Welcome to the North American Subaru Impreza Owners Club Tuesday April 7, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 04-23-2010, 11:50 AM   #1
Built Industries
Vendor Sales Rating: (24)
Member#: 33839
Default Super Mega Coilover Sales- BC/Tein/KW/Eibach/Megan
Christmas comes early for subaru community in the form of awesome coilover deals!! We are offering free shipping on all orders over $1,000 (that covers just about all of them!!) We stock all the major brands and are not limited to what you see here!!
BC Racing BR Coilovers
Pillowball upper mount
Camber adjustable top mounts
Aluminium top plates
30 way adjustable damping
Adjustable spring platform
Height adjustment via bottom mount to retain full damper travel
Bearing mounted upper front spring platform
Dust boot to protect damper seals
* some features are dependent on model
Tein Flex Coilovers
Flex coilovers are designed to provide the ultimate balance between comfort and performance. They are a completely different coilover from the Basic/SS line, utilizing a fully threaded shock body that is adjustable both at the spring perch and lower shock body for independent height and spring preload adjustments. The twin-tube damper design makes for improved reliability and longevity. These are Tein's street/competition coilovers; they can be tuned for street use but will also be comfortable on the racetrack or autocross course. Tein Flex coilovers include upper mounts and are also fully rebuildable, making them a complete long-term solution.
KW Variant 3 Coilovers
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Independently adjustable damping technology -rebound and compression damping
"inox-line" stainless steel technology
Individual height adjustment
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Infinitely adjustable rebound damping
14- level adjustable compression damping
Unique, independently functioning damping power adjustment
Eibach Pro-Street Series Coilovers
Eibach WRX Pro-Street S coilover kits are high performance coilovers that features quick adjustable lowering but do not offer adjustable shock damping. Pro-Street S setups are designed for street use and are, in essence, a reasonably priced, balanced solution to purchasing shocks and springs for your Subaru WRX & STI. They feature a rust free stainless steel shock bodies and utilize the OEM suspension mounts to make installation and maintenance a trouble free.
Megan Racing Coilovers
Features:
Spring Rates: 10kg Front and 6kg Rear
32 Levels of Adjustable Damper
Front Adjustable Camber Plates
Pillow Ball Upper Mounts.
Rubber Dust Covers.
Adjustable Ride Height
Aggressive Spring Rates
Single-Cyliner Design
Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
All coilover damper kits come with 1 year manufacture-defect warranty.
All Hardware is Included
__________________
[B]321.304.4908[/B]
Mike/ Sales -
Mike Cell - 850-341-1072
General Inquiries -
For "package pricing" please email instead of messaging on NASIOC, please include your first and last name!
Built Industries is offline
Old 04-23-2010, 03:07 PM   #2
Built Industries
Member#: 33839
The day is coming to a close so get your orders in!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 04-26-2010, 09:58 AM   #3
Built Industries
Member#: 33839
HKS Hipermax III Coilovers
Hiper Linear Piston Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
Strengthened rubber upper mounts enhanced durability
Monotube design
Shock-body length adjustable (most applications)
65mm diameter springs Cold wound and manufactured in-house at HKS to ensure quality and consistency
Stainless lock nut & ride height adjuster feature anti-rust & corrosion characteristics for enhanced durability.
30-way adjustable dampening
Hard chrome-plated cylinder shaft
Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
Pillowball upper mounts optional on certain applications
Dustboots standard
1 year limited warranty
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 04-27-2010, 11:13 AM   #4
Built Industries
Member#: 33839
Replied to all PM's and questions! Lets keep this awesome deal goin!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 04-28-2010, 09:30 AM   #5
Built Industries
Member#: 33839
Default D2 Racing Sport Coilovers
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts, on most applications . Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 04-28-2010, 10:55 AM   #6
greenc51
Member Sales Rating: (3)
Member#: 154681
2012 135i
Alpine White
prices for all available coilovers for an 08 wrx?
greenc51 is offline
Old 04-29-2010, 10:55 AM   #7
Built Industries
Member#: 33839
^^ you my friend, have a message =)
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 04-29-2010, 12:48 PM   #8
vi3tboy
Member Sales Rating: (1)
Member#: 187017
2006 WRX
prices and deals for the coilovers for an 06 wrx please.
vi3tboy is offline
Old 04-30-2010, 09:54 AM   #9
Built Industries
Member#: 33839
^Sent you a PM my friend!
