11-07-2018, 07:28 PM | #26 | |
Member#: 198067
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
11-07-2018, 07:54 PM | #27 |
Member#: 385604
Vehicle:2012 WRX |
11-08-2018, 09:10 AM | #28 |
Member#: 385604
Vehicle:2012 WRX |
How does my light pattern/cutoff look? I feel like my passengers side headlight is aimed a bit higher and never noticed that until after putting in the H9 bulbs. I did adjust the drivers side up a little and passengers side down, but it seems like I'd have to do a lot more adjustment to have them level from left to right. Wondering if I'm missing something?
Ok, I can't figure out how to attach a picture from my files! Always asks for a URL? |
11-08-2018, 10:05 AM | #29 | |
Member#: 198067
11-08-2018, 01:01 PM | #30 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Host your pics on imgur or a similar free hosting site and link to them.
11-08-2018, 03:09 PM | #31 |
Member#: 385604
Vehicle:2012 WRX |
11-11-2018, 08:16 AM | #32 |
Member#: 198067
Last night I almost hit a deer. Eyesight wasn't used, as I hit the brakes. The clock in the video wasn't set properly.
The equipment I'm using with my reflective low beam and fog housings is; 2016 Crosstrek Limited Crystal White / Black leather (GRD - 23) Moonroof Package W/Navigation/Eyesight Auto-dim Mirror/Homelink + Alarm/shock sensor + Side moldings de Auto Key 5000k HID kit Philips 9011 HIR1 Diode Dynamics XML2 5000k Fog Lights SpyTec A118-C Dash Cam I hit the brakes before the deer shows in the video. I had the HID lows and the LED fogs on. The human eye can pick up objects in lower light than the digital camera. https://redirect.viglink.com/?format...-Yrf4%3Ft%3D23 |
11-16-2018, 12:51 AM | #33 |
Member#: 493987
Vehicle:2012 WRX |
First thing that i did when bought my vehicle I switched to xenon. Buying better bulbs could help improving visability but not the actual look of ur car. I have tried a lot of bulbs and some do work but at some point you would still see the yellowish shade coming from ur headlights. I have used led for my fogs with canbus adapters to avoid blinking but wouldn't recommend installing them into headlights as they do produce heat. Some cheap versions will melt inside the headlight.
11-16-2018, 08:19 AM | #34 | |
Member#: 198067
11-17-2018, 12:28 AM | #35 |
Member#: 348705
Vehicle:2016 WRX Blue//Gray |
I went with a set of VLEDS Mirco LED headlights and fogs, huge difference. They recently discontinued the micro’s and started sell micro evolutions (supposedly brighter that micros) Only issue is that you can sometimes hear the fan on the bulb. (Very minor)
