02-01-2002, 09:00 AM | #1 |
Member#: 4418
Vehicle:2019 CTR White |
headlight - how to take bulbs out??
I got some of those 'ultra cool' pretty white color light bulbs & today one of the fickers burnt out .
How do I remove my llight bulbs??? I know you disconnect the plug on the back, but how do you get the sucker out?? I sorta forgot since its been about 4 months since theyve been in there. thanks, -justin edit-- wrong subject
02-01-2002, 11:00 AM | #2 |
Celebrity Guest Star
Member#: 10648
NESIC
Vehicle:2008 Acura TL Wicked Black |
Rotate off the backing plate, remove the clip/ plug assy, and pull out the bulb. Not sure if you need to rotate the bulb. don't remember. I don't think you do. The plugs can be stubborn.
When installing, make sure you don't touch the bulb. oils from your skin will get on it, heat up, and break the bulb. Thats bad. -IggDawg Does replying to an obvious "do a search" thread count as post whoring ? |
FYSA Accessory switch light bulb part numbers. | steven765 | Electrical & Lighting | 0 | 09-02-2009 10:44 AM |
Need a few Light Bulb Part Numbers | toadie | Interior & Exterior Modification | 10 | 02-15-2006 07:03 PM |
2004 fog light bulb part number??????? | tweekernyc | Electrical & Lighting | 1 | 12-22-2004 06:18 PM |
hazard light bulb part number | Puckman | Electrical & Lighting | 1 | 06-15-2004 12:43 PM |
corner bulb part number/PIAA number | BadDogNoBiscuits | Electrical & Lighting | 6 | 02-18-2003 02:47 PM |
