Welcome to the North American Subaru Impreza Owners Club Sunday July 15, 2018
Old 08-20-2009, 12:13 PM   #1
alwu
Member#: 73776
Default uppipe and tgv CELs
i had some mods done to my subie recently which included a catless uppipe and tgv deletes, so i'm getting the CELs associated with those mods.
what's the correct way to get rid of these CELs with romraider? do i use the CEL fixes, delete the codes, or both?
alwu is offline   Reply With Quote
Old 08-20-2009, 12:56 PM   #2
D-NaSty
Member#: 156456
2005 92x aero
turn off the codes in romraider, I think its under the emissons folder
D-NaSty is offline   Reply With Quote
Old 08-26-2009, 09:29 AM   #3
mateospeed
Member#: 116317
2002 WRX...sold:-(
second. That's the "right" way to do it. Don't bother with CEL fixes, just disable the codes in RomRaider/ EcuFlash. www.romraider.com
mateospeed is offline   Reply With Quote
Old 08-26-2009, 09:54 AM   #4
Tea cups
Member#: 103136
disable the CELs and also enable the TGV fix (16-bit ECU).
Tea cups is offline   Reply With Quote
Old 08-27-2009, 05:18 PM   #5
alwu
Member#: 73776
thanks. that's what i did. i was getting the P2004, P2005, P2016, and P2021 CELs. i disabled those CELs and enabled the tgv fixes that included those CELs. but i left the other tgv related fixes and CELs alone, so i haven't enabled all the tgv fixes nor have i disabled all the tgv CELs. should i go ahead and enable/disable those even if those CELs haven't been thrown?
also, should i clear the CELs first with a scan tool before disabling them? or does that not matter?
Old 08-27-2009, 05:23 PM   #6
Tea cups
Member#: 103136
no, you do not need to clear the codes with scantool. Just disable and flash (you can always reset the ECU in RR's logger if you like although a flash has the same effect with most ECUs).
If you aren't getting the CELs pertaining to a fix, then you don't have to enable the fix. Won't hurt anything if you do anyway.
Gutted uppipe and no CEL 94'325is Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-06-2008 05:05 PM
Odd power-making problem. TGV CEL-related? jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-07-2005 08:27 PM
helix uppipe and downpipe no CEL? VideoGameWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-02-2004 09:31 PM
TGV CEL feature request from Ecutek janchiko Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-30-2004 02:53 PM
Godspeed uppipe and downpipe, still a CEL Oo DaRk StAr oO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-21-2003 06:35 PM
