Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 12-10-2009, 10:22 AM   #1
geneahn
Member#: 164681
Default My buddy's 05 Legacy GT Engine/Turbo failure!! GRRR!!!
Please give any advice if there is any! I feel really bad for my friend cause I bought an 09 WRX and he wanted to join the Subaru family asap...so he bought his 05 Legacy GT mid October...
Please note my buddy brought in his Legacy 1 month after purchasing it in for an oil change AND full inspection to make sure nothing from the previous owner would need repairing...(he has documentation of this) now...3 or 4 weeks after the oil change/inspection this happens:
To Whom It May Concern:
Brought his 2005 Subaru Legacy GT in for inspection on 12/07/09.
Customer stated that the check engine light was on solid.
Customer stated that when the vehicle is warm there is a clatter noise coming from the engine area.
Customer stated that there is a squealing noise when turning the steering wheel to full end and also at times when starting the vehicle.
Technician findings:
No oil was found on the dipstick and no sign of an oil leak under the vehicle.
Found clatter noise due to an internal failure within the Engine Assembly (rod knock).
Found internal failure within the Turbo Assembly.
( Possible Turbo failure causing no oil)
Note: customer has had an oil change service performed at Byers Imports on 11/11/09 at 71,678 miles.
Estimate to replace engine Assembly with a Short Block is $4,750.86 + tax
Estimate to machine Cylinder Heads if needed is $375.00 + tax
Estimate to replace Turbo Assembly is $2,167.50 + tax
I want to say we might have a case to pin negligent inspection and oil change on Byers imports?
geneahn is offline   Reply With Quote
Old 12-10-2009, 11:38 AM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
They usually kick it to the owner's responsibility to check oil level since it's stated in the owner's manual, but given that it was only 1 month from being bought at that dealership, you may have a case. Did Byer's include some short warranty with the car? It could still fall under that.
rougeben83 is offline   Reply With Quote
Old 12-10-2009, 11:40 AM   #3
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
It is possible that whoever did the oil change just drained the oil and didn't fill it back up, but the tech AND driver should have noticed this the moment the car was backed out onto the lot ready for pickup/driven away from the lot.
If a turbo is burning up oil the driver should see it smoking - the oil pressure light should have come on also.
Huffer is offline   Reply With Quote
Old 12-13-2009, 10:13 AM   #4
joeleodee
Member#: 193020
Search legacygt.com or post findings there if not done already. You will get more response.
joeleodee is offline   Reply With Quote
Old 12-15-2009, 06:13 PM   #5
oside13
Member#: 211017
That sucks!!!!!!!!!!!!!!
oside13 is offline   Reply With Quote
Old 12-17-2009, 11:14 PM   #6
Humbleninja
Member#: 208222
1992 Legacy SS
Sounds like he might be shiza out of luck, if the car is stock (catback exhaust ok) and has less than 60K on it, it still has powertrain warrenty at the dealership. Working at an undisclosed dealership i also know that if he calls subaru corprate and plays his cards right or just down right bugs the living crap out of them he might have a good chance of getting a goodwill warrenty repair, especially if its close to 60K. Guy at my work had an STi with 62K miles on it and the oil pick up cracked where it bolts to the block! He got a new block, heads, cams, and turbo and only had to pay for labor because he called subaru on it and they are pritty easy to push over. Also it helps to try and get on your service writers good side, if he knows what hes doing he can also help you out.
Humbleninja is offline   Reply With Quote
Old 12-20-2009, 05:54 PM   #7
jaygsx88
Member#: 228239
2012 STI Wagon
Ice silver metallic
sucks man good luck
jaygsx88 is offline   Reply With Quote
05+ legacy gt engine cover.. does anyone know where to buy? UnXpectedError Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-11-2009 01:44 AM
My limited 05 Legacy GT pdx Nick 05 LGT Member's Car Gallery 6 06-16-2009 02:32 AM
What's wrong with my car 05 legacy gt seden garboplateNY88 Service & Maintenance 0 07-20-2007 12:58 AM
Enkei RP03's on my dad's 05 Legacy GT- Got pops some new shoes :) IMPORTIMAGE Member's Car Gallery 32 11-14-2006 12:08 PM
WTB: 05 legacy GT engine cover o2sys Private 'Wanted' Classifieds 1 09-11-2005 07:30 PM
