03-28-2003, 09:41 PM | #1 |
Member#: 15604
Vehicle:2002 wrx Back in Black |
2.2L gauge question
Alright, i know this topic has been beaten to death, and i already did a search on it, but to no avail...I am installing an Autometer Air/Fuel Ratio gauge on my 01' 2.2L. I followed the instructions on Scoobymods.com, and ravensblade.com, HOWEVER, that is for a 2.5 RS....My question is, are the ECU pinouts the same? will it still be B136, wire #18? If not, anyone know what pinout it is for the "L"? or where i can find the proper info? My ECU appears to be set up the same as the one i have seen in the pics on both of the aforementioned sites, but i want to be sure before i go messing with random wires on the ECU...Any and all information is greatly appreciated...Thanks!!!
-Mark-
03-28-2003, 11:04 PM | #2 |
Member#: 4133
Vehicle:'01 2.5RS Sedan '05 LGT Wagon |
Mark,
There are a couple of differences in the ECU wiring between the 2.2L and 2.5L. I know for my '00, the Rear O2 Sensor - Signal, is in fact the same as the 2.5L - B136 #18. I don't think there were any changes between '00 and '01, but no guarantees. Others who have more accurate info please chime in... I suggest going to your closest, friendliest dealer and try to get a photocopy of the pinout diagrams for your year (it's in the Diagnostics book). Best of luck. Ron |
03-29-2003, 05:32 AM | #3 |
Member#: 20508
Vehicle:1998 Red Wagon New Turbo Project... |
I don't know if the ECUs are the same on the 97s as they are on the 01s, but you can compare connectors witht the diagrams on http://wac.addr.com/auto/obs/ecu1.gif
When I hooked an A/F gauge on a 1990 Legacy with no pinouts I just used a digital multimeter and a long peice of wire. Hooked one end to the white wire on the front O2 sensor and checked the few white wires on ECU connector until I found one without infinite resistance. Only took 10 min and I knew I had the right wire for sure. -Brad |
03-29-2003, 08:55 PM | #4 |
Member#: 15604
Thanks for the responses guys.....i'm going to wait till early next week and see what else shows up on here...i also recieved a response to an e-mail i sent out to Ravensblade regarding this question and he said pretty much the same things...look for a white wire in the B136 #18 position...i'm gonna make a couple of calls and see what else i can find out...Thanks again......Anyone else?
Similar Threads | ||||
legacy 2.2L port question | bubaru21 | Newbies & FAQs | 7 | 07-03-2006 05:30 PM |
1999 2.2L ecu question | jwmat | Engine Management & Tuning | 0 | 04-27-2006 03:29 PM |
2.2L engine question | emyselfandi | Legacy Forum | 2 | 08-21-2005 08:04 PM |
2.2l engine questions | Valric | New England Impreza Club Forum -- NESIC | 2 | 03-06-2003 11:23 AM |
2.2L turbo question | GooseMan | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 11-04-2002 03:07 PM |
