Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 07-24-2017, 12:29 PM   #76
themullet
Member#: 232808
2017 WRX Base
'Merica
Originally Posted by Cab0oze View Post
kinda, but apparently it's called crazing in this particular case.
Do you know what caused the headlight crazing? Doesn't seem like it would be the DD-Clights because the LED's don't really put off any heat.
themullet is offline   Reply With Quote
Old 07-25-2017, 07:25 AM   #77
Cab0oze
Member#: 443914
2021 WRX
It was either from blacking out the headlights at the same time or, what I'm starting to suspect, is when I reassembled the headlights the adhesive may have briefly touched the plastic.. or maybe there was some on my gloves and I touched the inside. Something to "contaminate" the plastic lens if you will. We'll see if it keeps spreading, because if it does, it was from blacking it out because there is no way I got the whole inside of the lens dirty, I was extremely careful.
I followed Cabooze's DRL wiring instructions. Worked great and I don't have the flickering issue anymore. It is also a much cleaner looking solution than the bundle of mess I had on there.
Glad I could help
Cab0oze is offline   Reply With Quote
Old 07-25-2017, 09:54 AM   #78
themullet
Member#: 232808
2017 WRX Base
'Merica
That's unfortunate. I really wish Subaru would sell just the lens separately. I'm not sure if these headlights are clear coated, but it might be worth trying to wet sand and then spraying a coat of clear.
Glad I could help
Thanks!
Old 07-25-2017, 06:31 PM   #79
Cab0oze
Member#: 443914
2021 WRX
Yeah, I wish so too. If it doesn't get worse, I'll leave it as is until I have another reason to take them apart... hopefully I'll just sell the car as is lol and the new owner wont care/notice.
If it does get worse, I'll try and wetsand it like you suggested with my fingers crossed, and if that fails I'll throw them back together temporarily and order a new set =/ Maybe the 2018 lights will fit.... hehe
Old 07-28-2017, 01:47 AM   #80
o2_designs
Member#: 434977
Do you have laminx or film on the lens?
Maybe it's caused by what kind of paint you used? Fumes or vapors sealed in the lights or something. Not sure. I really hope I don't have the same issue
o2_designs is offline   Reply With Quote
Old 07-28-2017, 07:43 AM   #81
Cab0oze
Member#: 443914
2021 WRX
No laminx. All paint should be roughly the same in terms of solvents, and while it is possible, the headlights are vented as far as I know so it shouldn't be an issue.
BTW this is what happened to mine, I had the pictures in another thread:
Old 08-08-2017, 06:40 AM   #82
Redwood839
Member#: 472501
Hi All,
So I did this last week, and I have the Diode Dynamics harness to connect to my DRL resistor.
I have a 15' WRX STI UK Type, and I looked for the connector on the passenger side of the NA models (that's what the instructions say) which would be driver side.
Everything was there as expected, the horn, the other harnesses and everything.. but the DRL resistor wasn't there. I checked my passenger side (driver side in NA) and it wasnt there.
Is there anything I'm missing? I checked everywhere and I couldn't find it. I thought if I hardwired it to my DRL harness going into the bulb it would work, but it doesn't.
Any ideas?
Redwood839 is offline   Reply With Quote
Old 10-09-2017, 04:05 PM   #83
jvicario
Member#: 442725
Hey everyone,
I am trying to design an RGB c-light for my 2016. It will be similar to the Morimoto but with the ability to control individual LEDs. The first step would be creating a pcb layout that fits in the c-light area. I unfortunately don't have an aftermarket c-light that I could use as a reference and the only other option would be to take my headlights apart and try to create a sort of template that I can use. So, I thought I'd come to you all and see if anyone has a set of uninstalled c-lights (DD or Morimoto) that they could send me a picture of next to a ruler for scale. I would owe you big time. Thanks
jvicario is offline   Reply With Quote
Old 11-08-2018, 03:01 PM   #84
dneve85
Member#: 493759
Default Which Wire do I tap
Hello, I tapped mine into the light that was in the C-Light hole. When i turn my DRLs on it still has the high beams on low. How do I do the wiring so I can just have my diode dynamics lights on when my drls are on. Also, what do I do with the socket for the Parking lights and the C light bulb???
dneve85 is offline   Reply With Quote
Old 11-08-2018, 05:35 PM   #85
Cab0oze
Member#: 443914
2021 WRX
Per post on page 2:
https://forums.nasioc.com/forums/sho...1&postcount=35
For the socket for the old parking light bulb, I just taped it up and stowed it. I used an appropriately sized water bottle cap and caulking on each headlight to seal up the hole that the C-light wires run through
Old 11-27-2018, 03:35 PM   #86
hvuong
Member#: 494513
I just picked up my first Subaru last month and my C light doesn't seem to work and I'm not able to post a new thread since my account is too new. This thread seems the most relevant to ask this.
2016 STI Limited from the dealership so I never got to talk to the original owner. The car seems completely stock so i am unsure if there was any C-light conversions. Anyone know which fuse or settings I need to check to see if the C light is turned off or broken? Any way I can easily check if the C-light was converted to LED or disconnected? From what i can tell the C light is only on during night time, right? Also, both lights are out so i feel like it's either been disconnected or a fuse blown.
hvuong is offline   Reply With Quote
Old 11-27-2018, 06:38 PM   #87
Cab0oze
Member#: 443914
2021 WRX
AFAIK the fuses are for each circuit (1x low beam, 1x high beam, etc) and not per headlight assembly (L/R)... so if all your lights are out on 1 side, that might be a bigger problem.