Its Friday but that doesnt mean the deals end just yet!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-02-2010, 02:55 PM   #10
sackytar
Member Sales Rating: (48)
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Can I get a price on these.
BC Racing BR Coilovers 02-07 WRX
Thanks Rob
sackytar is offline
Old 05-03-2010, 09:40 AM   #11
Built Industries
Member#: 33839
Tein Electronic Dampening Force Controller
This optional product makes it possible for the driver to control the damping force by controlling a motor installed in the shock absorber while being seated in the driver's seat. Since the damping force can be manually controlled with ease to meet different situations, the driver can enjoy variations in the suspension setting. Go from living your life a quarter mile at a time to Sunday cruising at a buttons press. The EDFC can control the 16 different stiffness settings and can also be put into 32 setting mode which adjusts in half-step increments for the purists and control freaks. The compact (approximately 3.5" wide x 1" tall x 4" deep) control box is easy to mount, making it a great add-on.
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-03-2010, 09:47 AM   #12
Built Industries
Member#: 33839
Thanks Rob
Sent you a message!
Thanks Rob!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-05-2010, 10:29 AM   #13
Built Industries
Member#: 33839
All PM's replied to! these are going a lot faster than i thought so scoop yours up before they're gone!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-06-2010, 10:40 AM   #14
Built Industries
Member#: 33839
Quotes sent out!! Dont be afraid to ask!! The worst that could happen is I give you a great a great deal
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-07-2010, 09:22 AM   #15
Built Industries
Member#: 33839
Replied to some more PM's. Its friday and im ready to make stuff happen!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-10-2010, 10:07 AM   #16
Built Industries
Member#: 33839
Back to the Monday Grind! Lets make this a great week!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-12-2010, 09:19 AM   #17
Built Industries
Member#: 33839
Another set of BC's and Megan racing coilovers gone! these are going fast!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-12-2010, 10:38 AM   #18
redimpreza09
Member#: 220441
how much for a set of megans for a 09 impreza2.5i
redimpreza09 is offline
Old 05-13-2010, 02:47 PM   #19
Built Industries
Member#: 33839
^ Sent you a PM buddy. Got them in stock!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-17-2010, 10:29 AM   #20
Built Industries
Member#: 33839
Replied to all the PM's from this weekend, and Sent out a couple more coilovers!! Lets keep this awesome deal rollin!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-18-2010, 11:31 AM   #21
Built Industries
Member#: 33839
Need a full suspension package?!? Ask me about the deals we got goin with Sway bars!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-19-2010, 10:01 AM   #22
Built Industries
Member#: 33839
Half way through the week, and these are flying off the shelf!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-21-2010, 10:56 AM   #23
Built Industries
Member#: 33839
Sent out some more qoutes today. Who else wants one!!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-24-2010, 03:56 PM   #24
Built Industries
Member#: 33839
Running out quicker than i thought on these haha! Lets keep this awesome Sale going again this week
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Old 05-25-2010, 09:04 AM   #25
Built Industries
Member#: 33839
The month is coming to a close, so get your deal before its gone!
__________________
[B]321.304.4908[/B]
Mike/ Sales -
General Inquiries -
Closed Thread
HOLIDAY DEALS! ~ BC Racing | KW | Whiteline | Kartboy | TiC | Megan | Koni & More! Circuit Motorsports Suspension/Brakes/Handling 109 01-14-2010 12:27 AM
The Serious Suspension Super Sale Post! Tein, Perrin, Hotchkis, Eibach! JSC Speed Suspension/Brakes/Handling 65 05-26-2008 08:13 PM
NY: super mega parts sale GC and GB OEM and aftermarket turbocolin Private 'For Sale' Classifieds 49 03-21-2006 02:49 PM
Tax Return Coilover and Spring Kit Super Sale Cusco, Tein, Perrin, Espelir, Eibach Spun Autosports Suspension/Brakes/Handling 14 02-18-2006 04:44 PM
