01-17-2010, 10:12 PM | #1 |
Member#: 75378
Vehicle:1999 Forester Silver |
Cruise Control Issues
Hey everyone - having an issue with my cruise control. Sometimes when I try to engage the CC it takes a few tries. once it engages it seems to only stay on for a few seconds and then cuts out.
Do you think I should replace the unit? Does the CC in a WRX need a vaccum line running to it? Right now I just have the line to the throttle body but heard that in the older RS there is also a vaccum line. Thanks!
01-18-2010, 01:00 AM | #2 |
Member#: 176490
SWIC
Vehicle:2005 STI WRB |
Check the tension on the cable might be loose
01-18-2010, 09:22 AM | #3 |
Member#: 75378
IF so, how do I create more tension?
01-18-2010, 11:13 AM | #4 |
Member#: 151045
Are you getting any CEL's? Depending on the CEL it can automatically disengage your cruise control. I would check on that first before making any cable adjustments.
01-18-2010, 11:41 AM | #5 |
Member#: 75378
I do not have any CELs thankfully. I have had this issue for a few years but kind of ignored it. I have tried to run the CC in times where I did and did not have a CEL with the same end result.
01-18-2010, 12:18 PM | #6 |
Member#: 151045
Check by the throttle body for the cruise control cable. There are some adjustment nuts to increase or decrease the tension on the cable. I would check with the service manual for the correct procedure because it can make things worse...
There is also a little black box near the passenger side strut tower. That should be the tensioner for the cruise control cable--you can trace the cable back from the throttle body to find it. I believe it is motorized, but not positive. |
Cruise Control Issue | losinspace | Service & Maintenance | 1 | 07-12-2009 09:47 PM |
STi Cruise Control issue | Engmus | Service & Maintenance | 10 | 12-05-2008 04:21 PM |
cruise control issues | rok_toy | Service & Maintenance | 5 | 12-23-2007 06:05 PM |
cruise control issues | knadsady | Newbies & FAQs | 0 | 10-10-2007 12:17 AM |
Cruise Control Issues | jimithing412 | Service & Maintenance | 2 | 12-04-2002 12:36 PM |
