Welcome to the North American Subaru Impreza Owners Club Wednesday April 8, 2020
Old 02-15-2020, 01:27 PM   #1
RKozlowski
Member#: 511708
Default 2009 Impreza 2.5 cylinder 2 misfire
Hello new Subaru owner here, I just recently purchased a 2009 Impreza 5 speed with 114k miles. Yesterday I noticed that when it is revved at about 4K rpm and above it makes a strange noise that I canít really explain it just doesnít seem normal. Anyways I tried accelerating hard in second gear and it gave me a flashing check engine light for about 5 seconds then disappeared. I went home and scanned it and got back a cylinder 2 misfire code.
RKozlowski is offline   Reply With Quote
Old 02-15-2020, 05:12 PM   #2
IHaveAHorse
Member#: 507873
Spark plugs?
IHaveAHorse is offline   Reply With Quote
Old 02-15-2020, 05:56 PM   #3
RKozlowski
Member#: 511708
Originally Posted by IHaveAHorse View Post
Spark plugs?
I hope so Iím gonna change the plug and coil pack to another cylinder tomorrow to see if the code changes. If not that Iím looking for suggestions on other possible causes
Old 02-15-2020, 06:28 PM   #4
IHaveAHorse
Member#: 507873
If it were me, working up from the easiest and cheapest options first, if the spark plug change doesn't work, I'd maybe try hot soaking the cylinders after warming the car up a bit but not fully. I'd dump seafoam into the spark plug holes and just let it sit in the cylinder overnight, crank in the morning without the spark plugs in because you don't want to bend the valves on the off chance there's enough seafoam in the cylinder to cause dangerous compression, screw them back in, and start it up. But that's just me, just an easy/cheap thing to do worth trying, could be excessive carbon on a valve or something in theory.
Old 02-16-2020, 01:54 PM   #5
RKozlowski
Member#: 511708
I switched out the plugs today the one closest to the back of the motor was drenched in oil Iím not sure which is cylinder 2 or 4 however
Old 02-16-2020, 03:40 PM   #6
IHaveAHorse
Member#: 507873
That sounds like a pretty involved fix... Piston ring's obliterated I'd guess? Hopefully no piston or cylinder damage but I would almost expect there to be
Old 02-18-2020, 06:46 PM   #7
Bsmith650
Member#: 511786
Following this cause Iím getting a miss on 2 on my 07
Bsmith650 is offline   Reply With Quote
