Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Old 06-29-2008, 06:10 AM   #1
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
Default EJ22 block - EJ20G heads: Exhaust question
So I have a newly rebuilt EJ22 block with EJ20G heads on it. I tried bolting my exhaust off my EJ22 onto it and it seems that the new setup is wider? There is a good half inch gap between the two manifolds and they won't bolt in the middle. The intake bolts up just fine. What gives is the exhaust different or something?!
GodSquadMandrake is offline   Reply With Quote
Old 06-29-2008, 11:11 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Why on earth would you whore out shiny piston pics to get an answer to an exhaust question.
Yes....we see you spent some money on pistons. Now figure out why the exhaust won't fit. My guess is that you need to spread the header as you put it up into place. There is no reason why it shouldn't go...... (as long as you are talking about the exhaust and not the intake, which have differences mentioned above).
Jay Storm
Old 06-29-2008, 05:50 PM   #3
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
^^ right exhaust p/n are the same up to 06 ?? maybe install the runners then connect the mid section
sense of nature is offline   Reply With Quote
Old 06-29-2008, 08:08 PM   #4
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
Oh the exhaust spreads? Is there a flex pipe in the middle or something hiding underneath the heatshield? That would be nice. I'll try again today. Thanks.
Old 06-30-2008, 11:11 PM   #5
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
Ok it fit! Thanks guys.
Ej22 block swap question Rich Town Built Motor Discussion 5 08-21-2009 07:53 AM
1999 257 block 99sohc heads: ~400 whp ~426 wtq White 2.5rs Proven Power Bragging 10 07-30-2009 05:19 PM
EJ22e block + EJ20G heads....compression? Numbchux Built Motor Discussion 23 02-23-2009 01:27 PM
FS: EJ22t block, EJ20G short block, sti RA heads my name Engine/Power/Exhaust 20 05-12-2008 08:04 PM
Ej22 to Ej20g swap, difficult? d4d4d4d4 Subaru Conversions 3 03-28-2004 01:59 PM
