Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 06-26-2009, 02:42 AM   #1
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
Satin Gray Metallic (CGM)
Default Cobb Stage 2 logs - not hitting boost target
Hey guys,
Setup: Cobb catted DP, UP, STI CBE, SPT intake, APv2 Stage 2 flash, Shell 93 octane.
I did a few more runs today following prior advice of going from 2500 to 6500 at WOT in 3rd gear (couldn't find a safe place to do it in 4th). The highest boost I hit was a mere 13.8psi. I should be hitting 16.5psi.
Today's 13.8psi log
There are no obvious leaks in front or behind the turbo, the restrictor pill is still there, and the car runs like a top otherwise.
For what it's worth, it was 104 degrees here in Houston when I was doing the runs. Previously, I was hitting 14.8psi when it was in the mid-80s. Could there be some correlation?
I'm tempted to turn the waste gate actuator arm in 1.5 turns and see what happens. Any advice is much appreciated.
Drivinwest is offline   Reply With Quote
Old 06-26-2009, 11:45 AM   #2
b00stin
Member#: 212898
05 CGM STi
WFC #289
Is this is the SAAB?
b00stin is offline   Reply With Quote
Old 06-26-2009, 11:51 AM   #3
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
It's a Saabaru... a 2005 WRX wagon with a Saab nose, STi bits, leather, etc. The drivetrain is identical to a 2005 WRX.
Not hitting boost targets in 1st or 2nd? HELPr AccessPort 3 03-09-2010 09:50 PM
CT Protune Not hitting boost targets, HELP! KmofugginD AccessPort 4 07-30-2009 01:49 PM
Perrin GT30R not hitting boost targets is it FBC or something else roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-15-2006 01:30 PM
just installed cobb stage 2.5 - not hitting targest boost! what gives? anthonyrb98 Engine Management & Tuning 7 10-24-2004 11:58 PM
Cobb stage 2... not hitting boost target level... WRXVII Engine Management & Tuning 37 06-06-2004 01:14 AM
