighting. You'll lose travel. And do you think you can do a better job of setting up your suspension than Prodrive? Seriously, the P1 spring, in spring rate and height, is more spring than most will need for the road and basic track duty. Unless you just want the slammed look, then do what you want but please leave any expectation of Performance out of the equation.
you won't run into any alignment issues per se. but that will depend on how low you go. but too low is too low if you want a good handling car.
Old 03-25-2005, 06:32 PM   #11
suby25
Member#: 52822
2015 WRX
I just ordered some P1 springs too, but I've having a hard time choosing between the V5/6 and KYB AGX. I like the dampening adjustment on the AGX, but it'd be nice to get a comparison from somebody who's driven both to see where one out performs the other. I'm not against spending the money for the V5/6, but it should be worth the difference.
FWIW, this setup would be used for auto-x and aggressive street driving.
suby25 is offline   Reply With Quote
Old 03-25-2005, 07:41 PM   #12
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Good point. I run AGX in Boston and either settings >2 is hell in this historic town. I run an ALK and pinks too.
I just installed some v8 STi struts w/ Espliers on a buddy's sedan and I REALLY liked the ride over my set up. I think the STis are a better dampened strut over the adjustability of the AGX. I would recomend getting rides in cars with the two different struts (everything else being equal) and compare before you buy. I wish I had.
N
REDrum is offline   Reply With Quote
Old 03-25-2005, 08:25 PM   #13
linsavy
Member#: 11620
I would get Koni's before V5s. Adjustable struts are very helpful for autox. AGX are OK and inexpensive. If you can spend a little more, get the Koni's.
Old 03-25-2005, 11:26 PM   #14
OvenMitts
Member#: 46278
96 Impreza
"brighton"
I've got the AGX/P1 setup on my GC, and I love it. I run it at its stiffest setting, and it handles great. The ride can get a bit bumpy, but new top hats might help with that. My only regret is not waiting a bit longer to upgrade to Group N tophats at the same time.
OvenMitts is offline   Reply With Quote
Old 03-25-2005, 11:33 PM   #15
psyber_0ptix
Member#: 60671
1992 Turbo Miata
402hp/375tq
my prodrive+agx is way too soft for my taste...
i think i'm going to move to koni inserts and eibach ERS springs
psyber_0ptix is offline   Reply With Quote
Old 03-26-2005, 02:19 AM   #16
boosted20
Member#: 79576
put your car on a diet. Trim spa baby. drop like 300 lbs...
boosted20 is offline   Reply With Quote
WTT:(FL) KYB AGX struts and prodrive springs for coilovers evan_impreza Suspension/Brakes/Handling 2 10-14-2009 11:04 PM
WTB:93-01 impreza AWD kyb agx struts and prodrive P1 springs martystoked Private 'Wanted' Classifieds 1 09-18-2008 05:31 PM
KYB AGX struts and Prodrive P1 Springs for GC8 SubaruLover Private 'Wanted' Classifieds 5 06-01-2005 12:42 AM
Kyb AGX Shocks and Prodrive P1 springs (MY02 WRX Sedan) WReXsy Private 'For Sale' Classifieds 43 04-23-2005 02:46 AM
F.S. local, KYB AGX struts and Ver.6 springs Red Rocket New England Impreza Club Forum -- NESIC 12 02-13-2003 04:19 PM
