Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 10-14-2004, 11:47 AM   #1
dedfish
Member#: 6482
2011 Transit Connect
Metalic Silver
Default Switching to snow tires early...how bad is that?
I just had a flat on my summer tires and I was thinking about just putting my snow tires on the car now and just replacing the summer tires after the winter. I live in Boston and we probably won't see snow for at least another month or two. How bad is it to run snow tires this early in the season?
dedfish is offline   Reply With Quote
Old 10-14-2004, 12:46 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The snow tire compound will not hold up to heat well at all. If you had a nice sunny day and drove many miles it could significantly wear the tread. If you don't drive much, it will likely not be a problem. Depends on the snow tire compound too. There is no safety issue, although the snows are not optimal for dry weather driving.
linsavy is offline   Reply With Quote
Old 10-14-2004, 01:10 PM   #3
obyone
Member#: 16523
Snow tires don't like the warm weather. They get real squirmy and wear faster than normal, under warm temperatures.
obyone is offline   Reply With Quote
Old 10-14-2004, 03:10 PM   #4
dedfish
Member#: 6482
Metalic Silver
Well it's a done deal. This is the first time I've prayed for early cold weather!
Old 10-14-2004, 03:30 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
If you have a more all season snow tire like the Nokian WR or Bridgestone LM-22 you will be fine.
mbiker97 is offline   Reply With Quote
Old 10-14-2004, 08:43 PM   #6
nate49509
Member#: 22452
2018 STi
What he said. The more performance oriented winter tires will do just fine in the semi-warm weather.
nate49509 is offline   Reply With Quote
Old 10-14-2004, 11:22 PM   #7
dedfish
Member#: 6482
Metalic Silver
I have the Kumho I'ZEN Stud Snow tires. They are not studded, but studable.
Old 10-15-2004, 02:26 AM   #8
nate49509
Member#: 22452
2018 STi
Ok.
Old 10-14-2004, 06:26 PM   #9
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
No problems. Think of snow tires as temperature tires. As it gets colder, the softer tread compound works better than that of a performance tire, which gets rock-hard in temperatures below 40 degrees F.
Just don't drive all crazy and stuff, and you'll be fine. The other question is what kind of snow tires do you have? This makes a big difference.
Kevin
gtguy is offline   Reply With Quote
Old 10-14-2004, 06:52 PM   #10
SOOBY
Member#: 51946
2000 RS 2.5
Blue Ridge Pearl
Default Snows
We'd a fall of snow about 2 weeks ago. I put my (New last winter) snows / studded tires on.
Snow lasted about 2 days then it was gone. We're due big snow soon, so I was going to leave them on. However, soon as they're warm, you can actually feel the car slip, under heavy cornering, so, I took them off again and put my summer tires back on.
Here you're allowed to use studded tires from mid September I think, but, I could almost 'hear' the tires wearing on the dry roads....
SOOBY is offline   Reply With Quote
Old 10-15-2004, 02:21 PM   #11
[email protected]
Tire Rack Moderator
Member#: 1215
ext. 4362
you'll be fine .... I have a set of winter tires on 1 of my cars already
Luke@tirerack is offline   Reply With Quote
Tires: Wider and bigger, but how bad is that really? metoo Tire & Wheel 8 03-04-2008 08:32 PM
How bad is it to drive on snow tires in warmer weather??? Farnsrocket Tire & Wheel 4 12-16-2006 12:26 PM
When are you going to switch to snow tires? Undepelo Mid Atlantic Impreza Club -- MAIC 14 11-30-2004 10:12 PM
When to switch to snow tires? Rich10 Brakes, Steering & Suspension 15 10-31-2002 08:28 AM
How bad is that? Subalo Transmission (AT/MT) & Driveline 6 05-03-2002 10:02 PM
