Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-31-2014, 06:27 PM   #176
lockmedic
Member#: 314893
Hmmm. . . probably.
The Baja heated seats are 2 settings only. . . low and high, and it's done by switching the base/back elements between a series or parallel wiring scheme. On low, they're in series. . . higher resistance, less heat. In High, they're in parallel. . less resistance, so hotter. There are probably some make-or-break tstats incorporated into the elements for safety, but other than that, they're just 'dumb' elements.
The 05+ Legacy heated seats use a PWM controller with a thermostat mounted in the seat that provides feedback to the controller, which has 4 heat settings. . . didn't pay any attention to how they're connected (series or parallel) but it doesn't really matter.
So to answer the question, yes, you could use an 05+ LGT heated seat switch, but you'd most likely need the elements with tstats from said vehicle. . .as the controller wouldn't have a tstat to work from.
Probably easier to just get 05+ Legacy heated seats and transplant 'em. Take note that the 05-06 switches are much larger than this 08 one. . . I'm not sure you'd have space to mount it. The switches in the 08 Legacy this one came from are smaller than the 00-04 Legacy/Baja heated seat switches, and mounted waaay back under the armrest, which a lot of 07-09 LGT owners complain about. Also the donor 08 LGT had Si-Drive, and I think the ones without have different (larger) switches.
Confused yet?
lockmedic is offline   Reply With Quote
Old 03-31-2014, 06:45 PM   #177
Trucklett
Member#: 334882
2006 Baja Turbo 5MT
Oops. I don't think I worded that clearly. I'd like to take the later seats and transplant them in the Baja and keep the Baja switch, but that sounds complicated since they are using a different method. Darn.
Trucklett is offline   Reply With Quote
Old 03-31-2014, 07:08 PM   #178
lockmedic
Member#: 314893
Well, that would actually be easier. . .but you'd need to rewire the seats to work without the PWM controller. It's very possible. . . but would probably involve tearing down the seats and installing an aftermarket set of seat heaters (which will work with the old style series/parallel switch), or attempting to rewire the 05+ seats to work without the controller. It's doable, but if they don't have tstats, you risk overheating them. . . and your butt.
EDIT: this is a close up of the 08 LGT Si-Drive heated seat switch, next to my Baja's coin holder. I'll get a pic of the bezel I made if anyone's interested, but it's not what I'd call A-list quality. I made it out of 1/8" ABS sheet with a drill press, utility knife, and files.
Old 04-14-2014, 10:06 AM   #179
drifterx
Member#: 25128
2005 Baja turbo
since it hasnt been posted on any of the pages (actually just went through all 8 to make sure) 02-07 wrx GMS aluminum radiator and GMS silicone hoses fit. Had to trim the lower hose to accomedate the extra width of the radiator. The upper hose is really close to the alternator cover but, i diddnt shorten it (i may trim it eventually).
As posted earlier the SPT intake works and i saw the a member had a looked like the spt intake heat shield. When i went to put my heatshield on it diddn look close to fitting so i never put it on. Can someone chime in on the fitment of it? I got the 02-07 wrx fitment one.
drifterx is offline   Reply With Quote
Old 04-14-2014, 08:11 PM   #180
always_willing
Member#: 207724
2006 Baja Turbo
installed H&R 25mm wheel spacers this weekend. i'd always hated how the wheels looked sunken in, now they look flush with the exterior as they should have stock. i can also upgrade the rotors/calipers in the future beyond OEM size now as well.
Perrin lightened crank pulley works, and was an easy install. i've got an automatic and managed to get it on, just had a buddy bump the ignition as described in other posts. didn't notice any power gains however.
subtle solutions dead pedal is probably the best value part i've ever bought. took ten seconds to install, and makes a huge difference in traffic or long roadtrips. looks sharp as well.
i've got the perrin short ram intake on order presently, hoping to get it installed next weekend. will probably keep the snorkel on at first, until i can get a radiator cover. i'll probably try the whey protein mod as referenced here: http://forums.nasioc.com/forums/show...y#post37323286
got the 1" subtle solutions kit as well, but i think ill wait to install it with some new shocks /springs, as im finding the roads in the D.C. area to be atrocious. suggestions?
always_willing is offline   Reply With Quote
Old 04-15-2014, 01:44 PM   #181
thenewrick
Member#: 240649
2004 WRX STi
If the roads are poor don't get a firmer suspension or lower the car. Stick with replacement stock OEM pieces and get some good quality tires and a proper alignment. That'll get you the best ride quality.
thenewrick is offline   Reply With Quote
Old 05-16-2014, 10:54 AM   #182
TurBaja05
Member#: 360425
2005 baja turbo
stoptech wrx stainless braided front brake lines work on the baja, front
stoptech legacy outback stainless braided brake lines work in the rear if you bend the metal tabs back 1/4-1/2" as the lines are about 1/2" shorter than stock rubber lines.
i'll get part numbers if i didn't already throw the packaging away.
will be fitting a sti avcs and oil feed line on my 05 turbo model soon. i hope it fits.
