Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2020
Old 08-03-2005, 06:20 AM   #1
RexSex
Member#: 79088
2004 300hp WRX
Default Odd sound under high boost
Alright, I seriously did a lot of research on this site, so plz don't tell me this is a repost. I can't find anything that discusses my specific problem.
Basically, I have a boost controller on my 04 WRX. On low, it is at 6psi, and on high it is at about 16-16.5psi. I only ever use high if I need to launch through a busy intersection, pass someone at lower or higher speeds, or race someone at a traffic light. Other than those times, I am always on low. This is mainly out of precaution and hoping to save some gas as well.
Note: Im still a noob when it comes to performance modding. Taking it a little at a time.
So, the problem is that when I set the boost controller to high and floor it, the engine makes a sort of ticking sound, but as I said ONLY when I am flooring it and reaching around 4000-5000rpm. It is a faster ticking, that gets a little faster the harder I push the car.
The sound never happens on low boost setting no matter how hard I push the car, and never happened with stock boost settings before installing the boost controller, and never happens when decelerating, nor when accelerating normally...just to be clear.
I am going to take it in to my friend's shop in the coming few days, but for now I was wondering if anyone had any insight to what the problem may be, if any.
It could be nothing, but just in case. Thnx.
Thnx.
RexSex is offline   Reply With Quote
Old 08-03-2005, 07:55 AM   #2
BamBooI
Member#: 10945
2006 Evolution IX
detonation?
BamBooI is offline   Reply With Quote
Old 08-03-2005, 08:23 AM   #3
23b_Rex
Member#: 79394
02 gda
wrb
it's the wastegate ticking
is this a mbc?
23b_Rex is offline   Reply With Quote
Old 08-03-2005, 08:46 AM   #4
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
Thnx.
this entire paragraph scares me.....
-Kevlar- is offline   Reply With Quote
Old 08-03-2005, 09:13 AM   #5
RexSex
Member#: 79088
2004 300hp WRX
Yes its a manual boost controller. Is the ticking ok? And why does the paragraph scare you? lol...let me know if Im doing something too dangerous. Thnx.
Old 08-03-2005, 09:25 AM   #6
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
I'd like to hear the answer to the ticking
Bundyboyz is offline   Reply With Quote
Old 08-03-2005, 09:39 AM   #7
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
@thejeffruhl 387hp/350tq
sounds like detonation. Isnt a MBC on an 04 bad juju?
JeffrWRX is offline   Reply With Quote
Old 08-03-2005, 04:26 PM   #8
RexSex
Member#: 79088
2004 300hp WRX
Anyone else have any feedback? Im getting worried...
Old 08-03-2005, 04:39 PM   #9
RexSex
Member#: 79088
2004 300hp WRX
Just spoke to Andy at Neetronics. He thinks it's detonation too. lol...WHEW...Im glad I found out about this sooner than later. I'm such a noob.
Old 08-03-2005, 07:13 PM   #10
23b_Rex
Member#: 79394
02 gda
wrb
take the mbc off RIGHT NOW! detonation = bad... the 04/05s have a delay when switching from open loop to closed loop fueling... mbcs cause part throttle full boost.... ptfb + ol/cl delay = kab00m! if you don't take it off, you're going to blow your s**t up... seriously
Old 08-03-2005, 07:25 PM   #11
IronMedic
Member#: 82122
2005 WRX Premium
if u want a MBC, use a UTEC to help it. i didnt have my ABC so i had to get a HPMBC from turboXS to use with my UTEC. works great and im running 14.5 psi of boost for now with my stage 2
IronMedic is offline   Reply With Quote
Old 08-03-2005, 10:11 PM   #12
RexSex
Member#: 79088
2004 300hp WRX
Alright, I set the MCB low to 6psi and the high to about 14psi (down from 16.5psi). Is this ok? Or should I take it off completely? Is even the 6psi ok or is the whole MCB a problem for the 04?
My mechanic said that I didn't do any serious damage, since if I did it would all be over right now. That is a relief. Im planning on getting the ECU tuned, but that is not for another month or two.
Plz let me know if even the 6psi is ok. Thnx.
Severe stuttering under high boost linsavy Pre-2002 Factory Turbo Powertrain 66 04-01-2020 03:00 PM
"creaking" or fluttering noise under high boost/throttle...?? vokalize770 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-06-2008 03:38 PM
Clutch slips under high boost gatts Transmission (AT/MT) & Driveline 6 03-19-2007 08:20 PM
Whistling sound at high boost STI8U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 04-02-2005 05:44 AM
Annoying Two Stroke Sound under high boost SpooledRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-18-2002 09:30 PM
