04-14-2018, 12:47 PM | #51 | |
Member#: 356492
The problem I found is that the ASWC-1 is detecting the radio as an Eclipse. I used the PC software to force it to Sony, and all is well. Joe
04-14-2018, 12:53 PM | #52 | |
Member#: 356492
Joe |
04-14-2018, 11:05 PM | #53 |
Member#: 438216
If you don't have spare pins(or don't want to mess with it), this connector already has pins 4, 13, 14 installed:
https://www.amazon.com/20-pin-Subaru...dp/B01D9K3L44/ |
11-26-2018, 03:01 AM | #54 | |
Member#: 477158
Vehicle:2011 GR STi Hatch SWP |
My only concern is getting in there and soldering inside the dash opening...it's going to be literally the worst. I don't know if anyone can comment, but would you wire your back up camera power to the head unit power (red) or rather the reverse signal brown/yellow cable by passenger footwell? Pros to reverse cable is longevity for the camera, however it would only trigger video when the car is in reverse. Vice versa for splicing to HU Accessory (red). Thanks! |
01-23-2020, 04:08 PM | #55 |
Member#: 511009
Vehicle:2015 STi black |
Hi everyone,
i have little problem and need help with connect SWC to Sony ax100 in STi 2015 from USA because in car audio shop in europe cut cable from 20pin and connet in ISO cable. I need original oem color cable from pin 4, 13, 14 . Tnx for help |
01-23-2020, 04:17 PM | #56 | |
Member#: 2452
SCIC
Vehicle:2016 WRX WR Blue |
http://ae64.com/20-pin-pinout.htm Here's his ordering page: http://ae64.com/Ordering.htm He ships internationally and will be your best source of information when needed. Good luck. |
01-23-2020, 04:34 PM | #57 |
Member#: 511009
Currently i have connect and working radio on ISO cube but don't have SWC. Radio have 3,5mm jack connector to SWC but i don't know which oem color cable connect.
BTW sorry for my English |
01-23-2020, 06:10 PM | #58 | ||
Member#: 2452
SCIC
Check out this thread: https://forums.nasioc.com/forums/sho....php?t=2815667 Scroll down to post #11 Quote:
01-24-2020, 04:55 AM | #59 |
Member#: 511009
I read this before, but in car don't have 20 pin cube - only cut cable. I need cable color for pin 4,13, 14, dont' see color in post, only pin number