TurBaja05 is offline   Reply With Quote
Old 07-01-2014, 07:51 PM   #183
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Originally Posted by 2.5 turbo hyped View Post
The TMIC has been covered numerous times in this thread. Check it out. :-)
The STi TMIC has been covered many times, I don't recall seeing any others. I can get a stock Baja one for $95 at the local yard, and a WRX one for the same. Paying on average $300 for an STi TMIC and not have it fit the scoop very well doesn't really interest me much.
Thanks for trying though?
Patrikman is offline   Reply With Quote
Old 08-20-2014, 05:52 PM   #184
Styx2066
Member#: 164665
2006 5MT Baja Turbo
Maybe I just overlooked it going through all of the pages, but did anyone state a full exhaust switch? I have a 06 turbo baja 5 spd. I am wanting to change up dp all the way back so I can run a catless system (no emissions testing in Al).
For my own piece of mind, I saw a suggestion for a vag com cable instead of tatrix for a tune, and I saw something about replacing the fuel pump. and to do aeromotive instead of walbro(which I've used before. Which one am I looking at for this setup. http://aeromotiveinc.com/products-page/fuel-pumps/
Please feel free to rudly correct me on anything I'm stupid about. Looking for bolt ons as this is my daily driver, and I prefer to do it myself. Any and all advice is appreciated.
Styx2066 is offline   Reply With Quote
Old 08-20-2014, 07:55 PM   #185
lockmedic
Member#: 314893
I just ordered up some 3" stainless pipe, hangers, resonator, and a Borla Sportsman stainless muffler on eBay and had a local exhaust shop bend and weld it all up. . .with stainless wire.
It's a pretty simple exhaust system to have fabbed up given it doesn't have to go on top of anything.
Old 09-02-2014, 12:06 PM   #186
TurBaja05
Member#: 360425
2005 baja turbo
be careful to use power source with vag com else you will drain your battery in just a couple minutes.
Old 09-16-2014, 01:59 PM   #187
Styx2066
Member#: 164665
2006 5MT Baja Turbo
I've thought about doing that, but I was hoping there was something bolt on, since it's my daily driver, I would like to just knock it out myself over the weekend.
Old 09-16-2014, 02:04 PM   #188
Benhart21
Member#: 149617
Xcelleration has a Baja specific TBE, but it was a bit on the high side price wise.
Benhart21 is offline   Reply With Quote
Old 09-16-2014, 11:34 PM   #189
Styx2066
Member#: 164665
2006 5MT Baja Turbo
Woo! no kidding! also s unfortunately a catted system. I want to go catless. Good find though.
Old 09-20-2014, 05:32 PM   #190
Patrikman
Member#: 234499
2004 Outbrat XT
It is a bit on the high side but fitment and quality are top notch, I've got it on mine.
Old 09-20-2014, 05:52 PM   #191
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Not true. I use vagcom cables on both of my subies. I have been doing it for years. IT DOES NOT DRAIN YOUR BATTERY.
Where do you guys come up with all of this misinformation??
2.5 turbo hyped is offline   Reply With Quote
Old 09-21-2014, 01:02 AM   #192
Styx2066
Member#: 164665
2006 5MT Baja Turbo
What exhaust setup do you have on yours?
Old 09-21-2014, 09:12 AM   #193
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Its a perrin exhaust off a 2012 sti sedan. No, it does not bolt right up.
Old 09-21-2014, 09:19 AM   #194
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
WRONG!!! BCracing and I worked together to make a setup that increased the payload of the baja and rode smooth as glass on forest service roads at 80 mph.
Call up Import image racing and tell Josh you want the same setup Sean Fillner has on your baja.
The strut cartridges are 50mm longer so you can do a 2" lift rather than lower it and they use 14k swift springs on all 4 corners.
This setup makes the oem setup feel like jalopy garbage trash clown car suspension.
Old 09-21-2014, 02:57 PM   #195
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Hmmm my suspension is getting kinda worn at 143K... what is the cost of that setup Sean??
Flowmastered87GL is offline   Reply With Quote
Old 09-21-2014, 06:31 PM   #196
dansch
Member#: 401145
Sean, How much adjustment in ride height do you have with this set up? Is a 2" lift the max high? What is the max low? Below stock? That would be awesome if you could have a set up that went +/- 2" from stock depending on the season and tire selection.
dansch is offline   Reply With Quote
Old 09-21-2014, 07:05 PM   #197
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Stock height to +4 but your axles (front ones) will pull apart before you get it that high.
Why would you lower a baja??
IIRC it was around 1200 shipped but that was over a year ago.
Old 09-21-2014, 10:13 PM   #198
Patrikman
Member#: 234499
2004 Outbrat XT
Anybody have any idea how much different the axlebacks are in length between stock Baja and a hawkeye Impreza? I have the stock axleback right now but I came across a Prodrive one that I can get sorta cheap.
Old 09-22-2014, 12:14 AM   #199
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
It won't fit. The bajas wheelbase is at least 6 inches longer than any other subaru. Try to fit a wrx exhaust or exhaust part on a baja and you will see what I mean. Unless you can weld or have big bucks to pay someone to weld it will not fit. There is no cheaping out on this one.
Old 09-22-2014, 10:14 PM   #200
Styx2066
Member#: 164665
2006 5MT Baja Turbo
What modification did you have to do, or did you have a shop fit it?
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
