Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 07-13-2006, 07:52 AM   #1
dodiox
Visiting NASIOC Timeout
Member#: 85718
06 WRX
Cobb Stage 2
Default 06 wrx with vf39 needs new restrictor pill?
i was checking out cobb map notes on the vf39 upgrade for my car and they say you need to change the restrictor pill in the vacuum hose and make the hole bigger. is there a place where you can just buy the pill required? i don't want to mess with the original pill just in case i want to take the car back to stock.
thanks!
dodiox is offline   Reply With Quote
Old 07-13-2006, 08:26 AM   #2
ControlFreak
Member#: 99200
Buy a stock restrictor pill and have it drilled out, and hang on to the original one.
I'm not sure where you can buy one though..
ControlFreak is offline   Reply With Quote
Old 07-13-2006, 08:55 AM   #3
equipment junkie
Member#: 97607
2006 wrx
wrx blue
The restrictor pill is in the VF39 vacume hose line that is connected to the wastegate vacume solenoid. If you leave your stock hose on the TD04...you'll still have the stock set up. You drill
the pill that comes WITH the VF39. Go to a tool supply store and buy the appropriate bit (a couple of bucks). The pill is made of brass (soft) and drills very easily. You don't even have to remove it from the hose. This is very, very simple. No biggie...don't sweat it
equipment junkie is offline   Reply With Quote
Old 07-13-2006, 09:46 AM   #4
06WRXTR
Member#: 96668
2006 WRX TR
or you can just simply buy a 3/16 vaccum connector
06WRXTR is offline   Reply With Quote
Old 07-13-2006, 10:32 AM   #5
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
My VF39 pill was already at the recommended size of .043. Also... good luck getting a .043 bit into a standard drill....
Bullitt 2496 is offline   Reply With Quote
Old 07-13-2006, 10:59 AM   #6
devil doc
Member#: 107279
06 vf39 wrx
black
what size is the stock vf39 pill ?. when i bought the turbo it had the stock one so i wanted to know if it still has to be modify
devil doc is offline   Reply With Quote
Old 07-13-2006, 11:10 AM   #7
Yoo Shin
Member#: 87327
2017 Heron White SS
I still kill threads
#57 bit, right?
Yoo Shin is offline   Reply With Quote
Old 07-13-2006, 11:48 AM   #8
06BLUEREX
Member#: 120000
yes the stock one is correct, you wont have to mod it if yours came with the turbo. But i would try to find the #57 drill bit anyways just to make sure.
If your in Houston you can purchase the drill bits from Bass tool supply , they carry all the drill bits. thats where i purchased my #57 drill bit for my old vf39 setup and new drill bit for my 18G they have like 30 instock of each and are 70 cents each. hope this helps. if you need any help just PM.
06BLUEREX is offline   Reply With Quote
05 WRX with a VF34 which restrictor pill should I use? Zerogravity Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-27-2008 02:34 AM
06 wrx with vf39 question rabbitae86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 04-29-2007 03:48 PM
06 wrx with vf39 an sti tmic openecu tune WTFchuck Proven Power Bragging 5 03-20-2007 10:19 PM
06 wrx with vf39 and stock intercooler? dodiox Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-28-2006 11:39 AM
06 WRX with VF39 and STi IC? bcristea Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 54 01-23-2006 01:34 PM
