Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 09-07-2001, 04:29 PM   #1
Imprezafan1
Member#: 4039
2015 WRX
Default Do they make KYB/AGX for '01 RS Sedan
Wanted to lower my car and heard that the KYb/AGX's were cool. But i also heard that they don't make them for the 01's RS yet? Can someone help along with recommended springs? My goal is to lower my car to make it look nicer. Performance and handling would be great also.
Imprezafan1 is offline   Reply With Quote
Old 09-07-2001, 04:34 PM   #2
JGard
pooptastic
Member#: 1904
2017 Impreza Sport
E36 M3/4/5
the 01 RS is the same as the 00, 99, and 98.
they are out for it...people have been using them already, so you are all set
JGard is offline   Reply With Quote
Old 09-07-2001, 04:38 PM   #3
Imprezafan1
Member#: 4039
2015 WRX
Default Cool!
So all i have to do is ask for the 98 and up set up for this car? What are the reputations on these struts and what kinda springs are best for them? Thanks man!
Old 09-07-2001, 05:09 PM   #4
Boom
Member#: 1101
04 STi
like theres a choice BLUE
Although I have never actually owned the AGX's I have heard that if you lower the car more than one inch, and you have spring rates higher than 300lbs, the AGX's blow their seals. So most people have gone with a different shocks, like the Koni's. But don't quote me on this. I am only going with what I have heard. I have actaully talked to 2 people who have blown the AGX, but its cause they were running too high of a spring rate, and they lowered the car too far. If you stay within the limits of the shock you will probably not have any problems.
Hope this helps a little
Steve
99 White RS
Boom is offline   Reply With Quote
Old 09-07-2001, 05:41 PM   #5
Fido
Member#: 1867
Plenty of people have the KYB-AGXs . I have heard a few things about people blowing them up, though, but I've always thought that they were one tough strut.
Fido is offline   Reply With Quote
Old 09-08-2001, 09:40 PM   #6
Imprezafan1
Member#: 4039
2015 WRX
Default Thanks everyone........
In this case, are Koni's better than the KYB/AGX? I just want to lower my car so that it will make a difference in appearance. Not planning to butterfly my car and see have the wheel. Just enough so that it covers the gap in between the car and the tires. Please help anybody!!!!!!!!!! I am going to do it soon. And if you have pics, please post or email to Vince
Old 09-09-2001, 04:06 PM   #7
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
I have the Tein springs (soft) with KYB/AGX on my '99RS. Although I don't care for the Tein's (to darned low) I do like the KYB's. Easily adjustable unless you car is as low as mine then the back knobs are hard to get at.
A 3front/6rear combo seems to really help in the corners and soak up the bumps better but it increases the amount you can feel from the road undulations. I normally run a 2/4 or 2/5 for daily driving. Only the largest bumps will cause an almost bottom out. I run a 1/3 during the winter.
If I had to do it all over again I would have gone Eibach or H&R or what I am doing now; saving for DMS Golds.
spshultz is offline   Reply With Quote
Old 09-10-2001, 02:45 AM   #8
Imprezafan1
Member#: 4039
2015 WRX
Default Why?
Why Eibach and H+R's. Are those better? Dang wat should i get? What best fits the IMpreza
Old 09-10-2001, 10:06 AM   #9
JGard
pooptastic
Member#: 1904
2017 Impreza Sport
E36 M3/4/5
if you want a good suspension set up, which lowers the car nicely...
go with the Bilstein Prodrive setup. Fishguy has it, and it's just plain awesome. Great looking and great handling.
Old 09-10-2001, 04:05 PM   #10
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
I'm running KYB-AGX and 1.5" drop, all is good. look good feels even better. shocks 390.00$ shipped from Cox auto on the Group Buy center. no pics but no gap in the rear and 1/2" front get STI mounts to Primitive has a good deal on them. 1.5" drop is the max before KYB will void your warranty, and no coller type springs i/e ground control
milkman is offline   Reply With Quote
Old 09-11-2001, 12:28 AM   #11
codemunky
Member#: 1804
Eibach Pro springs and KYB AGX seem to be one of the best setups...as I was told. Pro springs don't lower the car too much. I've had them for 2 months, they seem pretty fine, although the springs on the left side has been worn a bit more than the right, which is probably because I hardly use my brakes on right hand turns...
codemunky is offline   Reply With Quote
Old 09-11-2001, 02:05 AM   #12
Imprezafan1
Member#: 4039
2015 WRX
Default THe gap in front?
I have noticed that the gap in the rear is covered when spring and struts are in, but whats with the sider gap in the front? And how much higher are the Eibach Pro Kits compared to others like Ground Control or Skunk Works.??? PLease help people.
WTB: kyb agx for 02 WRX sedan! FRONTS ultramagnus Private 'Wanted' Classifieds 0 11-23-2007 12:53 AM
how do i make KYB AGX struts for an 04 wrx sedan fit my 02 wrx sedan? dln84 Brakes, Steering & Suspension 7 05-26-2005 12:33 PM
WTB: KYB AGXs for '02 WRX sedan Hank3 Private 'Wanted' Classifieds 10 12-14-2004 09:45 AM
Do they make kick panels for the WRX yet? juztin180 Car Audio, Video & Security 1 01-11-2003 09:24 AM
do they make cf mirrors for WRX? scoobypuff Interior & Exterior Modification 11 05-03-2002 01:39 PM
