03-21-2017, 02:27 PM | #101 |
Member#: 210371
Vehicle:2002 hybrid 16gxt '03 Lifted TS |
Since I'm using the 2002 wrx heads and intake manifold, I'm sticking with the stock system. The extra block vent is capped off.
03-22-2017, 01:56 PM | #102 | |
Member#: 57969
Vehicle:2004 WRX WRB |
Is this what was recommended by your engine builder or your own reasoning? I've heard different things from different people but your plan seems to be the most common. |
03-22-2017, 02:00 PM | #103 |
Member#: 459680
Vehicle:2015 WRX STI |
Wow***128563; Me likey
03-22-2017, 02:11 PM | #104 | |
Member#: 210371
I did mention this to my builder at one point when I asked if capping the one breather port was ok. He said not to worry about it as its main design was to aid in the AVCS, which I don't have. He said to mimic what the 2.0 block would be like, so I did. And yes, it seems that most of us hybrid guys who don't have the variable valve stuff cap the one breather port. |
03-31-2017, 09:34 AM | #105 |
Member#: 210371
Small update. The engine is coming out this weekend. I don't know if I'll tear into it at all, or just let Andrewtech do it. Then, on April 14th (thankfully my work has that day off) I'll drive down to them and drop the engine off. While they have things apart..again...I'll have them install a few new items.
- APR headbolts: I don't think I really need them, but it's one of those "I'm in there already" things. - shimless buckets: If I had done this in the first place, I might not be in the position I'm in now. - new valves: this is undecided as of yet. Will be determined by the shop if they should be replaced. - oil dipstick and tube: I have an STi oilpan, but a WRX tube/stick. Functions correctly, but full/low spots are wrong. I don't want to have to guess when changing oil. Do it right. - TGV deletes: I'll let Andrewtech decide what to do there. Either delete factory, or buy aftermarket (IAG). - 3mm phenolic IM spacers: again, don't really need them, but... |
03-31-2017, 08:22 PM | #106 | |
Member#: 343367
Vehicle:2002 rotated gt3076 |
Why do you say the shimless buckets would've changed that? Curious because I have shim style buckets in my engine. I do plan to change them but I can't flip the $350 for buckets right now. |
04-02-2017, 02:51 PM | #107 |
Member#: 108091
Vehicle:2002 WRX |
Can't believe I missed this update. Hope everything turns out with the block. I really can't wait to see how this pans out on the dyno. fingers and toes still crossed for you brother.
04-03-2017, 08:02 AM | #108 |
Member#: 210371
I suspect the cause of the leaking valves would be on me as I adjusted valve lash. If the shop had done the bucket swap, it would have been good to go. If it's not lash, and something like the seat of the valve, then they would have seen that when they did the buckets.
04-03-2017, 08:03 AM | #109 |
Member#: 210371
04-03-2017, 08:59 AM | #110 | |
Member#: 343367
I just had an issue with my engine and valve lash. I paid the machine shop to set the valve lash and when I checked the lash (after torquing to heads) they were way off. Intakes as tight as .005 some exhaust as tight as .007 and some loose as .016. Have you checked the lash after torquing the heads on? |
04-03-2017, 09:08 AM | #111 | |
Member#: 210371
We'll see what happens once they look at things. I pulled the drivers side valve cover off last night and saw a little oil pooled on one valve. I didn't look any further at that point. |
04-03-2017, 09:18 AM | #112 | |
Member#: 343367
Adjusting the valve lash is a huge pain unless you're just going to order new buckets for everything. Even if you don't plan to do it at this point you should at least measure the lash so you know what it is for your own peace of mind before you sent the engine out. |
04-03-2017, 09:22 AM | #113 | |
Member#: 210371
04-03-2017, 09:24 AM | #114 |
Member#: 343367
Yep. You never think it's going to take as long as it does. I have my fingers crossed you got lucky enough to only need the lash adjusted or something else minor like that!
04-18-2017, 09:21 AM | #115 |
Member#: 210371
UPDATE:
Good news: The block is fine. They took the heads off and looked at the cylinder walls. No issues at all, which means they don't have to split the case or replace any of the seals/bearings. Bad news: The heads are ruined. Cam caps are wrong. Lash is completely incorrect (was told that some of them would never have been correct, even with the largest/smallest shim). All valves bent. None of the valves were seated properly. So, I had two options. First was to get a set of new or used heads, new valves, and transfer my parts over. Second option was to machine my heads for +1mm valves, new valves, and reinstall the other parts. Cost difference between the two: about $50. I went with the larger valves. I should know how things are progressing in a few days. |
04-18-2017, 10:07 AM | #116 |
Member#: 108091
Vehicle:2002 WRX |
****ing boss!!!!!
04-18-2017, 10:20 AM | #117 |
Member#: 210371
This is turning into a much larger budget than I wanted, over a much larger time period, but with all the delays I've had, along with the issues, the final price has gone up. But, in the end, it will be a much better build with a higher power potential. If in a few years I decide to bump up again, I should only have to replace the turbo, and possibly the fuel pump. Everything else should be good to use again.
I can say though that if all these issues didn't happen, the final price would have been very reasonable. |
04-19-2017, 11:26 AM | #118 |
Member#: 210371
Items to add to the list, which will be made in full once the engine is reinstalled and started since I suspect I'm going to change things a little using parts I already have:
- +1mm Supertech intake and exhaust valves - ported and polished heads (if any of you remember Unabombers heads that he got...yeah...same port job) - 11mm ARP headstuds - shimless bucket upgrade |
04-27-2017, 11:12 AM | #119 |
Member#: 210371
04-27-2017, 11:18 AM | #120 |
Member#: 343367
Sorry if I missed it but are you using hybrid pistons?
04-27-2017, 11:29 AM | #121 |
Member#: 210371
04-27-2017, 11:53 AM | #122 |
Member#: 146760
RMIC
Vehicle:2004 WRX Wagon WRB |
Good news on the heasds, though I've heard +1mm valves aren't worth it. Did they machine for larger seats or use the stock size? Maybe that's the difference.
Will be interesting to see what you put down. Which head gaskets/thickness are you using? |
04-27-2017, 11:57 AM | #123 | |
Member#: 210371
Power: you and me both. Before all this head work, we guessed around 350whp, with 375tq. Now...who knows. As to which thickness head gaskets, no idea. I'll let the shop deal with that. |
04-27-2017, 12:14 PM | #124 |
Member#: 343367
Awesome I'm excited to see how it does. I chambered my last hybrid and I'm planning on doing another but haven't decided what route to go on my heads yet
04-27-2017, 01:36 PM | #125 |
Member#: 210371
I considered doing the same, but since I was putting forged pistons in, the JE hybrids killed two birds with one stone.
