07-30-2017, 10:58 PM | #1301 |
Member#: 326345
Vehicle:2012 5-Door Premium Ice Metallic Silver |
Svxdx, you're a beast. Thanks for doing that. I was going to make him read the 51 pages
07-31-2017, 07:26 PM | #1302 |
Member#: 471974
Vehicle:2014 WRX Rally Blue |
Thank you very much!!
10-24-2017, 12:02 AM | #1303 |
Member#: 326345
If anyone is looking, I am considering selling my CP635U1 with the SiriusXM Satellite Radio module and adapter for rear view camera. Might be posting to classifieds in the next few weeks.
11-08-2017, 01:40 PM | #1304 |
Member#: 477258
I can't seem to buy an the CP635U1 head model in Singapore.
Anyone know of one or have one up for sale, maybe even from USA. Delivery can be done with the help of this company 6connect.biz . |
11-08-2017, 01:51 PM | #1305 | |
Member#: 471974
11-08-2017, 06:24 PM | #1306 |
Member#: 326345
Not sure if that was a post looking for a radio or a post promoting a website I've never heard of. If you want to talk further Kimmy, I am likely selling mine soon, drop me a private message
11-21-2017, 06:02 PM | #1307 |
Member#: 478077
Hello, can you please tell me if i can replace the oem CZ424L1 with CP435L1 from aliexpress, and all the features including Bt will work?
Is it plug and play or needs modifications? I own a Impreza XV 2010 and I did not found any information about my radio model. I have the 3 Bt buttons under the steering wheel |
11-24-2017, 12:54 AM | #1308 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
If you want to add a rear camera, you'll need to add a wire to a vacant slot on your car's 16-pin aux/mic harness plug to supply the reverse gear signal to the display HU, plus an 8-pin rear camera harness (and a camera). I probably gave more details about that somewhere earlier in this thread. It's probably not a Crosstrek. Maybe just a 5-door (hatchback)? And is the 10th digit of your VIN "A" (for 2010) or "B" (for 2011)? That's the model year Subaru considers your car to be. |
11-24-2017, 03:29 PM | #1309 |
Member#: 478077
Thank you for the answer.
It's considered 2011 but it is first registred in September 2010. Impreza XV it's the "limited edition", if I can say that, for the normal 5 door Impreza. It has the moulded plastic wheel arch protector and roof rails |
11-24-2017, 11:00 PM | #1310 | |
Member#: 25837
South East
2013 Crosstrek rear badge picture |
11-25-2017, 06:41 PM | #1311 |
Member#: 478077
12-09-2017, 09:52 AM | #1312 | |
Member#: 478954
12-10-2017, 05:58 PM | #1313 | |
Member#: 478954
Please clarify if the additional wire is connected between 8-pin harness and 16-pin harness . Also, wich are the pins of each harness where this additional wire is connected. Many thanks! |
12-12-2017, 06:39 PM | #1314 | ||
Member#: 25837
South East
Connect the free end of that wire to your car's +12V reverse gear signal. You can tap that from a factory harness behind the passenger kick panel (near the door hinge), or near the reverse bulbs (near the camera). Some aftermarket rear cameras have an extra red wire embedded in the long video cable. You can use that to send the reverse signal from the back of the car to the HU. Or use that to send power from near the HU to the camera. |
01-16-2018, 09:07 AM | #1315 | |
Member#: 478954
04-09-2018, 04:01 PM | #1316 |
Member#: 259919
SCIC
Vehicle:2011 WRX Hatchback SWP |
Thank you SVXdc!!! Upgraded my WRX to a 2013 Forester HU with a Rydeen duo back up camera using your 8-pin camera harness. Thanks to the guys at Safe and Sound Auto Design in Woodland Hills, CA. And thank you Suba_WRX for the awesome screen saver (post #524).
04-15-2018, 10:29 PM | #1317 |
Member#: 355716
W. Canada
Vehicle:2012 WRX Premium Gray |
I got the harness from svxdc and a forester head unit CP635U1 and connected the backup camera to it. Powered the backup camera from the reverse lights but the head unit doesn't switch to the reverse camera when I put the car in reverse. After a bit of digging I found a diagnostic mode in the head unit (turn off and rotate the right tuning dial while pressing the preset button 6) and that shows me the camera input when I'm in reverse.
