10-12-2006, 07:22 PM | #1 |
Member#: 31529
South East
Vehicle:1974 datsun z soon to be silver |
odd issue with idle and driving
I've already searched and cleaned the iacv like the sticky said. The car is idling high around 1700 - 1500rpm and it hesitates a little while driving. I've checked the best I could for leaks around the vacuum lines and I'm running out of options
One thing that I've notaced is when I'm driving and let off the gas in gear I'm showing .05 instead of .01 on the factory boost gauge, is that right? Input is appreciated My mods on the engine are just full catless ehaust with o2 simulator and a homemade grounding kit
10-13-2006, 02:45 PM | #2 |
Member#: 31529
South East
bump up
10-13-2006, 05:29 PM | #3 |
Member#: 882
Vehicle:2004 WRX Wagon very blue |
High idle and high closed throttle manifold pressure both point to an uncontrolled air source going to the engine. Could be the throttle plate hanging up, IACV hanging up, or a vacuum leak happening somewhere after the throttle. This would also make you tend to run a bit lean (air entering the engine that hasn't passed through the MAF sensor) and cause a stumble on tip-in.
If you can't hear the vacuum leak, you may be able to find it with a propane torch. Turn on the propane a bit (don't light the torch) and move the tip around the intake/throttle body. When your RPM jumps, you've narrowed in on the vac leak (engine just sucked in some propane instead of air). Try not to blow yourself up tho... |
10-13-2006, 10:24 PM | #4 | |
Member#: 31529
South East
Thanks man, appreciate the help, I thought it was a leak somewhere but damned if I could find it, she's now at the stealership and i'll let them tinker with it. |
10-24-2006, 12:50 AM | #5 |
Member#: 64467
Vehicle:2013 Forester XT Sage GReen |
bump did we get this figured out?
Odd issue with Rallitek/IPD swaybar | SportyMark | Brakes, Steering & Suspension | 1 | 01-25-2010 08:55 PM |
Odd issue with 05 WRX shifting | NJHK | Transmission (AT/MT) & Driveline | 3 | 07-21-2009 08:39 AM |
odd issue with idle and driving 03 WRX | rigpin | South East Region Forum | 10 | 10-15-2006 08:57 AM |
Anyone else have data stability issues with large hard drives (300gig)? | pjcoregon | Off-Topic | 28 | 06-06-2005 08:12 PM |
HELP....big problem with idle and stumbling after TGV removal and dual feed rails | subiedave | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 07-11-2003 11:18 AM |
