Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 02-06-2008, 07:55 PM   #1
Kahn23
Member#: 161569
2006 WRX Stage 2
Crystal Grey Metallic
Default Where is the proper place to run boost controller/gauge hose?
I'm just wondering where the proper place is to put the boost gauge/controller hose?
I know that you hook up the 2 to the solenoid that comes with the controller but where exactly does the third hose go???
Any pics of where would be great because I think mine is hooked to the wrong place and I am not reading correctly.
If it is in the wrong spot do I just use a T-fitting and splice it into the correct line??
Thanks
Kahn23 is offline   Reply With Quote
Old 02-06-2008, 08:04 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
boost gauge t's into the line coming off the bpv. not sure how you hook it up with a boost controller though. why do you even have a boost controller?
Old 02-06-2008, 08:29 PM   #3
Kahn23
Member#: 161569
2006 WRX Stage 2
On there when I bought the car. Tried returning to stock and now am not achieving correct boost levels (according to the gauge) and doesn't feel right. Seems to be wastegate. I kept it on as just a gauge. I have tried pretty much everything else except a pressure test for leaks which i will do tom. or Fri. Another member that I met and flashed me stage 2 said he hooked his gauge up somewhere else. I just wasn't sure where it should go or if this would make that big of a difference. Like I said I'm out of ideas.
Thanks
I want to buy wheels - where is the best place to go T.McRally Tire & Wheel 3 11-09-2009 10:38 PM
Where is the best place to get the AP v2? YCT AccessPort 9 01-07-2007 02:58 PM
[EGT,OIL]Where is the best place to install the sensors to my gauges in the engine? west Interior & Exterior Modification 2 05-06-2005 10:04 PM
where is the cheapest place to buy the vf23? EJ22Boom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-10-2005 06:12 AM
Where is the best place to get the VF23 waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-24-2003 03:56 AM