Any idea why it doesn't automatically switch in normal mode? |
04-16-2018, 12:07 AM | #1318 |
Member#: 326345
The head unit stays on whatever function you were on? Or shows you a black backup screen? What model are you putting it in? Svxdc has a pin break out that shows the reverse signal...might want t make sure it's all good. Could it be the head unit?
04-16-2018, 03:46 PM | #1319 |
Member#: 355716
W. Canada
Yes, the mode/function of the head unit doesn't change
2012 Subaru Impreza WRX Premium in the hidden diagnostic menu it shows the camera signal when the car is in reverse and a black screen otherwise so that makes me think that the harness is good |
04-17-2018, 09:46 AM | #1320 |
Member#: 326345
Try disconnecting the positive line from the reverse lights. If you're seeing the camera through diagnostic, that means the camera is getting powered without the reverse light feed.
04-18-2018, 03:18 PM | #1321 | |
Member#: 25837
South East
The diagnostic menu also shows you the status of several signals, including reverse gear. I'm guessing that's never showing it "on." Right? As I explained back when you ordered the camera harness from me, WRX and STi models like yours lack that signal. You must also add a wire with that signal to pin #16 on your car's 16-pin aux/mic harness plug. I provided a wire with the proper OEM-style (Japanese) terminal for you to do that. The opposite end must be tapped into a factory wire behind the passenger kick panel (near the door hinge). Did you not install that wire? |
04-18-2018, 04:56 PM | #1322 |
Member#: 484052
Vehicle:2011 Impreza WRX WRB |
Got my CM631UD installed this morning. Purchased via eBay for $70, it came out of a 2014 Impreza. Installation was straightforward and it is a much better radio than the stock unit. I can now see all text from the albums and songs being played from my iPod and iPhone, and the interface is much better. Bluetooth works a little better too, though I still need to manually pair the phone after starting the car.
https://i.imgur.com/DZwJjgC.jpg |
04-19-2018, 12:05 PM | #1323 |
Member#: 95825
SCIC
Vehicle:2011 WRX Hatch SWP |
04-24-2018, 01:04 AM | #1324 |
Member#: 485027
Will any of these radios below work with a 2010 Forester? I don't need sat, bluetooth, usb. What I need is AM/ FM, maintain the controls on the steering wheel and a backup camera which will need to be newly installed.
(radios with 4.3" screens listed in SVXdc's post #1300) Last edited by wazzabie; 04-28-2018 at 03:53 AM. |
04-27-2018, 08:55 PM | #1325 | |
Member#: 25837
South East
Subaru made a significant change to the SWCs on 2011-up models with the phone/Bluetooth buttons. In previous models, there were only 2 wires between the SWCs and the radio's 20-pin power/speaker harness. On the models with BT SWC buttons, Subaru added a 3rd wire for those, and changed all of the resistor values. None of the SWC buttons in 2008-2010 models (Impreza, WRX, STi, Forester) have the proper resistances for a 2011-up radio designed to work with the phone/BT buttons. To have working SWCs with one of the 4.3" HUs, you would need to retrofit the SWC buttons from a 2011-2014 model. That would also require that you swap in a roll connector from one of those models (to support the 3rd SWC wire between the wheel and the HU). All of that is doable, but may be more effort and expense than it's worth, unless you have a nearby cheap source for salvaged parts. If your main goal is to add a rear camera, you'll probably find it easier and cheaper to install an aftermarket HU. See this 'parts needed' guide. |
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket | SubeDooS | SCIC Private Classifieds | 1 | 04-14-2011 03:05 PM |
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims | johnpaulm1208 | Tri-State Area Private Classifieds | 1 | 04-06-2011 10:32 PM |
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale | mug23 | Suspension/Brakes/Handling | 3 | 06-26-2008 12:35 PM |
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? | ScoobyNubieToo! | Car Audio, Video & Security | 3 | 02-11-2008 08:26 AM |
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires | singincanary | Private 'For Sale' Classifieds | 5 | 08-30-2005 08:50 PM |
