Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 01-21-2008, 11:09 AM   #1
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Default 02 wrx and MAF limits
Hi i have heard that the 02 wrx ecu MAF pegs out at 4.69 volts.
i am reaching 4.7 volts with plenty to go while tuning with MAF mode and utec do i need to switch to SD? is this true that it pegs out at around 4.69 volts ? thanks
DemiSlayer is offline   Reply With Quote
Old 01-21-2008, 11:16 AM   #2
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRX Wide Wagon - Stg 3
Mine reads 4.9-5.0V all day long in my utec logs... stock MAF is 0-5V so you still have plenty of room left.
jstbstn is offline   Reply With Quote
Old 01-21-2008, 11:24 AM   #3
DemiSlayer
Member#: 120339
02 WRX
Thanks man. was told the stock ecu has a limit but was not sure how that related to the utec. also is it worth switching to SD if everything is running fine with MAF tuning. am running a VF22
Old 01-21-2008, 04:48 PM   #4
jstbstn
Member#: 35020
02 WRX - Stage WTF
if everything is running well you don't need to change to SD... there are alot of good threads about using SD so depending on what you need/prefer you may want to read up on it.
Old 01-21-2008, 06:18 PM   #5
DemiSlayer
Member#: 120339
02 WRX
Thanks.
FS: 02 WRX TMIC, MAF, and air box unforgiven2144 Engine/Power/Exhaust 1 06-22-2009 03:05 PM
Early 02 WRX and late 02 WRX??? Huh? japslapr General Community 11 08-29-2008 07:25 PM
Does 02+ WRX and 02+ RS have same clutch line? awd4ever Transmission (AT/MT) & Driveline 1 10-25-2006 02:00 AM
02 WRX and 02 SVT focus *nightshots* Unknown_Driver Member's Car Gallery 7 09-26-2006 01:24 AM
02 WRX Auto Speed Limiter tjamz Engine Management & Tuning 4 09-12-2003 12:16 PM
