Welcome to the North American Subaru Impreza Owners Club Thursday September 23, 2021
Old 09-15-2021, 12:40 PM   #1
UKPR1
Member#: 525602
Default Basic Ignition Fuse Question
So I replaced my turbo, and all the tutorials suggest pulling the ignition fuse to prime the turbo with oil without allowing he car to run. On the inside fuse block on my 2008 Impreza WRX, I can't seem to find the obvious fuse on the diagram marked IG or IGN. So...which one is the correct fuse? I've done my research here and elsewhere, and #11 seems to be referred to the most, but on my fuse panel diagram, it doesn't refer to IGN at all. I don't want to pull the pump relay in the engine bay, as that may allow the car to run for a minute or so, which I don't want to happen.
So - can anyone help me out, please?
Geoff
UKPR1 is offline   Reply With Quote
Old 09-15-2021, 12:58 PM   #2
cdska
Member#: 458809
05 blob, 02 bug
Dunno, but if you unplug the cam and crank position sensor and it will absolutely not start
cdska is online now   Reply With Quote
Old 09-15-2021, 01:01 PM   #3
UKPR1
Member#: 525602
Good Plan B that might end up being Plan A! Thanks!
Old 09-15-2021, 01:47 PM   #4
xtremewlr
Member#: 525652
2006 STI
WR Blue
Which fuse panel are you looking at? The one in the engine bay or in the cabin?
Some quick google searching is telling me that the 08 doesn't have an ignition fuse and you should pull the fuel pump relay fuse instead.
xtremewlr is offline   Reply With Quote
Old 09-16-2021, 01:10 PM   #5
UKPR1
Member#: 525602
Looked at both, but the #11 was referring to the inside panel, I believe.
I agree - I can't find reference to the coils being ties to any particular fuse - even though they have to be, right? I thought of pulling the fuel pump relay, but I didn't want it to run even for 30 seconds from burning any residual fuel it had sitting in it's lines.
Geoff
