08-24-2007, 04:34 PM | #1 |
Member#: 89058
International
Vehicle:2003 WRX 9.33/151mph EJ257+PT7675 840whp |
Stock EJ205, stock clutch, 11.989@119(11,[email protected])
Today did 11.989@119mph (22 psi boost)
Stock EJ205, stock clutch, no passenger sit, 225/45/17 GY F1, 95F it was at the see, on airport so the moisture level was very high and it was f..... hot Last time I wrote: next time when its colder and no wind I think its possible to make 11.9 or even 11.89 and I did a little mistake when shifted in 2nd So, here you are Mods are: FPGreen, SMC Meth injection 50/50, Walbro 255 fuel pump, STI pinks (550cc), Noname China FMIC, Apexi Short Ram intake, , Apexi AVCR, QTP cutout, Blitz Nurspec RX TBE, One step colder (7) plugs NGK Iridiums, TurboXS UTEC (SELF TUNED), PPG 1st and 2nd straight cut syncro gears, Kartboy shifter the blue one))) the begining is here http://forums.nasioc.com/forums/show...26158&posted=1 Last edited by Bilyk WRX; 10-12-2007 at 10:51 AM. |
08-24-2007, 04:49 PM | #2 |
Member#: 71460
Tri-State
Vehicle:2007 STi Limited |
Whats your IDC and AFR with the pinks and meth? Just wondering cause I run pinks with my 16G and wondering what their real max is. Nice time though.
08-25-2007, 01:28 AM | #3 |
Member#: 89058
International
08-24-2007, 05:01 PM | #4 |
Member#: 132587
Vehicle:2006 JrTuned STi 8.69@164mph |
i wasnt aware you could run an FPgreen with STi pinks...are they maxxed out?
08-24-2007, 05:06 PM | #5 |
Member#: 104944
pinks+meth
08-24-2007, 09:33 PM | #6 |
Member#: 101880
SCIC
Vehicle:2012 Mustang GT |
yay, a green in the 11s
08-24-2007, 09:43 PM | #7 |
Member#: 115420
MAIC
Vehicle:Its like a STI..... but it doesn't break |
Very nice run. How is your stock clutch holding up?
08-25-2007, 01:32 AM | #8 |
Member#: 89058
International
08-25-2007, 09:12 AM | #9 |
Member#: 117854
Vehicle:2003 spec c |
good run! You still running the HKS clutch you had problems with?
I saw your log, looks fantastic. A really sweet boost curve, almost no taper from 4 to 7k rpms! You MAF voltage is 4.6 so looks like your new APexi intake gotta go home )). Did you think about going speed density on your new FMIC? Might be worth an extra 30whp on meth... Last edited by STi*guy.kiev; 08-25-2007 at 09:22 AM. |
08-26-2007, 12:00 PM | #10 | |
Member#: 89058
International
I've been to SD since the begining! . I built my SD map myself. It took 3-4 hours to make it perfect |
08-27-2007, 04:25 AM | #11 |
Member#: 89058
International
I must admit, that engine EJ205 is completely stock with stock heads and stock internals. The milage is 51000 (81600 km).
08-24-2007, 11:14 PM | #12 |
Member#: 91925
TXIC
Vehicle:2015 WRX STi AWDTuning.com |
Nice run man, sounds like you've put some serious thought and work into your setup.. I was wondering what type of g/s your seeing on your logs (if you take any..)
08-25-2007, 04:34 PM | #13 |
Member#: 22987
SCIC
Vehicle:2010 PB EVO X GSR... .. It's All Stock Officer |
thats a great pic! Im surprised that the pinks got you into 11s with only 88***37; IDC. Awsome!
08-25-2007, 04:43 PM | #14 |
Member#: 140529
TXIC
Vehicle:01 Ferrari 360 spy |
On a ej20 thats impressive, nice run.
08-27-2007, 01:03 PM | #15 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Congrats on that pass. Rods have to be close to saying by by. I went 11.82 back in o3 with a setup close to yours on the stock EJ205..
CLark |
08-27-2007, 03:18 PM | #16 | |
Member#: 89058
International
As you see on the picture its usual road surface with no glue on it. wheel spin is common problem here. RWD cars with 500+ rwhp can't make faster then 11.5 finishing at 135+ mph |
08-27-2007, 01:16 PM | #17 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
nice frigging run, and good on ya for tuning it yourself.
08-27-2007, 03:36 PM | #18 |
Member#: 8785
SWIC
IN reality the make shift drag race systems are a bit faster. I bet you would slow down at a NHRA certified track in the US. Great time for a stock engine though!
Clark |
08-27-2007, 04:25 PM | #19 |
Member#: 89058
International
10-12-2007, 04:34 PM | #20 |
Member#: 88322
MWSOC
Vehicle:2009 BMW 135i |
08-27-2007, 04:28 PM | #21 |
Member#: 89058
International
and may be somebody has big experience in 1/4 how much HP do I have?
10-12-2007, 08:39 PM | #22 | |
Member#: 67371
Vehicle:05 BUILT 2.4L STI |
Based on that speed (119) You could have anywhere from 370-400WHP. Which sounds about right for your set-up. The best I've done on my pump gas map (403 WHP) is 11.69 @ 118 with 1.60 60 ft. With better tires and clutch you should be able to run better since your car is lighter. But your car is little trickier to launch. Good luck! |
10-13-2007, 08:41 AM | #23 |
Member#: 89058
International
10-13-2007, 06:38 PM | #24 |
Member#: 84786
RMIC
Vehicle:2011 STi SWP |
so thats on a 2.0? Got a dyno graph?
10-13-2007, 07:04 PM | #25 |
Member#: 147598
Vehicle:95 Impreza 2dr Black |
ive got a similar setup... at what rpm are you hitting your max boost??
