Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-17-2007, 10:24 PM   #1
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Default AF Learning +14.99
I am at a loss.
I have:
Stock Intake w/ K&N & Snorkus Delete
VF34
GM Boost Control Solenoid
STI TMIC
STI Pink Injectors (Cleaned and tested at Witchhunter)
Crucial Summer Cooling Kit
GT Spec II Headers
Stromung Divorced WG Down Pipe
MadDad 3CE - 3"
MadDad Whisper 3" Catback
I have a basemap from a user here that he spent many hours tuning on.
My problem, is that my AF Learning seems to always go to +14.99%
I have tried changing the Scalar from 528 up and down (all the way to 515).
I even tried changing the latency to .95 @ 11.5vdc and .65 @ 14vdc.
No combination of the Scalar or Latency table can seem to get my setup correct.
I'm thinking that there is something mechanically wrong with the car, but it runs pretty good.
My MAF seems what I would consider a bit low (225 g/s @ 17psi). I was seeing that kind of flow w/ my stage 2 setup.
I am seriously at a loss, and could really use some help from the knowledge base here.
Forgot to add, duing idle when the AF Learning is +14.99 my AFR's are rich (both stock and lc-1 concur)
I dont know what causes this issue, but when I decel, and finally stop, engage the clutch, put car in neutral, and am waiting for a signal to change, my AFR's go from 20.99 during decel down to 15, 14, 13.6.... up to 13.7 and up to around 14.6.
ZR2_S10 is offline   Reply With Quote
Old 09-17-2007, 10:38 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
the injector scalar is WAY too foking HIGH....
I generally set 'pinks' at ~480cc/min w/ stock injector latencies...also the MAF tables need to be stock.
You'll need to redo your AFR table. With these settings, the Target AFR in the table will match very very close to a WB02 reading(within 0.2AFR of my LM-1.
testes1010 is offline   Reply With Quote
FS : (NJ) 17"x7" Kosei K1 TS, Silver Set(4)+2, 5x100, 14.6 lbs/ea! 02DaWeRXs Wheels/Tires 62 01-06-2011 10:41 PM
Spare rim and tire for 99 Forester trevoro NWIC Private Classifieds 3 06-07-2010 01:38 AM
99 OB Trans overhaul, Valvebody from IPT or EcuTuning? Farmboy0007 Transmission (AT/MT) & Driveline 1 06-03-2010 12:28 PM
2002 WRX problem with AF learned values... Chi_San Open Source Reflashes 4 10-13-2009 03:15 AM
Consequences of Changing AF Learning Ranges? williaty Open Source Reflashes 0 02-18-2008 11:53 PM
