Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 11-15-2018, 02:03 AM   #1
Bellicose7
Member#: 480081
Default 2006 WRX Headlight harness issue
My 2006 WRX has a HID swap that the previous owner did. When I installed C-Bars I think I shorted the drivers side car side headlight wiring harness. I tried a new bulb, ballast, and even new headlight. I then tried the driver side headlight on the passenger side and vice versa, realizing that there’s an issue with the harness on the drivers side. Does anyone have any knowledge on if I need an STI harness because I’m running HIDs, or if the WRX harness would fit. Furthermore, are there any guides on how to change this harness?
Bellicose7 is offline   Reply With Quote
Old 11-15-2018, 02:04 AM   #2
Bellicose7
Member#: 480081
Also, it’s only the low beam light that doesn’t work, sometimes it flickers and then dies. The C-Bar and turn signal works. The high beam has power but is very dark.