Might be good to take a picture of the problem with various light settings selected. For the C-lights, a closeup of the headlight assembly might help, or otherwise look to see if you've got any non-stock looking wiring coming out of the back of the outer/upper portion of the headlights.
Old 12-17-2018, 07:32 PM   #88
UnluckyPanda
Member#: 492156
What does the white wire do specifically? If I don't hook it up, will the C Lights not turn on if my parking break is up?
UnluckyPanda is offline   Reply With Quote
Old 12-17-2018, 08:10 PM   #89
Cab0oze
Member#: 443914
2021 WRX
The white wire turns your c-lights on whenever your parking lights (or whatever you hook the white wire up to) would normally be on. Normally your parking lights are on whenever your tail lights are on. If you don't hook the white wire up you will only get the amber flashers and C-lights when the DRL would normally be on (i.e. when your parking lights are off).
Correct, there will be no way to get them to turn on if the parking brake is up. There will also be other times they don't turn on, as noted above.
Does that help?
Old 12-27-2018, 03:00 PM   #90
hvuong
Member#: 494513
Car on and brakes up
DRL
Low beams on
Behind light unit doesn't seem to be modified
I'll have to check all the fuses but do you have any ideas?
Old 12-29-2018, 01:27 PM   #91
Cab0oze
Member#: 443914
2021 WRX
Pictures were working the other day, but now that I have time to reply I can't see them. From what I remember seeing, everything worked on the driver side, but no C-light. Does everything work on the other side, or are the c-lights out on both sides?
Previously you said:
[qoute]Also, both lights are out so i feel like it's either been disconnected or a fuse blown.[/quote] so I assumed you were talking about low/high beams, but now I think I realized you're saying BOTH c-lights are out. Maybe there is a fuse for that... I don't have factory c-lights on my car so I can't really confirm. Yours doesn't look aftermarket.
Old 04-19-2019, 12:37 PM   #92
MrSTIGuy17
Member#: 500573
2017 STI
CWP
Does anyone know where the signal/power wire is for the c-lights so when you turn on parking for example, the c-lights/boomerang go on? With the 2017 headlights I have, I can't just replace the bulb like some other older models, but wondering if there's a specific wire that I can splice into to power on the c-light/boomerang as DRL's.
MrSTIGuy17 is offline   Reply With Quote
Old 05-15-2019, 01:49 AM   #93
Rekstr0m
Member#: 501601
2016 WRX - Limited
Post Subispeed Headlight for 2016 WRX
On the subject of headlights, I have a working Subispeed v1 headlight, just the housing (black back portion) is cracked and I'm looking to purchase a replacement. Anyone have info on the manufacturer or tips on mending this. Subispeed won't sell parts or just a single headlight they force you to buy the set. I know that this might be in the wrong place but this is a new account and I have post restrictions (SORRY!)
Rekstr0m is offline   Reply With Quote
Old 05-16-2019, 06:35 PM   #94
Cab0oze
Member#: 443914
2021 WRX
Pictures would help... can you just glue/re-seal it?
Old 05-16-2019, 06:42 PM   #95
Rekstr0m
Member#: 501601
2016 WRX - Limited
The tabs are broken off, and the main cracks broke around the ballast motor locking point, I'm going to try to repair it probably this weekend, I got it pulled appart checked all the cables and lights, started cuts on the areas that need to be reformed. I more or less wanted to know if anyone knew how to get parts for these. Etc. Because me options now are limited to fab work now.
Old 05-16-2019, 06:44 PM   #96
Cab0oze
Member#: 443914
2021 WRX
Good luck!
Old 05-16-2019, 06:47 PM   #97
Rekstr0m
Member#: 501601
2016 WRX - Limited
Thanks man!
Old 05-20-2019, 12:54 PM   #98
Lapezy757
Member#: 501831
I have a 17 STi I installed my DD c lights into my headlights already I’m stumped on how to wire my ss Drl harness , c lights , and ss switchback foglight bezel together so that my c light and led bar on the bezel are my DRL . HELP PLEASE yes I have been researching for about a week now
-I have the 60$ wrx Drl harness Bc ss told me that one would be fine ,
Lapezy757 is offline   Reply With Quote
Old 05-20-2019, 07:28 PM   #99
Cab0oze
Member#: 443914
2021 WRX
More info required. Do you have anything working? Like if you could get the C-light 100% working (using the instructions provided) then finishing the job should be simple enough.
Also, 'm not familiar with how the (updated?) DRL harness is made, so it does kind of depend on that. Do you have a link to the PDF of the instructions?
Old 06-07-2019, 11:25 PM   #100
SR 25 RS
Member#: 97983
2017 STi
For info in case future issues arise with others. Will report back when I take everything apart:
Installed mine months back with bezels. Today I got some some strange activity. When headlights are off, my passenger side C-light is off. When I turn into the ambers option (before headlights fully on) my C-lights work appropriately (with bezels) but when I turn on the headlights, the left C-light is cut off and the passenger side headlight is off.
So strange. Also have a disabled headlight 'cel.' That ish cray. I'm going to go double check my wiring and verify it didn't' come loose over the course of the year. Very strange activity though since it's not exactly a complete loss of signal from a loose wire from what I see.
SR 25 RS is offline   Reply With Quote
