Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 05-24-2018, 09:48 PM   #1
illestbryan
Member#: 433353
2011 Wrx
Default AC Noise
I was wondering if I can get a little insight on this. My AC started making this noise a day or two ago and I donít remember it being this loud. Only happens when AC along with the clutch being engaged? Right when the clutch disengages, the noise is gone. AC is still blowing cold. Can kinda feel a power serge as well. Could the pulley be going out or something or is this normal.
Car is a 2011 Wrx. I took a video and is posted below.
Thanks in advance!
http://<iframe width="560" height="3...reen></iframe>
illestbryan is offline   Reply With Quote
Old 05-25-2018, 02:22 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Can't see your video.
Old 05-28-2018, 02:20 AM   #3
illestbryan
Member#: 433353
2011 Wrx
Old 05-28-2018, 04:08 AM   #4
VinceS2
Member#: 353338
2005 EVO 8 WRX + STi
gold
Sounds like a bearing cage has collapsed. The clutch 'lets go' of it so it rattles around before coming to a stop. The belts are tracking well so not totally cactus yet. Too tight belts are the number one cause of bearing failures, how do you think the adjustment was of this one?
The a/c solenoid clutch assembly can be removed to inspect, but you need to hold the triangle plate / inner section bit, not the outer pulley bit as the little spring connector damper fingers won't like it if you try to undo the centre retaining bolt and they have to try and hold it...!
Hard to tell, but wondering when your timing bearings are due to be changed? Could be sooner than you think! Don't rely on a www diagnosis for this one but. A screwdriver on the cover might help (can be scary with the wrong screwdriver!). Or just compare with a known good one.
VinceS2 is offline   Reply With Quote
Old 05-28-2018, 10:27 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Sounds like the AC clutch for sure although some rust in the clutch/pulley surface can make some noise.
It is a stretch belt.....so.....tension should be fine and no idler pulley (older models mounted the tensioner from the 2 threaded holes sorta lower left of the compressor, yours are empty) to have failing bearing.
Timing belt should always make the same noise regardless of AC on or off.
Agreed, "if" you were to pull the AC clutch, don't pull by the outer part as this will likely bend the plate as mentioned. This will negatively affect the clutch operation.
Old 05-28-2018, 11:30 AM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Start with this first. Easy to remedy if this is the culprit and little to no cost involved.
This is a common problem.
Rust builds up around/between the clutch/pulley areas.
All you need to do is used compressed air to blow all this out. Only takes a few minutes.
If you do this, wear a mask & glasses, or be careful, bequest what comes out is a fine powder and it can get in your eyes and in your nose/throat. Won't be pleasant.
Old 05-30-2018, 02:29 AM   #7
illestbryan
Member#: 433353
2011 Wrx
Believe it or not that actually worked. The whole dust blower. Knock on wood lol but for now it seems good. I will update you guys if it comes back. Thank you guys very much for your help on this.
Old 05-30-2018, 11:29 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Cool
We are glad to help.
Old 05-31-2018, 10:19 PM   #9
mysadsubie
Member#: 486650
Default Compressor Clutch
I have a similar problem where my clutch has broken. It looks like I just need to replace the springs in the clutch or put a new clutch on. I can't find anywhere that I can buy a new clutch but have found many repair kits. Does anyone know anywhere I can get one? I have a 2010 impreza.
mysadsubie is offline   Reply With Quote
Old 06-15-2018, 09:14 PM   #10
illestbryan
Member#: 433353
2011 Wrx
Good afternoon guys,
It looks like the problem is back. Do you think it could be the AC clutch or do you think it could be the idler pulley? Iíve seen some post that say itís the idler pulley and that fixes the problem but the sound is coming from the Ac pulley area. I even double check the belt and tightened it a little more as well as cleaned around that area again but same noise...
Old 06-17-2018, 12:39 PM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If the problem is back, I would :
1. Blow the dust out again to make sure you got it all. It took a couple of attempts to get all the rust out when I did mine.
2. Idler pulley would be my next step. Eventually I had the squeak return after quite some time. Changed the Idler Pulley and it never returned. I think the Idler pulley is ~ $30 if you buy a good brand. Pretty sure I bought a Denso replacement.
Old 06-18-2018, 09:07 PM   #12
illestbryan
Member#: 433353
2011 Wrx
Ok perfect. I will give this a try again tomorrow and see if that works and let you know. If it does come down to idler pulley, is it pretty simple to change our? Seems inexpensive
Old 06-19-2018, 08:04 AM   #13
Samurai Jack
Member#: 21145
2002 Enemy of Aku
The Idler pulley is very straight forward to replace.
Yes, the pulley is fairly inexpensive:
https://www.autozone.com/external-en...subaru/impreza
